Extension 'omni.hello.world-1.0.0' is untrusted
when I followed the NVIDIA-Omniverse/kit-extension-template in Giuhub, I got an error:
Is there anybody who can help answer this question ?
Hi @shy0625. I’ll try to reproduce that on my end. Does it work if you add the path and enable the extension from the Extension Manager?
I ran it in a wrong path at first
The correct path should be:
D:\Finance_VA_Research\sunhy\4_omnikitextention\kit-extension-template> app\omni.code.bat --ext-folder exts --enable omni.hello.world
Then it works.
Thank you
