Export: Not a valid identifier (Cuda environment setup)
Hi, I have trouble with the environment variables. Following the official guide, https://docs.nvidia.com/cuda/cuda-in…lation-actions
I added the cuda path to my ~/.bashrc file:
#CUDA
export PATH=/usr/local/cuda-10.1/bin:/usr/local/cuda-10.1/NsightCompute-2019.1${PATH:+:${PATH}}
export LD_LIBRARY_PATH=/usr/local/cuda/lib64\
                         ${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}
# added by Anaconda2 installer
export PATH="/home/veronica/anaconda2/bin:$PATH"
export CAFFE_ROOT=/home/veronica/caffe
export PYTHONPATH=/home/veronica/caffe/python:/home/veronica/anaconda2/bin/python
#export PYTHONPATH=/home/veronica/caffe/python:$PYTHONPATH
# add Bazel path
export PATH="$PATH:$HOME/bin"
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/lib/nvidia-418
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/home/veronica/.mujoco/mjpro150/bin
But, when I tried to make this file work:
$ source ~/.bashrc
bash: export: `:/usr/local/cuda-10.1/lib64:/usr/lib/nvidia-418:/home/veronica/.mujoco/mjpro150/bin': not a valid identifier
I am sure these folders all exist.
PS: “:/usr/lib/nvidia-418:/home/veronica/.mujoco/mjpro150/bin” could work well before I added cuda path.
I am looking forward your help. Thank you in advanced.
The backtick in front:
bash: export: `
doesn’t look right. I think there is something you’re not showing us. You have this:
but /usr/local/cuda/lib64 doesn’t show up in the problematic export:
bash: export: `:/usr/local/cuda-10.1/lib64:/usr/lib/nvidia-418:/home/veronica/.mujoco/mjpro150/bin’: not a valid identifier
a symbolic link (/usr/local/cuda) would not be converted to an actual path by the export command.
Thank you so much for your reply!
I am sorry I am new to Ubuntu and don’t know much about it. I don’t quite understand why does the backtick exist?
I can show you the completed version of my ~/.bashrc file:
# ~/bashrc: executed by bash(1) for non-login shells.
# see /usr/share/doc/bash/examples/startup-files (in the package bash-doc)
# for examples
# If not running interactively, don't do anything
case $- in
    *i*) ;;
      *) return;;
esac
# don't put duplicate lines or lines starting with space in the history.
# See bash(1) for more options
HISTCONTROL=ignoreboth
# append to the history file, don't overwrite it
shopt -s histappend
# for setting history length see HISTSIZE and HISTFILESIZE in bash(1)
HISTSIZE=1000
HISTFILESIZE=2000
# check the window size after each command and, if necessary,
# update the values of LINES and COLUMNS.
shopt -s checkwinsize
# If set, the pattern "**" used in a pathname expansion context will
# match all files and zero or more directories and subdirectories.
#shopt -s globstar
# make less more friendly for non-text input files, see lesspipe(1)
[ -x /usr/bin/lesspipe ] && eval "$(SHELL=/bin/sh lesspipe)"
# set variable identifying the chroot you work in (used in the prompt below)
if [ -z "${debian_chroot:-}" ] && [ -r /etc/debian_chroot ]; then
    debian_chroot=$(cat /etc/debian_chroot)
fi
# set a fancy prompt (non-color, unless we know we "want" color)
case "$TERM" in
    xterm-color|*-256color) color_prompt=yes;;
esac
# uncomment for a colored prompt, if the terminal has the capability; turned
# off by default to not distract the user: the focus in a terminal window
# should be on the output of commands, not on the prompt
#force_color_prompt=yes
if [ -n "$force_color_prompt" ]; then
    if [ -x /usr/bin/tput ] && tput setaf 1 >&/dev/null; then
	# We have color support; assume it's compliant with Ecma-48
	# (ISO/IEC-6429). (Lack of such support is extremely rare, and such
	# a case would tend to support setf rather than setaf.)
	color_prompt=yes
    else
	color_prompt=
    fi
fi
if [ "$color_prompt" = yes ]; then
    PS1='${debian_chroot:+($debian_chroot)}\[
for examples
If not running interactively, don’t do anything
case $- in
i) ;;
*) return;;
esac
don’t put duplicate lines or lines starting with space in the history.
