I met problem when I run nvgstiva-app on TX2.
sudo ./nvgstiva-app -c …/…/configs/PGIE-FP16-CarType-CarMake-CarColor.txt
**ERROR: <create_osd_bin:62>: Failed to create ‘nvosd0’
**ERROR: <create_osd_bin:100>: create_osd_bin failed
**ERROR: <create_processing_instance:926>: create_processing_instance failed
**ERROR: <create_pipeline:1062>: create_pipeline failed
**ERROR: main:384: Failed to create pipeline
First my environment is below.
HW: TX2
JetPack 4.2
DeepStream SDK version 1.5
I flashed image and hardly push jetson sdk componet to TX2.
Website said that DeepStream SDK version 1.5 is the latest supported version for Jetson TX1 and TX.
So I installed DeepStream SDK Ver 1.5 and build nvgstiva-app and build successful.
But when I run sample application, I got error messages…
What is my problem?
Please let me know what’s my problem.
Thanks comment. But I am still confusing…
I will explain why I am confused.
To enable TX2 board and running Deep Stream SDK, I searched Nvidia sites.
There are many dependencies for running Deep Stream SDK. JetPack is comprehensive solution for these steps. (JetPack SDK | NVIDIA Developer)
Website said “JetPack 4.2 is the latest production release supporting Jetson AGX Xavier, Jetson TX2 series modules, and …”. So I installed JetPack 4.2 without a doubt.
If I want to use DeepStream SDK 1.5 in TX2, I need to newly install JetPack3.3 and use it.
Yes
If I want to use DeepStream SDK 3.0 with JetPack4.2, I need to wait the release for R32.x BSP.
DeepStream SDK 3.0 is for Xavier only, there will be a new DeepStream SDK release to support this R32.x BSP.
