Hello, I am new in nvidia orin nx.
My nx jetpack version is: 6.0
I am using python moviepy which I want to use ffnvvodec to accelerate Editing. I have installed it from
https://git.videolan.org/git/ffmpeg/nv-codec-headers.git
And after I install the specific ffmpeg using
./configure --enable-gpl --enable-libx264 --enable-nonfree --enable-libnpp --enable-cuda --enable-cuvid --enable-nvenc --extra-cflags=-I/usr/local/cuda/include --extra-ldflags=-L/usr/local/cuda/lib64 --prefix=/usr/local/ffmpeg
There are some errors:
ERROR: cuda requested, but not all dependencies are satisfied: ffnvcodec
Do you know how to fix this problem?
Thanks a lot.
Not sur but the package may be for x86 machine. You may check the steps in FAQ and try:
Jetson AGX Orin FAQ
Hello, I would like to install ffmpeg that can use hardware encoding, such as Invenc. How do I install it??
There are only these now
ids@ids-desktop:~$ ffmpeg -encoders
ffmpeg version n4.2.7-24-gd796def2ea-1ubuntu0.1 Copyright (c) 2000-2022 the FFmpeg developers
built with gcc 9 (Ubuntu 9.4.0-1ubuntu1~20.04.2)
configuration: --prefix=/usr --enable-nvv4l2dec --enable-libv4l2 --enable-shared --extra-libs='-L/usr/lib/aarch64-linux-gnu/tegra -lv4l2 -lnvbufsurface -lnvbufsurftransform' --extra-cflags=-I/usr/src/jetson_multimedia_api/include/ --extra-version=1ubuntu0.1 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --arch=arm64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
libavutil 56. 31.100 / 56. 31.100
libavcodec 58. 54.100 / 58. 54.100
libavformat 58. 29.100 / 58. 29.100
libavdevice 58. 8.100 / 58. 8.100
libavfilter 7. 57.100 / 7. 57.100
libavresample 4. 0. 0 / 4. 0. 0
libswscale 5. 5.100 / 5. 5.100
libswresample 3. 5.100 / 3. 5.100
libpostproc 55. 5.100 / 55. 5.100
Encoders:
V..... = Video
A..... = Audio
S..... = Subtitle
.F.... = Frame-level multithreading
..S... = Slice-level multithreading
...X.. = Codec is experimental
....B. = Supports draw_horiz_band
.....D = Supports direct rendering method 1
V..... a64multi Multicolor charset for Commodore 64 (codec a64_multi)
V..... a64multi5 Multicolor charset for Commodore 64, extended with 5th color (colram) (codec a64_multi5)
V..... alias_pix Alias/Wavefront PIX image
V..... amv AMV Video
V..... apng APNG (Animated Portable Network Graphics) image
V..... asv1 ASUS V1
V..... asv2 ASUS V2
V..X.. libaom-av1 libaom AV1 (codec av1)
V..... avrp Avid 1:1 10-bit RGB Packer
V..X.. avui Avid Meridien Uncompressed
V..... ayuv Uncompressed packed MS 4:4:4:4
V..... bmp BMP (Windows and OS/2 bitmap)
V..... cinepak Cinepak
V..... cljr Cirrus Logic AccuPak
V.S... vc2 SMPTE VC-2 (codec dirac)
VFS... dnxhd VC3/DNxHD
V..... dpx DPX (Digital Picture Exchange) image
VFS... dvvideo DV (Digital Video)
V.S... ffv1 FFmpeg video codec #1
VF.... ffvhuff Huffyuv FFmpeg variant
V..... fits Flexible Image Transport System
V..... flashsv Flash Screen Video
V..... flashsv2 Flash Screen Video Version 2
V..... flv FLV / Sorenson Spark / Sorenson H.263 (Flash Video) (codec flv1)
V..... gif GIF (Graphics Interchange Format)
V..... h261 H.261
V..... h263 H.263 / H.263-1996
V..... h263_v4l2m2m V4L2 mem2mem H.263 encoder wrapper (codec h263)
V.S... h263p H.263+ / H.263-1998 / H.263 version 2
V..... libx264 libx264 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (codec h264)
V..... libx264rgb libx264 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 RGB (codec h264)
V..... h264_omx OpenMAX IL H.264 video encoder (codec h264)
V..... h264_v4l2m2m V4L2 mem2mem H.264 encoder wrapper (codec h264)
V..... hap Vidvox Hap
V..... libx265 libx265 H.265 / HEVC (codec hevc)
V..... hevc_v4l2m2m V4L2 mem2mem HEVC encoder wrapper (codec hevc)
VF.... huffyuv Huffyuv / HuffYUV
V..... jpeg2000 JPEG 2000
VF.... libopenjpeg OpenJPEG JPEG 2000 (codec jpeg2000)
VF.... jpegls JPEG-LS
VF.... ljpeg Lossless JPEG
VF.... magicyuv MagicYUV video
VFS... mjpeg MJPEG (Motion JPEG)
