In order to get CUDA installed, I had to install it through sdk manager, which fails to install every time.
SDKM_logs_JetPack_4.4_Linux_for_Jetson_Nano_[developer_kit_version]_2020-10-18_17-06-07.zip (1.4 MB)
Hi kubaixixel,
What’s the file system format of /media/kuba/sdjf/2/? You could check this by running “mount | grep /media” command. The expected file system format is ext4.
Hi kubaixixel,
Have you managed to get SDKM and CUDA installed successfully?
Any result can be shared?
Yeah, unfortunatelly not, but I seems, that just using iso image installs cuda fine for me.