append to the history file, don’t overwrite it
shopt -s histappend
HISTSIZE=1000
HISTFILESIZE=2000
If set, the pattern “**” used in a pathname expansion context will
#shopt -s globstar
[ -x /usr/bin/lesspipe ] && eval “$(SHELL=/bin/sh lesspipe)”
if [ -z “${debian_chroot:-}” ] && [ -r /etc/debian_chroot ]; then
fi
set a fancy prompt (non-color, unless we know we “want” color)
case “$TERM” in
esac
if [ -n “$force_color_prompt” ]; then
# We have color support; assume it’s compliant with Ecma-48
color_prompt=yes
else
color_prompt=
fi
fi
if [ “$color_prompt” = yes ]; then
PS1=‘${debian_chroot:+($debian_chroot)}[\033[01;32m]\u@\h[\033[00m]:[\033[01;34m]\w[\033[00m]$ ’
else
PS1=’${debian_chroot:+($debian_chroot)}\u@\h:\w$ ’
fi
unset color_prompt force_color_prompt
If this is an xterm set the title to user@host:dir
case “$TERM” in
xterm*|rxvt*)
PS1=“[\e]0;${debian_chroot:+($debian_chroot)}\u@\h: \w\a]$PS1”
esac
enable color support of ls and also add handy aliases
if [ -x /usr/bin/dircolors ]; then
test -r ~/.dircolors && eval “$(dircolors -b ~/.dircolors)” || eval “$(dircolors -b)”
alias ls=‘ls --color=auto’
#alias dir=‘dir --color=auto’
#alias vdir=‘vdir --color=auto’
alias grep='grep --color=auto'
alias fgrep='fgrep --color=auto'
alias egrep='egrep --color=auto'
fi
colored GCC warnings and errors
#export GCC_COLORS=‘error=01;31:warning=01;35:note=01;36:caret=01;32:locus=01:quote=01’
some more ls aliases
alias ll=‘ls -alF’
alias la=‘ls -A’
alias l=‘ls -CF’
Add an “alert” alias for long running commands. Use like so:
sleep 10; alert
alias alert=‘notify-send --urgency=low -i “$([ $? = 0 ] && echo terminal || echo error)” “$(history|tail -n1|sed -e ‘'‘s/^\s*[0-9]+\s*//;s/[;&|]\s*alert$//’'’)”’
Alias definitions.
You may want to put all your additions into a separate file like
~/.bash_aliases, instead of adding them here directly.
See /usr/share/doc/bash-doc/examples in the bash-doc package.
if [ -f ~/.bash_aliases ]; then
. ~/.bash_aliases
fi
enable programmable completion features (you don’t need to enable
this, if it’s already enabled in /etc/bash.bashrc and /etc/profile
sources /etc/bash.bashrc.)
if ! shopt -oq posix; then
if [ -f /usr/share/bash-completion/bash_completion ]; then
. /usr/share/bash-completion/bash_completion
elif [ -f /etc/bash_completion ]; then
. /etc/bash_completion
fi
fi
cuda
#export PATH=/usr/local/cuda-10.1/bin${PATH:+:${PATH}}
#export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/cuda-10.1/lib64
export LD_LIBRARY_PATH=/usr/local/cuda-10.1/lib64
#export LIBRARY_PATH=$LIBRARY_PATH:/usr/local/cuda-10.1/lib64${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}
#mujoco
#export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/home/veronica/.mujoco/mjpro150/bin
export PATH=“/home/veronica/anaconda2/bin:$PATH”
add Bazel path
export PATH=“$PATH:$HOME/bin”
33[01;32m\]\u@\h\[
for examples
case $- in
i) ;;
*) return;;
esac
shopt -s histappend
HISTSIZE=1000
HISTFILESIZE=2000
#shopt -s globstar
fi
case “$TERM” in
esac
color_prompt=yes
else
color_prompt=
fi
fi
else
fi
case “$TERM” in
xterm*|rxvt*)
esac
fi
alias ll=‘ls -alF’
alias la=‘ls -A’
alias l=‘ls -CF’
sleep 10; alert
Alias definitions.
. ~/.bash_aliases
fi
fi
fi
cuda
#mujoco
add Bazel path
33[00m\]:\[
for examples
case $- in
i) ;;
*) return;;
esac
shopt -s histappend
HISTSIZE=1000
HISTFILESIZE=2000
#shopt -s globstar
fi
case “$TERM” in
esac
color_prompt=yes
else
color_prompt=
fi
fi
else
fi
case “$TERM” in
xterm*|rxvt*)
esac
fi
alias ll=‘ls -alF’
alias la=‘ls -A’
alias l=‘ls -CF’
sleep 10; alert
Alias definitions.
