I have a optimus laptop with fermi card (nvidia GT 540M)
On Ubuntu 20.04 with nvidia driver 390.132
Prime synchronization doesn’t work if i put options nvidia-drm modeset=1
in created conf file: /etc/modprobe.d/zz-nvidia-fix-tearing.conf
sudo cat /sys/module/nvidia_drm/parameters/modeset show Y
Still have an screen tearing problem. PRIME Synchronization doesn’t work.
Here a bug report nvidia-bug-report.log (569.2 KB)
PRIME sync has not yet been fixed with the 390 driver for kernels >=5.4. You can try the patch for the initial 440 driver that had the same issue. It applies to the 390 driver as well with some fuzz:
If that works, you could open a bug report at Ubuntu’s to include that patch until nvidia releases a fixed 390 driver.
Nope. Nvidia doesn’t have a fixed release cycle and also doesn’t ever announce anything. Updates for legacy drivers to support new kernels are handled rather lazy, leaving it to distributions to create/include the patches. Only support for new Xservers is a bit more reliable since that obviously can’t be patched by anyone else.
Did dkms install recompile the modules without error or did it just say “already installed”?
Please try removing and re-adding it:
sudo dkms remove nvidia/390.132 --all
sudo dkms install nvidia/390.132 --all
Furthermore, I suspect the old modules are still in the initrd, so run
sudo update-initramfs -u
afterwards.
Then I really wonder how that driver ended up on your harddisk in the first place. Please reinstall the driver
sudo apt install --reinstall nvidia-driver-390
and post the output of
ls -l /usr/src/nvidia-390.132
and
dkms status
afterwards.
Weird. Please install the dkms part manually
sudo apt install nvidia-dkms-390
and
dkms status
afterwards.
nvidia, 390.132, 5.4.0-29-generic, x86_64: installed (WARNING! Diff between built and installed module!) (WARNING! Diff between built and installed module!) (WARNING! Diff between built and installed module!)
ok, looks better. Now please check if the patch is still applied:
cd /usr/src/nvidia-390.132/
patch --dry-run -p2 < /path/to/patch.patch
If it then complains about “looks like a reverse patch”, the patch is still applied, then run
sudo dkms --force install nvidia/390.132
dkms status
