I'm trying on Win10 (through MinGW64) to convert (mixing mode) from x265 file (by CPU) to x264 (by GPU - NVidia) resizing the output using scale_npp.
What means last 5 rows on this logs?
tnx!
$ ffmpeg -i /i/_wip/xxxxxxxxxxxxxxx.MULTI.1080p.BDRip.x265.10bit.AAC.2.0.Subs.Fr.Eng.mkv -c:v h264_nvenc -an -vf "fade,hwupload_cuda,scale_npp=304:120" -pix_fmt yuv420p -preset fast /i/_wip/test1_output_h264.mp4
ffmpeg version N-98027-g89328022be-g6cd198860d+3 Copyright (c) 2000-2020 the FFmpeg developers
built with gcc 10.1.0 (Rev3, Built by MSYS2 project)
configuration: --cc='ccache gcc' --cxx='ccache g++' --disable-autodetect --enable-bzlib --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-iconv --enable-lzma --enable-nvenc --enable-zlib --enable-sdl2 --
enable-ffnvcodec --enable-nvdec --enable-cuda-llvm --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libx265 --enable-libdav1d --disable-debug --enable-fontconfig --enable-libass
--enable-libbluray --enable-libfreetype --enable-libmysofa --enable-libopencore-amrnb --enable-libopenjpeg --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --ena
ble-libvo-amrwbenc --enable-libwavpack --enable-libwebp --enable-libxml2 --enable-libzimg --enable-libshine --enable-gpl --enable-avisynth --enable-libxvid --enable-libopenmpt --enable-version3 --enable-decklink --enable-frei0
r --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libfdk-aac --enable-libflite --enable-libfribidi --enable-libgsm --enable-libilbc --enable-libsvthevc --enable-libsvtav1 --enable-libkvazaar --enable-libmodplug --e
nable-librtmp --enable-librubberband --enable-libtesseract --enable-libxavs --enable-libzmq --enable-libzvbi --enable-openal --enable-libvmaf --enable-libsrt --enable-ladspa --enable-librav1e --enable-opencl --enable-opengl --
enable-libnpp --enable-libopenh264 --enable-openssl --extra-cflags=-fopenmp --extra-libs=-lgomp --extra-cflags=-DLIBTWOLAME_STATIC --extra-libs=-lstdc++ --extra-cflags=-DCACA_STATIC --extra-cflags=-DMODPLUG_STATIC --extra-cfla
gs=-DZMQ_STATIC --extra-libs=-lpsapi --extra-cflags=-DLIBXML_STATIC --extra-libs=-liconv --disable-w32threads --extra-cflags=-DKVZ_STATIC_LIB --enable-nonfree --extra-cflags='-IC:/PROGRA~1/NVIDIA~2/CUDA/v10.2/include' --extra-
ldflags='-LC:/PROGRA~1/NVIDIA~2/CUDA/v10.2/lib/x64'
libavutil 56. 49.100 / 56. 49.100
libavcodec 58. 90.100 / 58. 90.100
libavformat 58. 44.100 / 58. 44.100
libavdevice 58. 9.103 / 58. 9.103
libavfilter 7. 84.100 / 7. 84.100
libswscale 5. 6.101 / 5. 6.101
libswresample 3. 6.100 / 3. 6.100
libpostproc 55. 6.100 / 55. 6.100
[matroska,webm @ 000001b7772d1980] Could not find codec parameters for stream 3 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
Consider increasing the value for the 'analyzeduration' and 'probesize' options
[matroska,webm @ 000001b7772d1980] Could not find codec parameters for stream 4 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
Input #0, matroska,webm, from 'I:/_wip/xxxxxxxxxxxxxxx.MULTI.1080p.BDRip.x265.10bit.AAC.2.0.Subs.Fr.Eng.mkv':
Metadata:
title : xxxxxxxxxxxxxxx
creation_time : 2019-06-25T20:17:47.000000Z
ENCODER : Lavf58.20.100
Duration: 01:37:41.93, start: 0.000000, bitrate: 3252 kb/s
