Failed to create any GPU devices, including an attempt with compatibility mode
Diveces:
RTX 3080
RAM: 32G
i7-12700F
System:
ubuntu20.04
Nvidia driver:
535.129.03
Isaac sim version:
4.2.0
It worked fine when I use Isaac sim docker, but I launch with omniverse, the error appeared “Failed to create any GPU devices, including an attempt with compatibility mode.” Any ideas?
Hmm strange. So Isaac Sim through a docker is good, but when you try to launch Isaac Sim natively through the Omniverse launcher on the same machine, it fails with that message? That message means either you have an incomptible driver, usually meaning a driver version we currently don’t support, or an actual gpu we don’t support. The RTX 3080 should be ok. Also the driver version is correct. So I am stumped. Let me ask my team.
Technical Requirements — Omniverse USD Composer
Can you at least try to reinstall the driver directly in your Ubuntu OS, without the container? You have Fuse2lib installed right? You can get into Launcher ok right?
hi,RTX4090D
driver:550.135
ubuntu20.04
the same error launching with omniverse.could you give me some idea?
Your driver is too new. You need to stick to the recommended driver which is still lower that the 550
