Issue Running Isaac VSLAM with ZED Wrapper on Isaac ROS 3.1
Hello everyone,
I have followed the official ZED camera setup instructions from NVIDIA’s Isaac ROS documentation:
ZED Setup for Isaac ROS
I’m using Isaac ROS version 3.1 and trying to run Isaac VSLAM based on this guide:
Isaac ROS Visual SLAM
What Works:
  • The build process completes without errors for both the ZED wrapper and Isaac VSLAM.
  • The ZED Explorer launches, and I can open the cameras successfully.
The Issue:
When running the following launch command for Isaac VSLAM:
ros2 launch isaac_ros_examples isaac_ros_examples.launch.py \
launch_fragments:=zed_stereo_rect,visual_slam \
base_frame:=zed2_camera_center camera_optical_frames:="['zed2_left_camera_optical_frame', 'zed2_right_camera_optical_frame']" \
interface_specs_file:=${ISAAC_ROS_WS}/isaac_ros_assets/isaac_ros_visual_slam/zedx_quickstart_interface_specs.json
I get this error:
[INFO] [launch]: All log files can be found below /home/admin/.ros/log/2025-01-29-13-02-41-371529-GTW-ONX2-ubuntu-13025
[INFO] [launch]: Default logging verbosity is set to INFO
[INFO] [1738155761.518415355] [isaac_ros_examples]: Info: Interface spec "camera_model" is overridden. The value from the overriding file will be used
[INFO] [1738155761.519713525] [isaac_ros_examples]: Info: Interface spec "camera_frame" is overridden. The value from the overriding file will be used
[INFO] [1738155761.520897324] [isaac_ros_examples]: Info: Interface spec "camera_resolution" is overridden. The value from the overriding file will be used
[ERROR] [launch]: Caught exception in launch (see debug for traceback): package 'zed_wrapper' found at '/workspaces/isaac_ros-dev/install/zed_wrapper', but libexec directory '/workspaces/isaac_ros-dev/install/zed_wrapper/lib/zed_wrapper' does not exist
Additional Observations:
  • When launching ZED Explorer manually using:
/usr/local/zed/tools/ZED_Explorer
I see the following message in the terminal:
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-admin'
** [SVO] Hardware compression (NVENC) available **
[ZED-X][Warning] Failed to connect to zed_x_daemon.
Inside the ZED Explorer interface, I also notice a message indicating:
Disk Free space 0GB on /home/admin/Documents/ZED
I suspect this could be related to either a missing component in the ZED wrapper installation or an issue with the expected directory structure. Any insights on how to resolve this would be appreciated.
Hi @koenvanwijlick1
Looking this message seems the zed_wrapper is not installed or your didn’t import the sources.
For this issue, follow the ZED documentation: https://www.stereolabs.com/docs/get-started-with-zed-x/zed-x-and-docker
Best,
Raffaello
Hi @koenvanwijlick1
About ZED camera setup instructions in Isaac ROS 3.1, please add branch humble-v4.1.4 for zed-ros2-wrapper if you’re using Orin platform.
cd ${ISAAC_ROS_WS} && rm -rf zed-ros2-wrapper &&
git clone --recurse-submodules -b humble-v4.1.4 https://github.com/stereolabs/zed-ros2-wrapper
For that libexec error, I assume that you may have changed zed sdk version. If so, please revert it back.
Let me know,
Best,
Ahung
Hello thank you for your reply, after checking out the given version and reverting back to the correct SDK version i get the following warning
user@GTW-ONX2-ubuntu:~/workspaces/isaac_ros-dev/src/isaac_ros_common$ cd ${ISAAC_ROS_WS}/src/isaac_ros_common && ./scripts/run_dev.sh
Attaching to running container: isaac_ros_dev-aarch64-container
admin@GTW-ONX2-ubuntu:/workspaces/isaac_ros-dev$ /usr/local/zed/tools/ZED_Explorer
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to ‘/tmp/runtime-admin’
[ZED-X][Warning] Failed to verify the match between the L4T version of the host and the container. If you are indeed in a container, be sure to run the same L4T version on both.
