Fail to create a surface gripper fully on code following the documentation
Isaac Sim Version
[√] 4.5.0
Operating System
[√] Windows 11
[√] Windows 10
Topic Description
Detailed Description
Hi, I want to create a surface gripper fully on code and I am following the documentation :
async def _create_scenario(self, task):
    # Create the Gripper Properties
    self.sgp = Surface_Gripper_Properties()
    self.sgp.d6JointPath = ""
    self.sgp.parentPath = "/GripperCone"                # Set the Cone as the parent object
    self.sgp.offset = dc.Transform()                    # Offset the transform to the base of the Cone
    self.sgp.offset.p.x = 0
    self.sgp.offset.p.z = -0.1001                       # Offset the transform to the base of the Cone
    self.sgp.offset.r = [0.7171, 0, 0.7171, 0]          # Rotate to point gripper in Z direction
    self.sgp.gripThreshold = 0.02                       # Set attachment to within 2cm of the base of the Cone
    self.sgp.forceLimit = 1.0e2                         # Set other limits of the gripper ...
    self.sgp.torqueLimit = 1.0e3
    self.sgp.bendAngle = np.pi / 4
    self.sgp.stiffness = 1.0e4
    self.sgp.damping = 1.0e3
    self.sgp.retryClose = False                         # If set to True, surface gripper will keep trying to close until it picks up an object
    self.surface_gripper = Surface_Gripper(self._dc)    # Create the Gripper
    self.surface_gripper.initialize(self.sgp)           # Initialize the Gripper with these Properties
I am new to Isaac Sim so I am not sure what is dc in dc.Transform(). But I assume it is related to dynamic_control. So I wrote my code as shown below to initialize the surface gripper:
from isaacsim.robot.surface_gripper._surface_gripper import Surface_Gripper, Surface_Gripper_Properties
from omni.isaac.dynamic_control import _dynamic_control
dc = _dynamic_control.acquire_dynamic_control_interface()
gripper_properties = Surface_Gripper_Properties()
gripper = Surface_Gripper(dc)
gripper_properties.forceLimit = 100
gripper_properties.gripThreshold = 0.01
tr = omni.physics.tensors.Transform()
tr.p.y = 0.251000
tr.r.x = 0.0
tr.r.y = 0.70710678
tr.r.z = 0.0
tr.r.w = 0.70710678
gripper_properties.offset = tr
gripper_properties.parentPath = "/World/Gripper"
gripper.initialize(gripper_properties)
and got the error.
I know the Surface_Gripper() constructor doesn’t actually accept any parameters from surface_gripper’s API. So I wonder why in the documentation, the Surface_Gripper is construct with the parameter “self._dc”. Or do I understand the dc completely wrong?
Error Messages
2025-04-22 09:24:45 [12,899ms] [Error] [omni.kit.app._impl] [py stderr]: Traceback (most recent call last):
2025-04-22 09:24:45 [12,899ms] [Error] [omni.kit.app._impl] [py stderr]: File “c:\isaacsim\control_cone_gripper.py”, line 44, in
2025-04-22 09:24:45 [12,900ms] [Error] [omni.kit.app._impl] [py stderr]: gripper = Surface_Gripper(dc)
2025-04-22 09:24:45 [12,900ms] [Error] [omni.kit.app._impl] [py stderr]: TypeError: init(): incompatible constructor arguments. The following argument types are supported:
1. isaacsim.robot.surface_gripper._surface_gripper.Surface_Gripper()
Invoked with: <omni.isaac.dynamic_control._dynamic_control.DynamicControl object at 0x000001B42C1E46B0>
I checked the source code of the surface gripper extension, and it seems like the code in the documentation wasn’t updated.
@terence0tan i am just another user and haven’t worked with gripper, but i wonder if it’s at all related to the deprecation of dynamic control extension altogether since 4.5.0:
[omni.isaac.dynamic_control] Isaac Sim Dynamic Control — Isaac Sim
perhaps the devs/mods can elaborate on this and/or provide a solution.
Thanks for the notice. And yes, you are right. The source code of the previous software version can prove that.
