Does or has anyone been able to export and use the CSI CAM gpios? If so, what is their sysfs gpio number? I have checked the wiki on how to use GPIO, and it does claim that it is possible to use the CSI camera GPIOs if one decides not to use the CSI cameras. I have looked into the 5/1/2014 Jetson QA and some of the diffs for the Grinch Kernel and I have found nothing.
Uname -a
Linux tegra-ubuntu 3.10.24-grinch-19.3.7 #2 SMP PREEMPT Sat Nov 1 18:37:58 UTC 2014 armv7l armv7l armv7l GNU/Linux
I did some testing and discovered that with my current system PK1,PK2, and PK4 can be used as Outputs. GPIO_PH2 returns as busy. I cannot get PBB0-PBB7 to do anything (input or output). PCC1 and PCC2 work only as inputs. And it is already known that PH1, PU0-PU7 work as GPIOs.
