>>> from deepface.basemodels import FbDeepFace
2020-07-06 17:16:45.521514: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcudart.so.10.2
2020-07-06 17:16:51.077794: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libnvinfer.so.7
2020-07-06 17:16:51.127736: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libnvinfer_plugin.so.7
File "/usr/local/lib/python3.6/dist-packages/Keras-2.4.3-py3.6.egg/keras/__init__.py", line 3, in <module>
from tensorflow.keras.layers.experimental.preprocessing import RandomRotation
ImportError: cannot import name 'RandomRotation'
During handling of the above exception, another exception occurred:
File "<stdin>", line 1, in <module>
File "/usr/local/lib/python3.6/dist-packages/deepface-0.0.33-py3.6.egg/deepface/basemodels/FbDeepFace.py", line 4, in <module>
import keras
File "/usr/local/lib/python3.6/dist-packages/Keras-2.4.3-py3.6.egg/keras/__init__.py", line 6, in <module>
'Keras requires TensorFlow 2.2 or higher. '
ImportError: Keras requires TensorFlow 2.2 or higher. Install TensorFlow via `pip install tensorflow`
File "/usr/local/lib/python3.6/dist-packages/deepface-0.0.33-py3.6.egg/deepface/commons/functions.py", line 154, in get_opencv_path
raise ValueError("Confirm that opencv is installed on your environment! Expected path ",face_detector_path," violated.")
ValueError: ('Confirm that opencv is installed on your environment! Expected path ', '/usr/lib/python3/dist-packages/data/haarcascade_frontalface_default.xml', ' violated.')
