I’ve recently installed Linux Mint 19 Tara 64-bit, MATE 1.20.1.
I have the recommended Nvidia drivers 390.48-0ubuntu3.
While playing a video or scrolling down in Firefox, I see a tearing artifact in the upper half of the monitor. It really look like vsync is not active or maybe not fully active.
Tried to switch, but I get an answer:
Info: the NVIDIA profile is already set.
The screen tearing is still present, but it seems like the amount of the tearing was reduced, but it is still very visible in moving horizontally in scenes. I guess the changes I made following the threads from the links above helped with that.
I’ve also started a game to check which video adapter it is using, and it says OpenGL on Gt630M.
I have checked if I’m really using NVIDIA with glxinfo | grep vendor:
the result was:
jeanix@Jean-Lenovo-G580:~$ glxinfo | grep vendor
server glx vendor string: NVIDIA Corporation
client glx vendor string: NVIDIA Corporation
OpenGL vendor string: NVIDIA Corporation
In the directory /etc/modprobe.d/ I’ve created a file 99-prime-sync.conf containing
“options nvidia_390_drm modeset=1”
but I’m unable to run the command:
because of:
jeanix@Jean-Lenovo-G580:~$ nvidia-drm.modeset=1
nvidia-drm.modeset=1: command not found
and I guess that’s the reason why the command sudo update-initramfs -u don’t work.
I have also tried Chrome and the diagonal line while scrolling is also present. I wasn’t able to catch it with “PrintScreen”, but while fast scrolling, it seems that the line appear every time on the same place.
But the screen resolution went all down from 1366x768 to 1024x768.
Also, in the control panel as in the X Server Display Configuration are only 1360x768 and 1368x768 listed.
Starting any video or switching the browser to full-screen mode opens it only for the resolution 1024x768.
Is the any way to recover the native 1366x768 resolution?
That’s really odd. Please create a new nvidia-bug-report.log and attach that to your post. Hovering the mouse over an existing post will reveal a paperclip icon.
Added the line to /usr/share/X11/xorg.conf.d/10-nvidia.conf, saved and did a reboot.
The resolution hasn’t changed nor the 1366x768 resolution is present.
Odd. The problem is that the nvidia gpu detects a phantom vga monitor, happens sometimes, but the workaround of setting the option to ignore the crt doesn’t work. Might be a driver bug.
For another workaround, try running
I guess that command fixed it.
Now in the Monitor Preferences panel I have a Laptop LVDS-1-1 monitor and right next to it Unknown VGA-0 monitor.
The resolution is 1366x768, 60Hz.
And in the X-Server-Display Configuration is the resolution set to Auto, CRT-0 OFF.
I have also booted Kodi media center from the Linux login screen, not Mate. The resolution there was also broken and was 1024x768. I have changed in the preferences the monitor to LVDS-1-1 and the resolution fixed itself, but the screen went all white and impossible to work with, a reboot fixed that.
Now is everithing allright.
The screen tearing is now fully gone.
Thanks a lot for the help. ^_^
