Hi, i am trying to using Jetson Nano and watching Nvidia tutorial about training object detection with ssd model but get stuck when installed pytorch using this as instructions https://github.com/dusty-nv/jetson-inference/blob/master/docs/pytorch-transfer-learning.md#installing-pytorch
I am already reinstall os with newest version and repeat the step but still get same result, can anyone help me?
Hi @TrickyCV, what is the error you are getting, and which version of JetPack-L4T are you using?
You could also try running the jetson-inference docker container which already has PyTorch installed in it: https://github.com/dusty-nv/jetson-inference/blob/master/docs/aux-docker.md
Here the error msg, and the version of jetpack is 4.6.1-b110
this after i do sudo update & upgrade and installing jetson-inference after reinstall os
Hmm, ok interesting - can you try running pip3 install setuptools first?
Still get error msg, after do pip3 install
Hmm, not sure why this script is still making errors for you, sorry about that - next please try pip3 install 'Cython<3'
You can also use the jetson-inference docker container which has PyTorch, or see the instructions for manually installing PyTorch here:
Hi, @dusty_nv , thanks for solution and answer so quickly. And how to load the onnx custom model into script object detecting script?
No problem @TrickyCV - first, make sure that detectnet/detectnet.py can load your custom ssd-mobilenet.onnx model from the command-line like here:
https://github.com/dusty-nv/jetson-inference/blob/master/docs/pytorch-ssd.md#processing-images-with-tensorrt
Then, you can create your own version of detectnet.py that loads a custom model using the parameterized API instead:
