I have the following situation. I have an array of floating point values (keys) and two floating point arrays each containing 3D points (the arrays are of size number_of_points*3). The x, y, z coordinates are basically kept one after the other.
[codebox]
float *keys; // contains key values
float *arr1; // 3D points…x, y, z, x, y, z, x, y, z…
float *arr2; // 3D points…x, y, z, x, y, z, x, y, z…[/codebox]
Now, I need to sort these arrays in ascending order based on the key values.
I looked at the SDK and there seems to be a radix sort example and I was unable to figure out how to m odify it for my needs. Can someone provide any suggestion on how I might go about this.
I have about half a million keys to sort. So, it is not too many. The algorithm does not have to be the best in business but just good enough.
Thanks,
Luca