V.S... mpeg1video MPEG-1 video
V.S... mpeg2video MPEG-2 video
V.S... mpeg4 MPEG-4 part 2
V..... libxvid libxvidcore MPEG-4 part 2 (codec mpeg4)
V..... mpeg4_v4l2m2m V4L2 mem2mem MPEG4 encoder wrapper (codec mpeg4)
V..... msmpeg4v2 MPEG-4 part 2 Microsoft variant version 2
V..... msmpeg4 MPEG-4 part 2 Microsoft variant version 3 (codec msmpeg4v3)
V..... msvideo1 Microsoft Video-1
V..... pam PAM (Portable AnyMap) image
V..... pbm PBM (Portable BitMap) image
V..... pcx PC Paintbrush PCX image
V..... pgm PGM (Portable GrayMap) image
V..... pgmyuv PGMYUV (Portable GrayMap YUV) image
VF.... png PNG (Portable Network Graphics) image
V..... ppm PPM (Portable PixelMap) image
VF.... prores Apple ProRes
VF.... prores_aw Apple ProRes (codec prores)
VFS... prores_ks Apple ProRes (iCodec Pro) (codec prores)
V..... qtrle QuickTime Animation (RLE) video
V..... r10k AJA Kona 10-bit RGB Codec
V..... r210 Uncompressed RGB 10-bit
V..... rawvideo raw video
V..... roqvideo id RoQ video (codec roq)
V..... rv10 RealVideo 1.0
V..... rv20 RealVideo 2.0
V..... sgi SGI image
V..... snow Snow
V..... sunrast Sun Rasterfile image
V..... svq1 Sorenson Vector Quantizer 1 / Sorenson Video 1 / SVQ1
V..... targa Truevision Targa image
V..... libtheora libtheora Theora (codec theora)
VF.... tiff TIFF image
VF.... utvideo Ut Video
V..... v210 Uncompressed 4:2:2 10-bit
V..... v308 Uncompressed packed 4:4:4
V..... v408 Uncompressed packed QT 4:4:4:4
V..... v410 Uncompressed 4:4:4 10-bit
V..... libvpx libvpx VP8 (codec vp8)
V..... vp8_v4l2m2m V4L2 mem2mem VP8 encoder wrapper (codec vp8)
V..... libvpx-vp9 libvpx VP9 (codec vp9)
V..... libwebp_anim libwebp WebP image (codec webp)
V..... libwebp libwebp WebP image (codec webp)
V..... wmv1 Windows Media Video 7
V..... wmv2 Windows Media Video 8
V..... wrapped_avframe AVFrame to AVPacket passthrough
V..... xbm XBM (X BitMap) image
V..... xface X-face image
V..... xwd XWD (X Window Dump) image
V..... y41p Uncompressed YUV 4:1:1 12-bit
V..... yuv4 Uncompressed packed 4:2:0
VF.... zlib LCL (LossLess Codec Library) ZLIB
V..... zmbv Zip Motion Blocks Video
A..... aac AAC (Advanced Audio Coding)
A..... ac3 ATSC A/52A (AC-3)
A..... ac3_fixed ATSC A/52A (AC-3) (codec ac3)
A..... adpcm_adx SEGA CRI ADX ADPCM
A..... g722 G.722 ADPCM (codec adpcm_g722)
A..... g726 G.726 ADPCM (codec adpcm_g726)
A..... g726le G.726 little endian ADPCM ("right-justified") (codec adpcm_g726le)
A..... adpcm_ima_qt ADPCM IMA QuickTime
A..... adpcm_ima_wav ADPCM IMA WAV
A..... adpcm_ms ADPCM Microsoft
A..... adpcm_swf ADPCM Shockwave Flash
A..... adpcm_yamaha ADPCM Yamaha
A..... alac ALAC (Apple Lossless Audio Codec)
A..... aptx aptX (Audio Processing Technology for Bluetooth)
A..... aptx_hd aptX HD (Audio Processing Technology for Bluetooth)
A..... libcodec2 codec2 encoder using libcodec2 (codec codec2)
A..... comfortnoise RFC 3389 comfort noise generator
A..X.. dca DCA (DTS Coherent Acoustics) (codec dts)
A..... eac3 ATSC A/52 E-AC-3
A..... flac FLAC (Free Lossless Audio Codec)
A..... g723_1 G.723.1
A..... libgsm libgsm GSM (codec gsm)
A..... libgsm_ms libgsm GSM Microsoft variant (codec gsm_ms)
A..X.. mlp MLP (Meridian Lossless Packing)
A..... mp2 MP2 (MPEG audio layer 2)
A..... mp2fixed MP2 fixed point (MPEG audio layer 2) (codec mp2)
A..... libtwolame libtwolame MP2 (MPEG audio layer 2) (codec mp2)
A..... libmp3lame libmp3lame MP3 (MPEG audio layer 3) (codec mp3)
A..... libshine libshine MP3 (MPEG audio layer 3) (codec mp3)
A..... nellymoser Nellymoser Asao
A..X.. opus Opus
A..... libopus libopus Opus (codec opus)
A..... pcm_alaw PCM A-law / G.711 A-law
A..... pcm_dvd PCM signed 16|20|24-bit big-endian for DVD media
A..... pcm_f32be PCM 32-bit floating point big-endian
A..... pcm_f32le PCM 32-bit floating point little-endian
A..... pcm_f64be PCM 64-bit floating point big-endian
A..... pcm_f64le PCM 64-bit floating point little-endian
