Goodnight:
I have tearing problems with my RTX 3060 mobile graphic, I use the Arch Linux operating system and I have the latest drivers available to date.
I have already placed a file in /etc/modprobe.d with the content options nvidia-drm modeset = 1 and confirmed that the query in / sys / module / nvidia_drm / parameters / modeset returns a Y so theoretically prime sync should be activated, however, I still keep tearing. Please if someone could give me a hand with my problem. Thanks a lot.
nvidia-bug-report.log.gz (339.9 KB)
[mario@Asus-Arch modprobe.d]$ neofetch
-` mario@Asus-Arch
.o+` ---------------
`ooo/ OS: Arch Linux x86_64
`+oooo: Host: ASUS TUF Gaming A15 FA506QM_FA50
`+oooooo: Kernel: 5.15.10-zen1-1-zen
-+oooooo+: Uptime: 23 mins
`/:-:++oooo+: Packages: 999 (pacman)
`/++++/+++++++: Shell: bash 5.1.12
`/++++++++++++++: Resolution: 1920x1080
`/+++ooooooooooooo/` DE: Cinnamon 5.0.7
./ooosssso++osssssso+` WM: Mutter (Muffin)
.oossssso-````/ossssss+` WM Theme: Mint-Y-Dark-Grey (Mint-Y)
-osssssso. :ssssssso. Theme: Mint-Y-Dark-Grey [GTK2/3]
:osssssss/ osssso+++. Icons: Papirus-Dark [GTK2/3]
/ossssssss/ +ssssooo/- Terminal: gnome-terminal
`/ossssso+/:- -:/+osssso+- CPU: AMD Ryzen 7 5800H with Radeon Gra
`+sso+:-` `.-/+oso: GPU: AMD ATI 05:00.0 Cezanne
`++:. `-/+/ GPU: NVIDIA GeForce RTX 3060 Mobile /
.` `/ Memory: 2740MiB / 23501MiB
[mario@Asus-Arch modprobe.d]$ sudo cat /sys/module/nvidia_drm/parameters/modeset
Y
[mario@Asus-Arch modprobe.d]$ dmesg | grep nvidia
[ 0.887171] nvidia: module license 'NVIDIA' taints kernel.
[ 0.935355] nvidia-nvlink: Nvlink Core is being initialized, major device number 511
[ 0.936230] nvidia 0000:01:00.0: enabling device (0000 -> 0003)
[ 0.936401] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 1.012607] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 1.053832] nvidia-uvm: Loaded the UVM driver, major device number 509.
[ 1.106939] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 495.46 Wed Oct 27 16:22:48 UTC 2021
[ 1.135734] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 2.428201] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
