I tried to run deepstream 3.0 samples with jetpack4.2 on TX2,but failed:
deepstream-app -c config_infer_primary.txt
** ERROR: main:613: Failed to set pipeline to PAUSED
Quitting
ERROR from src_bin_muxer: Output width not set
Debug info: /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvmultistream/gstnvstreammux.c(1633): gst_nvstreammux_change_state (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstNvStreamMux:src_bin_muxer
App run failed
thanks, Radhika.I failed to flash my tx2 with jetpack3.2,so I have to try jetpack4.2. Jetpack4.2 is in good state except deepstream samples. I am a little lost. I am planning to try jetpack4.1.
Thanks, kayccc. So I have to flash Jetpack3.2 to TX2. I did that yesterday but no good result. The os is flashed to the board and network is up. But usb is not available. And the basic command “sudo” is also not available. I guess only the os is flashed successfully.
I am looking for a guide for flashing jetpack3.2 to tx2. any suggestion?
Im also having the same issue. 3.2 wont flash properly, and older cuda and cudnn packages have to be installed manually on tx2. Its very dissappointing that we have such expensive boards we cant develop on simply because older packages are harder to install properly on the tx2 and we cant even have access to deepstream because we cant afford to get a xavier. Stuck in the middle without a possible route at the moment.
