Hello, I am having some issues with the installation of Tensorflow on my Jetson Nano 4GB. I am running Jetpack 4.6.1 and followed a few forum posts on here to install Tensorflow 2.7.0+nv22.1, however when I try to import it into python I get the following error:
Python 3.6.9 (default, Mar 10 2023, 16:46:00)
[GCC 8.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import tensorflow
File "<stdin>", line 1, in <module>
File "/usr/local/lib/python3.6/dist-packages/tensorflow/__init__.py", line 41, in <module>
from tensorflow.python.tools import module_util as _module_util
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/__init__.py", line 49, in <module>
from tensorflow.python.feature_column import feature_column_lib as feature_column
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/feature_column/feature_column_lib.py", line 22, in <module>
from tensorflow.python.feature_column.feature_column import *
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/feature_column/feature_column.py", line 147, in <module>
from tensorflow.python.layers import base
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/layers/base.py", line 20, in <module>
from tensorflow.python.keras.legacy_tf_layers import base
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/keras/__init__.py", line 25, in <module>
from tensorflow.python.keras import models
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/keras/models.py", line 20, in <module>
from tensorflow.python.keras import metrics as metrics_module
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/keras/metrics.py", line 34, in <module>
from tensorflow.python.keras import activations
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/keras/activations.py", line 18, in <module>
from tensorflow.python.keras.layers import advanced_activations
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/keras/layers/__init__.py", line 29, in <module>
from tensorflow.python.keras.layers.preprocessing.image_preprocessing import CenterCrop
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/keras/layers/preprocessing/image_preprocessing.py", line 28, in <module>
from tensorflow.python.keras.preprocessing import image as image_preprocessing
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/keras/preprocessing/__init__.py", line 26, in <module>
from tensorflow.python.keras.utils import all_utils as utils
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/keras/utils/all_utils.py", line 34, in <module>
from tensorflow.python.keras.utils.multi_gpu_utils import multi_gpu_model
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/keras/utils/multi_gpu_utils.py", line 19, in <module>
from tensorflow.python.keras.engine.training import Model
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/keras/engine/training.py", line 52, in <module>
from tensorflow.python.keras.saving import hdf5_format
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/keras/saving/hdf5_format.py", line 37, in <module>
import h5py
File "/usr/local/lib/python3.6/dist-packages/h5py/__init__.py", line 45, in <module>
from ._conv import register_converters as _register_converters, \
File "h5py/h5t.pxd", line 15, in init h5py._conv
File "h5py/h5t.pyx", line 261, in init h5py.h5t
File "h5py/h5t.pyx", line 256, in h5py.h5t._get_available_ftypes
AttributeError: 'numpy.dtype' object has no attribute 'typeobj'
for reference, here are some of the relevant packages I have installed, hopefully this is enough info to solve the issue:
$ pip3 list
Package Version
Cython 0.26.1
h5py 3.1.0
keras 2.10.0
Keras-Applications 1.0.8
Keras-Preprocessing 1.1.2
matplotlib 2.1.1
numpy 1.19.4
pandas 0.22.0
Pillow 8.4.0
pip 21.3.1
protobuf 3.19.6
setuptools 59.6.0
tensorflow 2.7.0+nv22.1
tensorflow-estimator 2.8.0
