When I’m trying to use the ONNX model (generated using the export command) to generate a TensorRT engine, I encounter the following error:
My trtexec command:
/usr/src/tensorrt/bin/trtexec --onnx=/workspace/tao-experiments/SegFormer_TAO/SegFormer_newest_480x640.onnx --saveEngine=SegFormer_*engine.trt --minShapes=input:1x3x480x640 --optShapes=input:1x3x480x640 --maxShapes=input:1x3x480x640 --fp16 --workspace=2048
The error:
[08/22/2023-13:24:02] [E] Error[4]: [network.cpp::validate::3100] Error Code 4: Internal Error (input: for dimension number 2 in profile 0 does not match network definition (got min=480, opt=480, max=480), expected min=opt=max=1024).)
The tao export command seems to generate the ONNX file with the input dimensions as 1x3x1024x1024 by default. That’s why the trtexec operation doesn’t accept any different optimization profiles.
How can I customize the input dimensions during the generation of the ONNX file via export command? (I couldn’t see any description about this regarding the experiment spec file or command arguments.)
Thank you in advance.
atcnthn:
The error:
Could you upload the full log via below button ?
Also, can you share the training spec file when you train the segformer model?
Training spec file:
config_train.yaml (2.3 KB)
Export spec file:
config_export.yaml (1.8 KB)
trtexec log:
&&&& RUNNING TensorRT.trtexec [TensorRT v8503] # /usr/src/tensorrt/bin/trtexec --onnx=/workspace/tao-experiments/SegFormer_TAO/SegFormer_newest_480x640.onnx --saveEngine=SegFormer_*engine.trt --minShapes=input:1x3x480x640 --optShapes=input:1x3x480x640 --maxShapes=input:1x3x480x640 --fp16 --workspace=2048
[08/23/2023-05:25:29] [W] --workspace flag has been deprecated by --memPoolSize flag.
[08/23/2023-05:25:29] [I] === Model Options ===
[08/23/2023-05:25:29] [I] Format: ONNX
[08/23/2023-05:25:29] [I] Model: /workspace/tao-experiments/SegFormer_TAO/SegFormer_newest_480x640.onnx
[08/23/2023-05:25:29] [I] Output:
[08/23/2023-05:25:29] [I] === Build Options ===
[08/23/2023-05:25:29] [I] Max batch: explicit batch
[08/23/2023-05:25:29] [I] Memory Pools: workspace: 2048 MiB, dlaSRAM: default, dlaLocalDRAM: default, dlaGlobalDRAM: default
[08/23/2023-05:25:29] [I] minTiming: 1
[08/23/2023-05:25:29] [I] avgTiming: 8
[08/23/2023-05:25:29] [I] Precision: FP32+FP16
[08/23/2023-05:25:29] [I] LayerPrecisions:
[08/23/2023-05:25:29] [I] Calibration:
[08/23/2023-05:25:29] [I] Refit: Disabled
[08/23/2023-05:25:29] [I] Sparsity: Disabled
[08/23/2023-05:25:29] [I] Safe mode: Disabled
[08/23/2023-05:25:29] [I] DirectIO mode: Disabled
[08/23/2023-05:25:29] [I] Restricted mode: Disabled
[08/23/2023-05:25:29] [I] Build only: Disabled
[08/23/2023-05:25:29] [I] Save engine: SegFormer_*engine.trt
[08/23/2023-05:25:29] [I] Load engine:
[08/23/2023-05:25:29] [I] Profiling verbosity: 0
[08/23/2023-05:25:29] [I] Tactic sources: Using default tactic sources
[08/23/2023-05:25:29] [I] timingCacheMode: local
[08/23/2023-05:25:29] [I] timingCacheFile:
[08/23/2023-05:25:29] [I] Heuristic: Disabled
[08/23/2023-05:25:29] [I] Preview Features: Use default preview flags.
