How to install Parallel HDF5 with Jetson Nano?
I have some problem when running tensorflow:
File “/usr/lib/python3.6/contextlib.py”, line 99, in exit
self.gen.throw(type, value, traceback)
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/ops.py”, line 5652, in get_controller
yield g
File “/home/jetsonnano2/Desktop/TTRobot_Proj_20200207/yolo.py”, line 70, in generate
self.yolo_model = load_model(model_path, compile=False)
File “/usr/local/lib/python3.6/dist-packages/keras/engine/saving.py”, line 458, in load_wrapper
return load_function(*args, **kwargs)
File “/usr/local/lib/python3.6/dist-packages/keras/engine/saving.py”, line 550, in load_model
model = _deserialize_model(h5dict, custom_objects, compile)
File “/usr/local/lib/python3.6/dist-packages/keras/engine/saving.py”, line 239, in _deserialize_model
model_config = h5dict[‘model_config’]
File “/usr/local/lib/python3.6/dist-packages/keras/utils/io_utils.py”, line 298, in getitem
elif attr in self.data:
File “h5py/_objects.pyx”, line 54, in h5py._objects.with_phil.wrapper
File “h5py/_objects.pyx”, line 55, in h5py._objects.with_phil.wrapper
File “/usr/local/lib/python3.6/dist-packages/h5py/_hl/group.py”, line 415, in contains
return self._e(name) in self.id
File “h5py/h5g.pyx”, line 461, in h5py.h5g.GroupID.contains
File “h5py/h5g.pyx”, line 462, in h5py.h5g.GroupID.contains
File “h5py/h5g.pyx”, line 531, in h5py.h5g._path_valid
File “h5py/h5l.pyx”, line 212, in h5py.h5l.LinkProxy.exists
KeyError: ‘Unable to get link info (bad symbol table node signature)’
During handling of the above exception, another exception occurred:
File “TTRobot2.0__with_APP.py”, line 557, in
table_locate = PP.yolo_predict(video,reffrence_frames)
File “/home/jetsonnano2/Desktop/TTRobot_Proj_20200207/PingPong_lib_yolo_v1.py”, line 86, in yolo_predict
yolo = YOLO()
File “/home/jetsonnano2/Desktop/TTRobot_Proj_20200207/yolo.py”, line 45, in init
self.boxes, self.scores, self.classes = self.generate()
File “/home/jetsonnano2/Desktop/TTRobot_Proj_20200207/yolo.py”, line 74, in generate
self.yolo_model.load_weights(self.model_path) # make sure model, anchors and classes match
File “/usr/local/lib/python3.6/dist-packages/keras/engine/network.py”, line 1217, in load_weights
f, self.layers, reshape=reshape)
File “/usr/local/lib/python3.6/dist-packages/keras/engine/saving.py”, line 1162, in load_weights_from_hdf5_group
g = f[name]
File “/usr/local/lib/python3.6/dist-packages/h5py/_hl/group.py”, line 264, in getitem
oid = h5o.open(self.id, self._e(name), lapl=self._lapl)
File “h5py/h5o.pyx”, line 190, in h5py.h5o.open
KeyError: ‘Unable to open object (bad symbol table node signature)’
Please try the following command to see if works:
sudo apt-get install libhdf5-serial-dev hdf5-tools
I have installed the package before, so it didn’t work.
Sorry for the late.
Maybe you can try to install parallel hdf5 from source.
This will require you to install MPI on Jetson first.
https://support.hdfgroup.org/ftp/HDF5/current/src/unpacked/release_docs/INSTALL_parallel