Do i need to add the rules of the docker to the launching of the run dev script of isaac ros? I can open the ZED_Explorer and see the camera connections. For note i do use two Zed X cameras
Okay,
I posted something to early adding it as an addition doesnt work but directly adding it to the launch works:
docker run -it --rm
–privileged
–network host
${DOCKER_ARGS[@]}
-v $ISAAC_ROS_DEV_DIR:/workspaces/isaac_ros-dev
-v /etc/localtime:/etc/localtime:ro
–name “$CONTAINER_NAME”
–runtime nvidia
–user=“admin”
–entrypoint /usr/local/bin/scripts/workspace-entrypoint.sh
–workdir /workspaces/isaac_ros-dev
-v /dev/:/dev/
-v /tmp/:/tmp/
-v /var/nvidia/nvcam/settings/:/var/nvidia/nvcam/settings/
-v /etc/systemd/system/zed_x_daemon.service:/etc/systemd/system/zed_x_daemon.service
-v ${HOME}/zed_docker_ai/:/usr/local/zed/resources/
$BASE_NAME
/bin/bash
Hi, I am running into similar issues with my ZED2i where i keep getting
admin@ubuntu:/workspaces/isaac_ros-dev$ /usr/local/zed/tools/ZED_Explorer
[2025-06-29 05:50:29 UTC][ZED][WARNING] Warning: Recover MCU returns ECx-3
[2025-06-29 05:50:29 UTC][ZED][WARNING] [Sensors] MCU module not responding. Attempt module reboot
[ZED][MCU] Permissions denied : can't open device. Make sure you have installed udev rules or use sudo
[2025-06-29 05:50:30 UTC][ZED][WARNING] Warning: Recover MCU returns ECx-3
[2025-06-29 05:50:30 UTC][ZED][WARNING] [Sensors] MCU module not responding. Attempt module reboot
So I tried what you had done in the last step but its saying admin doesnt exist\
+ docker run -it --rm --privileged --network host --ipc=host -v /tmp/.X11-unix:/tmp/.X11-unix -v /home/student/.Xauthority:/home/admin/.Xauthority:rw -e DISPLAY -e NVIDIA_VISIBLE_DEVICES=all -e NVIDIA_DRIVER_CAPABILITIES=all -e ROS_DOMAIN_ID -e USER -e ISAAC_ROS_WS=/workspaces/isaac_ros-dev -e HOST_USER_UID=1000 -e HOST_USER_GID=1000 -v /run/user/1000/keyring/ssh:/ssh-agent -e SSH_AUTH_SOCK=/ssh-agent -e NVIDIA_VISIBLE_DEVICES=nvidia.com/gpu=all,nvidia.com/pva=all -v /usr/bin/tegrastats:/usr/bin/tegrastats -v /tmp/:/tmp/ -v /usr/lib/aarch64-linux-gnu/tegra:/usr/lib/aarch64-linux-gnu/tegra -v /usr/src/jetson_multimedia_api:/usr/src/jetson_multimedia_api --pid=host -v /usr/share/vpi3:/usr/share/vpi3 -v /dev/input:/dev/input -v /home/student/workspaces/isaac_ros-dev/:/workspaces/isaac_ros-dev -v /etc/localtime:/etc/localtime:ro --name isaac_ros_dev-aarch64-container --runtime nvidia --user=“admin” --entrypoint /usr/local/bin/scripts/workspace-entrypoint.sh --workdir /workspaces/isaac_ros-dev -v /dev/:/dev/ -v /tmp/:/tmp/ -v /var/nvidia/nvcam/settings/:/var/nvidia/nvcam/settings/ -v /etc/systemd/system/zed_x_daemon.service:/etc/systemd/system/zed_x_daemon.service -v /home/student/zed_docker_ai/:/usr/local/zed/resources/ isaac_ros_dev-aarch64 /bin/bash
docker: Error response from daemon: unable to find user “admin”: no matching entries in passwd file
Run 'docker run --help' for more information
+ cleanup
+ for command in "${ON_EXIT[@]}"
+ popd
Any suggestion would help.
Best,
Ambarish
this is within the docker file for the command run_dev.sh so add it there instead of directly running this within a terminal
Hi all,
We are currently working to fix this issue, and a minor update will be released soon.
Best,
Raffafello
Thanks! I appreciate the help but I did run into few issues while trying that as docker couldn’t find few env variables. So added the snippet from this post in my run_dev.sh before the docker run command. And it fixed it.
