External space in Jetson j1010
Hello everyone. I’m currently working on a Jetson nano reComputer j1010, which has 16GB of eemc storage. However, I’m facing a problem. After installing Ubuntu 18, upgrading to Ubuntu 20, and then installing Docker and ROS2 Humble, my storage space is currently very full. I want to install YOLO packages on it, but there isn’t enough space. I’ve looked at solutions like adding an SD card to increase the storage, but I’ve heard that it’s very slow to process. Does anyone have a solution?
Thanks for visiting the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I have moved this post for better visibility.
Cheers,
Tom
If don’t want to use larger SD card, then nvme is another choice. Thanks
