Hi Jerry,
Thank you. May I ask the reason why I am unable to use odmfuseread.sh? I can’t read the fuse I burned
hi Jerry,
I removed the test parameter from odmfuse.sh for burning, and according to your statement, the burning was successful. However, when I was using flash to write the image, I was prompted with
Error: either RSA key file and/or SBK key file are provided for none SBK and PKC protected target board
Did I make a mistake somewhere?
work@E470c:~/nvidia/35.4.1/Linux_for_Tegra$ sudo ./flash.sh -v uefi_keys/sbk.txt -u uefi_keys/rsa_3k.pem jetson-agx-xavier-devkit mmcblk0p1
# L4T BSP Information:
# R35 , REVISION: 4.1
# User release: 0.0
# Target Board Information:
# Name: jetson-agx-xavier-devkit, Board Family: t186ref, SoC: Tegra 194,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
Error: either RSA key file and/or SBK key file are provided for none SBK and PKC protected target board.
hello Youke,
as mentioned, the recommended way is to burn all fuses together instead of burning fuses step-by-step.
there should be odmfuse_pkc.xml
created for checking all fuses values.
so,
please give it a try to create the image blob locally.
$ sudo BOARDID=2888 FAB=400 BOARDSKU=0004 BOARDREV=K.0 ./flash.sh --no-flash -u rsa_priv.pem -v ./sbk.key jetson-xavier mmcblk0p1
Hi jerry,
I have made some modifications to the burnt in XML file. May I ask if there are any missing items regarding the complete burnt in you mentioned?
work@E470c:~/nvidia/35.4.1/Linux_for_Tegra$ cat uefi_keys/rsa_3k.xml
<genericfuse MagicId="0x45535546" version="1.0.0">
<fuse name="PublicKeyHash" size="32" value="0xe297bd68a275dc373dbec6f9cdbdabca9a690e3d32f3261bcb8aa6422a389adf"/>
<fuse name="Kek0" size="16" value="0x112233445566778899AABBCCDDEEFF00"/>
<fuse name="Kek1" size="16" value="0x123456789ABCDEF0FEDCBA9876543210"/>
<fuse name="SecureBootKey" size="16" value="0x123456789ABCDEF0FEDCBA9876543210"/>
<fuse name="BootSecurityInfo" size="4" value="0x06"/>
<fuse name="SecurityMode" size="4" value="0x1"/>
</genericfuse>
thanks
hold-on, are you going to burn another target?
may I know your test results to create the image blob locally.
The result of executing image blob is as follows
work@E470c:~/nvidia/35.4.1/Linux_for_Tegra$ sudo BOARDID=2888 FAB=400 BOARDSKU=0004 BOARDREV=K.0 ./flash.sh --no-flash -u uefi_keys/rsa_3k.pem -v ./uefi_keys/sbk.txt jetson-xavier mmcblk0p1
[sudo] work 的密码:
# User release: 0.0
Board ID(2888) FAB(400) sku(0004) revision(K.0)
lz4c installed at /usr/bin/lz4c
Compressing /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb ...
Copy /home/work/nvidia/35.4.1/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb to /home/work/nvidia/35.4.1/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb.rec
NVDISP+UEFI in bootloader/nvdisp-init.bin ..
copying bctfile(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p2888.cfg)... done.
copying bctfile1(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying uphy_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg)... done.
copying minratchet_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg)... done.
copying device_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-sdmmc.cfg)... done.
copying misc_cold_boot_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying misc_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg)... done.
copying gpioint_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg)... done.
copying pmic_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg)... done.
copying pmc_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg)... done.
copying prod_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg)... done.
copying scr_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying scr_cold_boot_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying bootrom_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg)... done.
copying dev_params(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-sdmmc.cfg)... done.
copying dev_params_b(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct_b-sdmmc.cfg)... done.
Existing bootloader(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/ramdisk_tmp /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader /home/work/nvidia/35.4.1/Linux_for_Tegra
42010 块
gzip: /home/work/nvidia/35.4.1/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.10.120-tegra
58247 块
Making Recovery image...
copying recdtbfile(/home/work/nvidia/35.4.1/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb.rec)... done.
记录了20+0 的读入
记录了20+0 的写出
20字节已复制,0.000578984 s,34.5 kB/s
Existing sosfile(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing tegraboot(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing cpu_bootloader(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
Existing mb2blfile(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mtspreboot(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mcepreboot(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mtsproper(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
Existing mb1file(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing bpffile(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/bpmp-2_t194.bin) reused.
Existing bpfdtbfile(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/tegra194-a02-bpmp-p2888-a04_lz4.dtb) reused.
Existing scefile(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/camera-rtcpu-t194-rce.img) reused.
Existing apefile(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing wb0boot(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
Existing tosfile(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/tos-optee_t194.img) reused.
