No fuses burned before. Just want to know if the system is still workable after signed images flashed without fuses burned, and if the system still can enter RCM?
you may also enable Jetson Security to protect the device.
fuses are designed to be inaccessible for production. the concept of Secureboot is to prevent execution of unauthorized code during boot process through chain-of-trust;
those authenticates boot components (such as, Boot Configuration Table, bootloader binaries, and warmboot vector) were signed using private key. (i.e. PKC / SBK)
for example,
there’s PKC used to ensure data integrity.
with PKC protection, if there’s any boot code changes or corruption, boot should not be able to go through.
there’s also SBK to protect data confidentiality.
with SBK protection, boot code should be properly encrypted, it will check signature for boot.
please also refer to developer guide, please check Secureboot chapter for more details.
thanks
“sudo bash ./flashcmd.txt” it’s the generate flash command-line according to your previous options specify to the flash.sh
so, please don’t use this flash command line since you’re target is not fused.
So only fuses burned firstly, images signed with non-zero key can be flashed to target. Right? If yes, is there any way to program the signed images bypass the key verification?
may I know what’s the real use-case to enable this?
as you can see in comment #5, it’s Secureboot is to prevent execution of unauthorized code during boot process through chain-of-trust;
that’s just an incorrect process, you should expect failures during image flash.
btw,
please also check developer guide as see-also, Jetson Xavier NX / AGX Xavier / TX2 Update and Redundancy.
there’s bootloader redundancy to reduce the risk of boot failure after a Bootloader update and when images on the current Bootloader slot are corrupted.
so,
if you’re using partition update, (i.e. -k kernel) to update one partition with your own signed image, it’s bootloader redundancy to handle the booting failure, you may look into bootloader logs for the details.
thanks
