Is it possible to access CAM0_PWDN/CAM1_MCLK03 pins as GPIO on AGX Xavier?
I tried to access CAM0_PWDN/CAM1_MCLK03/DAP6_SCLK_PA0 pins as read/write GPIO pin, but got error message “bash: echo: write error: Invalid argument”
Here are the steps I did.
get pinmux number from AGX pinmux_confg=iguration file.
CAM0_PWDN — GPIO3_PH.06 – pin 62
CAM1_MCLK03 — EXTPERIPH2_CLK
DAP6_SCLK_PA0 — GPIO3.PA.01 – pin 1 -
echo 1 (62) > export – got error
error message
root@jetson-0423318034979:/sys/class/gpio# echo 1 > export
root@jetson-0423318034979:/sys/class/gpio# echo 62 > export
bash: echo: write error: Invalid argument -
the thing is echo 492 >export ok
ok message
root@jetson-0423318034979:/sys/class/gpio# echo 492 > export
root@jetson-0423318034979:/sys/class/gpio# cd gpio492
root@jetson-0423318034979:/sys/class/gpio/gpio492# ls
root@jetson-0423318034979:/sys/class/gpio/gpio492# echo out > direction
root@jetson-0423318034979:/sys/class/gpio/gpio492# echo 1 > value
root@jetson-0423318034979:/sys/class/gpio/gpio492# cat value
1
root@jetson-0423318034979:/sys/class/gpio/gpio492# echo 0 > value
0
Did I miss any?
Thank you for any advice.