. ~/.bash_aliases
fi
fi
fi
cuda
#mujoco
add Bazel path
33[01;34m\]\w\[
for examples
case $- in
i) ;;
*) return;;
esac
shopt -s histappend
HISTSIZE=1000
HISTFILESIZE=2000
#shopt -s globstar
fi
case “$TERM” in
esac
color_prompt=yes
else
color_prompt=
fi
fi
else
fi
case “$TERM” in
xterm*|rxvt*)
esac
fi
alias ll=‘ls -alF’
alias la=‘ls -A’
alias l=‘ls -CF’
sleep 10; alert
Alias definitions.
. ~/.bash_aliases
fi
fi
fi
cuda
#mujoco
add Bazel path
33[00m\]\$ '
else
    PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$ '
fi
# If this is an xterm set the title to user@host:dir
case "$TERM" in
xterm*|rxvt*)
    PS1="\[\e]0;${debian_chroot:+($debian_chroot)}\u@\h: \w\a\]$PS1"
esac
# enable color support of ls and also add handy aliases
    test -r ~/.dircolors && eval "$(dircolors -b ~/.dircolors)" || eval "$(dircolors -b)"
    alias ls='ls --color=auto'
    #alias dir='dir --color=auto'
    #alias vdir='vdir --color=auto'
fi
# colored GCC warnings and errors
#export GCC_COLORS='error=01;31:warning=01;35:note=01;36:caret=01;32:locus=01:quote=01'
# some more ls aliases
alias ll='ls -alF'
alias la='ls -A'
alias l='ls -CF'
# Add an "alert" alias for long running commands.  Use like so:
#   sleep 10; alert
alias alert='notify-send --urgency=low -i "$([ $? = 0 ] && echo terminal || echo error)" "$(history|tail -n1|sed -e '
And if I run $explore:
declare -x PATH=“/home/veronica/anaconda2/bin:/usr/local/cuda-10.1/bin:/usr/local/cuda-10.1/NsightCompute-2019.1:/home/veronica/anaconda2/bin:/usr/local/cuda-10.1/bin:/usr/local/cuda-10.1/NsightCompute-2019.1:/home/veronica/anaconda2/bin:/usr/local/cuda/bin:/usr/local/cuda-10.1/NsightCompute-2019.1:/home/veronica/.nix-profile/bin:/home/veronica/bin:/home/veronica/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/home/veronica/bin:/home/veronica/bin:/home/veronica/bin”
declare -x LD_LIBRARY_PATH=“/usr/local/cuda-10.1/lib64:/usr/lib/nvidia-418:/home/veronica/.mujoco/mjpro150/bin”
I really appreciate your help!'s/^\s*[0-9]\s*//;s/[;&|]\s*alert$//'
I really appreciate your help!')"'
# Alias definitions.
# You may want to put all your additions into a separate file like
# ~/.bash_aliases, instead of adding them here directly.
# See /usr/share/doc/bash-doc/examples in the bash-doc package.
    . ~/.bash_aliases
fi
# enable programmable completion features (you don't need to enable
# this, if it's already enabled in /etc/bash.bashrc and /etc/profile
# sources /etc/bash.bashrc.)
  fi
fi
#CUDA
export LD_LIBRARY_PATH=/usr/local/cuda-10.1/lib64\
#mujoco
# add Bazel path
declare -x PATH="/home/veronica/anaconda2/bin:/usr/local/cuda-10.1/bin:/usr/local/cuda-10.1/NsightCompute-2019.1:/home/veronica/anaconda2/bin:/usr/local/cuda-10.1/bin:/usr/local/cuda-10.1/NsightCompute-2019.1:/home/veronica/anaconda2/bin:/usr/local/cuda/bin:/usr/local/cuda-10.1/NsightCompute-2019.1:/home/veronica/.nix-profile/bin:/home/veronica/bin:/home/veronica/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/home/veronica/bin:/home/veronica/bin:/home/veronica/bin"
declare -x LD_LIBRARY_PATH="/usr/local/cuda-10.1/lib64:/usr/lib/nvidia-418:/home/veronica/.mujoco/mjpro150/bin"