Chapter #0:0: start 0.000000, end 438.605000
Metadata:
title : Chapter 1
Chapter #0:1: start 438.605000, end 833.583000
Metadata:
title : Chapter 2
Chapter #0:2: start 833.583000, end 1216.132000
Metadata:
title : Chapter 3
Chapter #0:3: start 1216.132000, end 1791.957000
Metadata:
title : Chapter 4
Chapter #0:4: start 1791.957000, end 1980.770000
Metadata:
title : Chapter 5
Chapter #0:5: start 1980.770000, end 2405.445000
Metadata:
title : Chapter 6
Chapter #0:6: start 2405.445000, end 3057.471000
Metadata:
title : Chapter 7
Chapter #0:7: start 3057.471000, end 3207.746000
Metadata:
title : Chapter 8
Chapter #0:8: start 3207.746000, end 3459.498000
Metadata:
title : Chapter 9
Chapter #0:9: start 3459.498000, end 3890.637000
Metadata:
title : Chapter 10
Chapter #0:10: start 3890.637000, end 4276.230000
Metadata:
title : Chapter 11
Chapter #0:11: start 4276.230000, end 4452.531000
Metadata:
title : Chapter 12
Chapter #0:12: start 4452.531000, end 5032.653000
Metadata:
title : Chapter 13
Chapter #0:13: start 5032.653000, end 5468.797000
Metadata:
title : Chapter 14
Chapter #0:14: start 5468.797000, end 5650.311000
Metadata:
title : Chapter 15
Chapter #0:15: start 5650.311000, end 5861.856000
Metadata:
title : Chapter 16
Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv, bt709), 1920x816 [SAR 1:1 DAR 40:17], 23.98 fps, 23.98 tbr, 1k tbn, 23.98 tbc (default)
Metadata:
BPS-eng : 2786523
DURATION-eng : 01:37:41.898000000
NUMBER_OF_FRAMES-eng: 140545
NUMBER_OF_BYTES-eng: 2041789311
_STATISTICS_WRITING_APP-eng: mkvmerge v35.0.0 ('All The Love In The World') 64-bit
_STATISTICS_WRITING_DATE_UTC-eng: 2019-06-25 20:17:47
_STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Stream #0:1(fre): Audio: aac (LC), 48000 Hz, stereo, fltp (default)
Metadata:
title : Stereo
BPS-eng : 223312
DURATION-eng : 01:37:41.930000000
NUMBER_OF_FRAMES-eng: 274778
NUMBER_OF_BYTES-eng: 163630473
Stream #0:2(eng): Audio: aac (LC), 48000 Hz, stereo, fltp
Metadata:
title : Stereo
BPS-eng : 224125
DURATION-eng : 01:37:41.909000000
NUMBER_OF_FRAMES-eng: 274777
NUMBER_OF_BYTES-eng: 164225325
Stream #0:3(fre): Subtitle: hdmv_pgs_subtitle (default)
Metadata:
title : PGS Français
BPS-eng : 24760
DURATION-eng : 01:32:42.098000000
NUMBER_OF_FRAMES-eng: 1436
NUMBER_OF_BYTES-eng: 17214937
Stream #0:4(eng): Subtitle: hdmv_pgs_subtitle
Metadata:
title : PGS English
BPS-eng : 27266
DURATION-eng : 01:32:44.475000000
NUMBER_OF_FRAMES-eng: 1948
NUMBER_OF_BYTES-eng: 18965232
Stream #0:5(fre): Subtitle: subrip
Metadata:
title : SRT Français
BPS-eng : 42
NUMBER_OF_FRAMES-eng: 718
NUMBER_OF_BYTES-eng: 29370
Stream #0:6(eng): Subtitle: subrip
Metadata:
title : SRT English
BPS-eng : 42
NUMBER_OF_FRAMES-eng: 974
NUMBER_OF_BYTES-eng: 29727
Stream mapping:
Stream #0:0 -> #0:0 (hevc (native) -> h264 (h264_nvenc))
Press [q] to stop, [?] for help
**Impossible to convert between the formats supported by the filter 'Parsed_scale_npp_2' and the filter 'auto_scaler_1'
Error reinitializing filters!
Failed to inject frame into filter network: Function not implemented
Error while processing the decoded data for stream #0:0
Conversion failed!**
