So I have an external HDMI display, and I can’t solve the tearing problem. I tried to enable V-Sync in Plasma settings and enabeling tripple buffering in KWin, but without any result.
nvidia-bug-report.log.gz (1.6 MB)
System: Host: localhost.localdomain Kernel: 5.14.14-1-default x86_64 bits: 64 Desktop: KDE Plasma 5.23.2
Distro: openSUSE Tumbleweed 20211101
Machine: Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec1xxx v: N/A serial: <superuser required>
Mobo: HP model: 87B1 v: 31.21 serial: <superuser required> UEFI: AMI v: F.20 date: 11/04/2020
Battery: ID-1: BAT0 charge: 46.9 Wh (100.0%) condition: 46.9/46.9 Wh (100.0%)
CPU: Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP cache: L2: 4 MiB
Speed: 2973 MHz min/max: 1400/2900 MHz Core speeds (MHz): 1: 2973 2: 2763 3: 2712 4: 2995 5: 1701 6: 1796 7: 2316
8: 2250 9: 2480 10: 2875 11: 3406 12: 3191 13: 3105 14: 2830 15: 1676 16: 1626
Graphics: Device-1: NVIDIA TU117M driver: nvidia v: 470.82.00
Device-2: Advanced Micro Devices [AMD/ATI] Renoir driver: amdgpu v: kernel
Device-3: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.13 driver: loaded: amdgpu,ati,nvidia unloaded: fbdev,modesetting,vesa resolution:
1: 1920x1080~60Hz 2: 1920x1080~60Hz
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.14.14-1-default LLVM 13.0.0) v: 4.6 Mesa 21.2.5
Audio: Device-1: NVIDIA driver: snd_hda_intel
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio driver: snd_hda_intel
Device-4: ESI Audiotechnik U22 XT USB type: USB driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.14.14-1-default running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.39 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: eno1 state: up speed: 100 Mbps duplex: full mac: 84:2a:fd:09:2d:40
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter driver: rtw_8822ce
IF: wlo1 state: down mac: 26:ea:40:5c:55:15
Bluetooth: Device-1: Realtek Bluetooth Radio type: USB driver: btusb
Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block: hardware: no software: no
address: 70:66:55:FA:5C:FC
Drives: Local Storage: total: 1.14 TiB used: 797.51 GiB (68.2%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB256HBHQ-000H1 size: 238.47 GiB
ID-2: /dev/sda vendor: Western Digital model: WD10SPSX-60A6WT0 size: 931.51 GiB
Partition: ID-1: / size: 75 GiB used: 65.9 GiB (87.9%) fs: btrfs dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 1022 MiB used: 324 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p1
ID-3: /home size: 162.47 GiB used: 121.47 GiB (74.8%) fs: btrfs dev: /dev/nvme0n1p3
ID-4: /opt size: 75 GiB used: 65.9 GiB (87.9%) fs: btrfs dev: /dev/nvme0n1p2
ID-5: /var size: 75 GiB used: 65.9 GiB (87.9%) fs: btrfs dev: /dev/nvme0n1p2
Swap: ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) dev: /dev/sda1
ID-2: swap-2 type: file size: 8 GiB used: 27.2 MiB (0.3%) file: /swap/swapfile
ID-3: swap-3 type: file size: 16 GiB used: 25.7 MiB (0.2%) file: /home/swap/swapfile
Sensors: System Temperatures: cpu: 73.4 C mobo: 71.0 C gpu: amdgpu temp: 47.0 C
Fan Speeds (RPM): N/A
Info: Processes: 439 Uptime: 1h 48m Memory: 14.98 GiB used: 7.06 GiB (47.1%) Shell: fish inxi: 3.3.07
