Example of Matrix Multiplication(from cuda book) points that i dont anderstend ...
<img src=‘http://hqnveipbwb20/public/style_emoticons/<#EMO_DIR#>/crying.gif’ class=‘bbc_emoticon’ alt=‘:’(’ />
need help this is from the cuda book …
// Thread block size
#define BLOCK_SIZE 16
// Forward declaration of the device multiplication function
__global__ void Muld(float*, float*, int, int, float*);
// Host multiplication function
// Compute C = A * B
// hA is the height of A
// wA is the width of A
// wB is the width of B
void Mul(const float* A, const float* B, int hA, int wA, int wB,
float* C)
int size;
// Load A and B to the device
float* Ad;
size = hA * wA * sizeof(float);
cudaMalloc((void**)&Ad, size);
cudaMemcpy(Ad, A, size, cudaMemcpyHostToDevice);
float* Bd;
size = wA * wB * sizeof(float);
cudaMalloc((void**)&Bd, size);
cudaMemcpy(Bd, B, size, cudaMemcpyHostToDevice);
// Allocate C on the device
float* Cd;
size = hA * wB * sizeof(float);
cudaMalloc((void**)&Cd, size);
// Compute the execution configuration assuming
// the matrix dimensions are multiples of BLOCK_SIZE
dim3 dimBlock(BLOCK_SIZE, BLOCK_SIZE);
dim3 dimGrid(wB / dimBlock.x, hA / dimBlock.y);
// Launch the device computation
Muld<<<dimGrid, dimBlock>>>(Ad, Bd, wA, wB, Cd);
// Read C from the device
cudaMemcpy(C, Cd, size, cudaMemcpyDeviceToHost);
// Free device memory
cudaFree(Ad);
cudaFree(Bd);
cudaFree(Cd);
CUDA Programming Guide Version 1.1 69
Chapter 6. Example of Matrix Multiplication
// Device multiplication function called by Mul()
__global__ void Muld(float* A, float* B, int wA, int wB, float* C)
// Block index
int bx = blockIdx.x;
int by = blockIdx.y;
// Thread index
int tx = threadIdx.x;
int ty = threadIdx.y;
// Index of the first sub-matrix of A processed by the block
int aBegin = wA * BLOCK_SIZE * by;
// Index of the last sub-matrix of A processed by the block
int aEnd = aBegin + wA - 1;
// Step size used to iterate through the sub-matrices of A
int aStep = BLOCK_SIZE;
// Index of the first sub-matrix of B processed by the block
int bBegin = BLOCK_SIZE * bx;
// Step size used to iterate through the sub-matrices of B
int bStep = BLOCK_SIZE * wB;
// The element of the block sub-matrix that is computed
// by the thread
float Csub = 0;
// Loop over all the sub-matrices of A and B required to
// compute the block sub-matrix
for (int a = aBegin, b = bBegin;
a <= aEnd;
a += aStep, b += bStep) {
// Shared memory for the sub-matrix of A
__shared__ float As[BLOCK_SIZE][BLOCK_SIZE];
// Shared memory for the sub-matrix of B
__shared__ float Bs[BLOCK_SIZE][BLOCK_SIZE];
// Load the matrices from global memory to shared memory;
// each thread loads one element of each matrix
As[ty][tx] = A[a + wA * ty + tx];
Bs[ty][tx] = B[b + wB * ty + tx];
// Synchronize to make sure the matrices are loaded
__syncthreads();
// Multiply the two matrices together;
// each thread computes one element
// of the block sub-matrix
for (int k = 0; k < BLOCK_SIZE; ++k)
70 CUDA Programming Guide Version 1.1
Csub += As[ty][k] * Bs[k][tx];
// Synchronize to make sure that the preceding
// computation is done before loading two new
// sub-matrices of A and B in the next iteration
__syncthreads();
// Write the block sub-matrix to global memory;
// each thread writes one element
int c = wB * BLOCK_SIZE * by + BLOCK_SIZE * bx;
C[c + wB * ty + tx] = Csub;
i have A few questions
  1. int function Muld that go to the device we are initialize a array of
this is start in the loop and end with in the loop
a)when we do it on the loop block this memory start for all the threads in the same place(address) in the shared memory and finish after the loop start again ?
so this memory start and finish in the same loop for all the threads ?
b)for my understanding and according to the book and i quote
as i understand the 2 arrays have the same address ?
10X all …love you :wub:
im replying to all the posts
shared memory is the same memory for all threads in 1 block.
The arrays do not share the same memory, that is only true for extern shared memory. When using extern shared memory you have to make sure that you split up the block of memory in the right number of parts you need. The size is determined by the third parameter of your kernel call like this:
myKernel<<<blocks, threads, SHARED_MEMORY_SIZE>>>(params)
is the maximum that i am using
this need to be the
extern shared memory that i am declaring in the thread
shared memory that i declaring in the thread
is SHARED_MEMORY_SIZE from
if i am in the right way ? External Media
As far as I know not. You can have
shared float first[256];
extern__shared__ float second;
extern shared float third;
third = &second[128];
and call you kernel like mykernel<<<grid, threads, 512*sizeof(float)>>>
and you will have a first of size 256 and a second of size 512 (but you should only use the first 128, otherwise you overwrite the contents of third) and your third will then be 384 big.
You have to check in your host code if 256*sizeof(float) + the shared mem you allocate from the host with the kernel call, is not too large for your grid & threads dimensions. You can use the occupancy calculator beforehand to see what your limits are.
1)just to make sure that i understand.
__shared__ float first[256]; this is unattached
[/CODE]
but the
extern__shared__ float second[];
extern __shared__ float third[];
using the same memory address and the size is float(512-256) =float(256) .
like if i say that
second[x]=third[x]
that is &third=&second
:ph34r: this is right ?
2)if i doing something like that ?
__shared__ float forth[256]; this is unattached
this will work ?
External Image External Image External Image
You would have to check the programming guide, but I think the site is float(512), but second = third indeed
As far as I know yes.
