I followed the tutorial in for ZED2i camera in isaac_ros_visual_slam — isaac_ros_docs documentation
For ZED2i I successfully managed to complete the setup: Isaac ROS ZED Setup — isaac_ros_docs documentation
All installations with Docker for x86_64 seemed to be successful.
The problem arises when executing:
ros2 launch isaac_ros_examples isaac_ros_examples.launch.py launch_fragments:=zed_stereo_rect,visual_slam pub_frame_rate:=30.0 base_frame:=zed2_camera_center camera_optical_frames:="['zed2_left_camera_optical_frame', 'zed2_right_camera_optical_frame']" interface_specs_file:=${ISAAC_ROS_WS}/isaac_ros_assets/isaac_ros_visual_slam/zed2_quickstart_interface_specs.json
I tried to follow similar issues, but they seemed to be more related to Jetson: Failed to initialize CUVSLAM tracker: 4
Do you have any suggestion to debug this problem?
As an additional notice, the problem seemed to arise also for ROSBag
Hi @alberto.remus
If this issue is related also to the ROSbag, please ensure that everything is well installed and works; maybe the issue is not related to the camera.
Raffaello
Hi @Raffaello,
I confirm that the problem is related to the ROSbag so I agree it is better to focus on that (I’m going to edit the title).
I tried a fresh installation and still getting this issue on my RTX 3080 Laptop GPU, do you have any hint to narrow down the problem?
As additional information, my local machine has:
NVIDIA-SMI 550.120 Driver Version: 550.120 CUDA Version: 12.4
Hi @alberto.remus
I think your issue is also related to other topics:
I add in this discussion @Ahung to keep you updated
Best,
Raffaello
Ahung
6
Hi @alberto.remus,
If you are using Isaac ROS 3.2, please upgrade CUDA 12.6+ according to the system requirements.
https://nvidia-isaac-ros.github.io/getting_started/index.html
Best,
Ahung
