Failed to import python module omni.isaac.assets_check. Error: No module named 'numpy'
When i start isaac sim the log showed a lot of errors and i dont know why.
Although it seem run correct, there are still some problems such as i dont have Isaac Utils and Isaac Examples in my menu
I put the logs in 1.txt
1.txt (209.6 KB)
Isaac Sim Version
4.2.0
Operating System
Ubuntu 20.04
This is a known issue on 4.2.0 (as discussed in Isaac Sim version 4.2.0 missing many Isaac Utils and Isaac Examples there were available in previous versions). Please upgrade to the latest version, 4.5.0.
thank you!
Hi, I met the same problem these days. Do you solve this successfully by upgrading to 4.5.0?
Thank you so much!
