Execute multi GPU with nsys profile command but GPU may be locked
I’ve learned to leverage pytorch DDP and nccl backed to execute training on multi-gpu bit single node. Here is the tutorial and the python code
https://pytorch.org/tutorials/beginner/ddp_series_multigpu.html
import torch
import torch.nn.functional as F
from torch.utils.data import Dataset, DataLoader
from datautils import MyTrainDataset
import torch.multiprocessing as mp
from torch.utils.data.distributed import DistributedSampler
from torch.nn.parallel import DistributedDataParallel as DDP
from torch.distributed import init_process_group, destroy_process_group
import os
def ddp_setup(rank, world_size):
    Args:
        rank: Unique identifier of each process
        world_size: Total number of processes
    os.environ["MASTER_ADDR"] = "localhost"
    os.environ["MASTER_PORT"] = "12355"
    init_process_group(backend="nccl", rank=rank, world_size=world_size)
    torch.cuda.set_device(rank)
class Trainer:
    def __init__(
        self,
        model: torch.nn.Module,
        train_data: DataLoader,
        optimizer: torch.optim.Optimizer,
        gpu_id: int,
        save_every: int,
    ) -> None:
        self.gpu_id = gpu_id
        self.model = model.to(gpu_id)
        self.train_data = train_data
        self.optimizer = optimizer
        self.save_every = save_every
        self.model = DDP(model, device_ids=[gpu_id])
    def _run_batch(self, source, targets):
        self.optimizer.zero_grad()
        output = self.model(source)
        loss = F.cross_entropy(output, targets)
        loss.backward()
        self.optimizer.step()
    def _run_epoch(self, epoch):
        b_sz = len(next(iter(self.train_data))[0])
        print(f"[GPU{self.gpu_id}] Epoch {epoch} | Batchsize: {b_sz} | Steps: {len(self.train_data)}")
        self.train_data.sampler.set_epoch(epoch)
        for source, targets in self.train_data:
            source = source.to(self.gpu_id)
            targets = targets.to(self.gpu_id)
            self._run_batch(source, targets)
    def _save_checkpoint(self, epoch):
        ckp = self.model.module.state_dict()
        PATH = "checkpoint.pt"
        torch.save(ckp, PATH)
        print(f"Epoch {epoch} | Training checkpoint saved at {PATH}")
    def train(self, max_epochs: int):
        for epoch in range(max_epochs):
            self._run_epoch(epoch)
            if self.gpu_id == 0 and epoch % self.save_every == 0:
                self._save_checkpoint(epoch)
def load_train_objs():
    train_set = MyTrainDataset(2048)  # load your dataset
    model = torch.nn.Linear(20, 1)  # load your model
    optimizer = torch.optim.SGD(model.parameters(), lr=1e-3)
    return train_set, model, optimizer
def prepare_dataloader(dataset: Dataset, batch_size: int):
    return DataLoader(
        dataset,
        batch_size=batch_size,
        pin_memory=True,
        shuffle=False,
        sampler=DistributedSampler(dataset)
def main(rank: int, world_size: int, save_every: int, total_epochs: int, batch_size: int):
    dataset, model, optimizer = load_train_objs()
    train_data = prepare_dataloader(dataset, batch_size)
    trainer = Trainer(model, train_data, optimizer, rank, save_every)
    trainer.train(total_epochs)
    destroy_process_group()
if __name__ == "__main__":
    import argparse
    parser = argparse.ArgumentParser(description='simple distributed training job')
    parser.add_argument('total_epochs', type=int, help='Total epochs to train the model')
    parser.add_argument('save_every', type=int, help='How often to save a snapshot')
    parser.add_argument('--batch_size', default=32, type=int, help='Input batch size on each device (default: 32)')
    args = parser.parse_args()
    world_size = torch.cuda.device_count()
    mp.spawn(main, args=(world_size, args.save_every, args.total_epochs, args.batch_size), nprocs=world_size)
In my case, there are 2 GPUs in a node.
If I execute it through command python directly, I can see GPU0, GPU1 inter-execute
However, if I execute with nsys profile command, GPU0 or GPU1 won’t take turn until one GPU finished, another just can execute. It is like locking mechanism.
Does anyone know how to make GPU take turn to execute with nsys profile?
What version of Nsys? Are you running on a windows target or are you running on a linux target from a windows host?
What is the nsys command line you are using?
Hi hwiper,
Here is the version: 2024.4.1.61-244134315967v0
I ran on linux target directly, and used the command as below
nsys profile  python3 single_node_multi_gpu.py 50 10
The code of single_node_multi_gpu.py is the same as my post.
Thanks for your reply : )
@liuyis can you take a look at this?
Hi @smallhand, in fact GPU0 and GPU1 are still inter-executing when you run the script under Nsys. It is just the std outputs that are acting strangely.
If you check the Nsys report, you can find GPU0 and GPU1 are being used by two different processes spawned by Python:
When profiling Python scripts, Nsys has a limitation that it will delay all std outputs until the very end of the execution. Since the outputs for GPU0 and GPU1 are generated by different processes, all outputs for GPU0 are shown up first at the end, then GPU 1.
The limitation is documented in User Guide — nsight-systems 2024.4 documentation. As mentioned in the doc, one way to workaround it is to set the environment variable PYTHONUNBUFFERED. I’ve verified on my local system that setting it makes the issue go away - now std outputs look the same whether it’s profiled by Nsys or not. See my screenshots below.
Hi @liuyis , I got it. The explanation is very helpful. Thanks for replying in detail.