A..... pcm_mulaw PCM mu-law / G.711 mu-law
A..... pcm_s16be PCM signed 16-bit big-endian
A..... pcm_s16be_planar PCM signed 16-bit big-endian planar
A..... pcm_s16le PCM signed 16-bit little-endian
A..... pcm_s16le_planar PCM signed 16-bit little-endian planar
A..... pcm_s24be PCM signed 24-bit big-endian
A..... pcm_s24daud PCM D-Cinema audio signed 24-bit
A..... pcm_s24le PCM signed 24-bit little-endian
A..... pcm_s24le_planar PCM signed 24-bit little-endian planar
A..... pcm_s32be PCM signed 32-bit big-endian
A..... pcm_s32le PCM signed 32-bit little-endian
A..... pcm_s32le_planar PCM signed 32-bit little-endian planar
A..... pcm_s64be PCM signed 64-bit big-endian
A..... pcm_s64le PCM signed 64-bit little-endian
A..... pcm_s8 PCM signed 8-bit
A..... pcm_s8_planar PCM signed 8-bit planar
A..... pcm_u16be PCM unsigned 16-bit big-endian
A..... pcm_u16le PCM unsigned 16-bit little-endian
A..... pcm_u24be PCM unsigned 24-bit big-endian
A..... pcm_u24le PCM unsigned 24-bit little-endian
A..... pcm_u32be PCM unsigned 32-bit big-endian
A..... pcm_u32le PCM unsigned 32-bit little-endian
A..... pcm_u8 PCM unsigned 8-bit
A..... pcm_vidc PCM Archimedes VIDC
A..... real_144 RealAudio 1.0 (14.4K) (codec ra_144)
A..... roq_dpcm id RoQ DPCM
A..X.. s302m SMPTE 302M
A..... sbc SBC (low-complexity subband codec)
A..X.. sonic Sonic
A..X.. sonicls Sonic lossless
A..... libspeex libspeex Speex (codec speex)
A..X.. truehd TrueHD
A..... tta TTA (True Audio)
A..X.. vorbis Vorbis
A..... libvorbis libvorbis (codec vorbis)
A..... wavpack WavPack
A..... libwavpack (codec wavpack)
A..... wmav1 Windows Media Audio 1
A..... wmav2 Windows Media Audio 2
S..... ssa ASS (Advanced SubStation Alpha) subtitle (codec ass)
S..... ass ASS (Advanced SubStation Alpha) subtitle
S..... dvbsub DVB subtitles (codec dvb_subtitle)
S..... dvdsub DVD subtitles (codec dvd_subtitle)
S..... mov_text 3GPP Timed Text subtitle
S..... srt SubRip subtitle (codec subrip)
S..... subrip SubRip subtitle
S..... text Raw text subtitle
S..... webvtt WebVTT subtitle
S..... xsub DivX subtitles (XSUB)
Our package enables hardware decoding. For hardware encoding, you may try the forum contribution:
GitHub - Keylost/jetson-ffmpeg: ffmpeg support on nvidia jetson
Or consider using jetson_multimedia_api
Thank you very much for your reply. I have installed ffmpeg and jetson ffMpeg for this tutorial, but when I was running the compilation, I encountered an Unknown decoder ‘h264_nvmpi’
Is it because my device doesn’t support it or did I not compile successfully?
root@ids-desktop:/home/nvidia/ffmpeg# ffmpeg -c:v h264_nvmpi -i /home/nvidia/input.mp4 -t 5 -c copy /home/nvidia/output.mp4
configuration: --prefix=/usr --enable-nvv4l2dec --enable-libv4l2 --enable-shared --extra-libs=‘-L/usr/lib/aarch64-linux-gnu/tegra -lv4l2 -lnvbufsurface -lnvbufsurftransform’ --extra-cflags=-I/usr/src/jetson_multimedia_api/include/ --extra-version=1ubuntu0.1 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --arch=arm64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
Please consult with the author to get further suggestion.
Thank you very much. My program has been successfully compiled using NVENC, but there is one issue:
It reports that the memory of the nvmpi encoder is low, but when I observed it with jtop, it seemed to be using the memory of my GPU. However, my GPU still has about 15 GB unused, so I have two questions
- Is the nvmpi encoder running on its own memory or GPU memory?
- Can I increase the usage of memory through some settings, such as giving it some system memory or GPU memory
nvmpi encoder packet memory pool is empty! Packet will be dropped. There may be artifacts in the output video.
Would suggest consult with the author for further questions. Or you may consider using jetson_multimedia_api. The sample demonstrating hardware encoding is at
/usr/src/jetson_multimedia_api/samples/01_video_encode/