[08/23/2023-05:25:29] [I] Input(s)s format: fp32:CHW
[08/23/2023-05:25:29] [I] Output(s)s format: fp32:CHW
[08/23/2023-05:25:29] [I] Input build shape: input=1x3x480x640+1x3x480x640+1x3x480x640
[08/23/2023-05:25:29] [I] Input calibration shapes: model
[08/23/2023-05:25:29] [I] === System Options ===
[08/23/2023-05:25:29] [I] Device: 0
[08/23/2023-05:25:29] [I] DLACore:
[08/23/2023-05:25:29] [I] Plugins:
[08/23/2023-05:25:29] [I] === Inference Options ===
[08/23/2023-05:25:29] [I] Batch: Explicit
[08/23/2023-05:25:29] [I] Input inference shape: input=1x3x480x640
[08/23/2023-05:25:29] [I] Iterations: 10
[08/23/2023-05:25:29] [I] Duration: 3s (+ 200ms warm up)
[08/23/2023-05:25:29] [I] Sleep time: 0ms
[08/23/2023-05:25:29] [I] Idle time: 0ms
[08/23/2023-05:25:29] [I] Streams: 1
[08/23/2023-05:25:29] [I] ExposeDMA: Disabled
[08/23/2023-05:25:29] [I] Data transfers: Enabled
[08/23/2023-05:25:29] [I] Spin-wait: Disabled
[08/23/2023-05:25:29] [I] Multithreading: Disabled
[08/23/2023-05:25:29] [I] CUDA Graph: Disabled
[08/23/2023-05:25:29] [I] Separate profiling: Disabled
[08/23/2023-05:25:29] [I] Time Deserialize: Disabled
[08/23/2023-05:25:29] [I] Time Refit: Disabled
[08/23/2023-05:25:29] [I] NVTX verbosity: 0
[08/23/2023-05:25:29] [I] Persistent Cache Ratio: 0
[08/23/2023-05:25:29] [I] Inputs:
[08/23/2023-05:25:29] [I] === Reporting Options ===
[08/23/2023-05:25:29] [I] Verbose: Disabled
[08/23/2023-05:25:29] [I] Averages: 10 inferences
[08/23/2023-05:25:29] [I] Percentiles: 90,95,99
[08/23/2023-05:25:29] [I] Dump refittable layers:Disabled
[08/23/2023-05:25:29] [I] Dump output: Disabled
[08/23/2023-05:25:29] [I] Profile: Disabled
[08/23/2023-05:25:29] [I] Export timing to JSON file:
[08/23/2023-05:25:29] [I] Export output to JSON file:
[08/23/2023-05:25:29] [I] Export profile to JSON file:
[08/23/2023-05:25:29] [I] === Device Information ===
[08/23/2023-05:25:29] [I] Selected Device: Quadro RTX 4000
[08/23/2023-05:25:29] [I] Compute Capability: 7.5
[08/23/2023-05:25:29] [I] SMs: 36
[08/23/2023-05:25:29] [I] Compute Clock Rate: 1.545 GHz
[08/23/2023-05:25:29] [I] Device Global Memory: 7966 MiB
[08/23/2023-05:25:29] [I] Shared Memory per SM: 64 KiB
[08/23/2023-05:25:29] [I] Memory Bus Width: 256 bits (ECC disabled)
[08/23/2023-05:25:29] [I] Memory Clock Rate: 6.501 GHz
[08/23/2023-05:25:29] [I] TensorRT version: 8.5.3
[08/23/2023-05:25:29] [I] [TRT] [MemUsageChange] Init CUDA: CPU +14, GPU +0, now: CPU 30, GPU 429 (MiB)
[08/23/2023-05:25:31] [I] [TRT] [MemUsageChange] Init builder kernel library: CPU +342, GPU +76, now: CPU 426, GPU 495 (MiB)
[08/23/2023-05:25:31] [I] Start parsing network model
[08/23/2023-05:25:31] [I] [TRT] ----------------------------------------------------------------
[08/23/2023-05:25:31] [I] [TRT] Input filename: /workspace/tao-experiments/SegFormer_TAO/SegFormer_newest_480x640.onnx
[08/23/2023-05:25:31] [I] [TRT] ONNX IR version: 0.0.6
[08/23/2023-05:25:31] [I] [TRT] Opset version: 11
[08/23/2023-05:25:31] [I] [TRT] Producer name: pytorch
[08/23/2023-05:25:31] [I] [TRT] Producer version: 1.14.0
[08/23/2023-05:25:31] [I] [TRT] Domain:
[08/23/2023-05:25:31] [I] [TRT] Model version: 0
[08/23/2023-05:25:31] [I] [TRT] Doc string:
[08/23/2023-05:25:31] [W] [TRT] onnx2trt_utils.cpp:377: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[08/23/2023-05:25:34] [W] [TRT] Tensor DataType is determined at build time for tensors not marked as input or output.
[08/23/2023-05:25:34] [I] Finish parsing network model
[08/23/2023-05:25:34] [E] Error[4]: [network.cpp::validate::3100] Error Code 4: Internal Error (input: for dimension number 2 in profile 0 does not match network definition (got min=480, opt=480, max=480), expected min=opt=max=1024).)
[08/23/2023-05:25:34] [E] Error[2]: [builder.cpp::buildSerializedNetwork::751] Error Code 2: Internal Error (Assertion engine != nullptr failed. )
[08/23/2023-05:25:34] [E] Engine could not be created from network
[08/23/2023-05:25:34] [E] Building engine failed
[08/23/2023-05:25:34] [E] Failed to create engine from model or file.
[08/23/2023-05:25:34] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec [TensorRT v8503] # /usr/src/tensorrt/bin/trtexec --onnx=/workspace/tao-experiments/SegFormer_TAO/SegFormer_newest_480x640.onnx --saveEngine=SegFormer_*engine.trt --minShapes=input:1x3x480x640 --optShapes=input:1x3x480x640 --maxShapes=input:1x3x480x640 --fp16 --workspace=2048
system
Closed
September 6, 2023, 6:23am
7