Existing eksfile(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/eks_t194.img) reused.
copying soft_fuses(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
copying dtbfile(/home/work/nvidia/35.4.1/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
Copying nv_boot_control.conf to rootfs
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating kernel_tegra194-p2888-0001-p2822-0000.dtb to rootfs... done.
Making system.img...
Setting "FDT /boot/dtb/kernel_tegra194-p2888-0001-p2822-0000.dtb" successfully in the extlinux.conf...done.
populating rootfs from /home/work/nvidia/35.4.1/Linux_for_Tegra/rootfs ... populating /boot/extlinux/extlinux.conf ... done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image... done.
system.img built successfully.
Not signing of kernel-dtb
Existing tbcfile(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/nvdisp-init.bin) reused.
记录了131072+0 的读入
记录了131072+0 的写出
67108864字节(67 MB,64 MiB)已复制,0.70859 s,94.7 MB/s
Sync'ing esp.img ... done.
copying tbcdtbfile(/home/work/nvidia/35.4.1/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
copying cfgfile(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t194_sdmmc.xml) to flash.xml... done.
done.
Existing flasher(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing flashapp(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/tegraflash.py) reused.
copying overlay_dtb(/home/work/nvidia/35.4.1/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)... done.
copying overlay_dtb(/home/work/nvidia/35.4.1/Linux_for_Tegra/kernel/dtb/tegra194-p2822-camera-dual-imx274-overlay.dtbo)... done.
copying overlay_dtb(/home/work/nvidia/35.4.1/Linux_for_Tegra/kernel/dtb/tegra194-p2822-camera-e3326-overlay.dtbo)... done.
copying overlay_dtb(/home/work/nvidia/35.4.1/Linux_for_Tegra/kernel/dtb/tegra194-p2822-camera-e3331-overlay.dtbo)... done.
copying overlay_dtb(/home/work/nvidia/35.4.1/Linux_for_Tegra/kernel/dtb/tegra194-p2822-camera-e3333-overlay.dtbo)... done.
copying overlay_dtb(/home/work/nvidia/35.4.1/Linux_for_Tegra/kernel/dtb/tegra194-p2822-camera-imx185-overlay.dtbo)... done.
copying overlay_dtb(/home/work/nvidia/35.4.1/Linux_for_Tegra/kernel/dtb/tegra194-p2822-camera-imx390-overlay.dtbo)... done.
copying overlay_dtb(/home/work/nvidia/35.4.1/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0005-overlay.dtbo)... done.
copying overlay_dtb(/home/work/nvidia/35.4.1/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000-overlay.dtbo)... done.
/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --sdram_config tegra194-mb1-bct-memcfg-p2888.cfg,tegra194-memcfg-sw-override.cfg --odmdata 0x9190000 --overlay_dtb L4TConfiguration.dtbo,tegra194-p2822-camera-dual-imx274-overlay.dtbo,tegra194-p2822-camera-e3326-overlay.dtbo,tegra194-p2822-camera-e3331-overlay.dtbo,tegra194-p2822-camera-e3333-overlay.dtbo,tegra194-p2822-camera-imx185-overlay.dtbo,tegra194-p2822-camera-imx390-overlay.dtbo,tegra194-p2888-0005-overlay.dtbo,tegra194-p2888-0001-p2822-0000-overlay.dtbo, --bldtb tegra194-p2888-0001-p2822-0000.dtb --applet mb1_t194_prod.bin --cmd "sign" --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --cfg flash.xml --chip 0x19 --uphy_config tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --device_config tegra19x-mb1-bct-device-sdmmc.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --pmic_config tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --pmc_config tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --prod_config tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini.cfg --br_cmd_config tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --dev_params tegra194-br-bct-sdmmc.cfg,tegra194-br-bct_b-sdmmc.cfg --bin "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp-2_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a04_lz4.dtb; spe_fw spe_t194.bin; tos tos-optee_t194.img; eks eks_t194.img; bootloader_dtb tegra194-p2888-0001-p2822-0000.dtb" --secondary_gpt_backup --bct_backup --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --encrypt_key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0461 ] Using default ramcode: 0
[ 0.0462 ] Disable BPMP dtb trim, using default dtb
[ 0.0462 ]
[ 0.0562 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --getmode mode.txt
[ 0.0594 ] Key size is 384 bytes
[ 0.0575 ] Generating RCM messages
[ 0.0676 ] tegrasign_v3.py --file mb1_t194_prod.bin --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --offset 4096
[ 0.0685 ] Key is a SBK key
[ 0.0685 ] Key Size is 16 bytes
[ 0.0873 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod_encrypt.bin zerosbk
[ 0.0892 ] Header already present for mb1_t194_prod_encrypt.bin
[ 0.1047 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --getmode mode.txt
[ 0.1071 ] Key size is 384 bytes
[ 0.1116 ] tegrasign_v3.py --file mb1_t194_prod_encrypt_sigheader.bin --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --length 1136 --getmontgomeryvalues montgomery.bin --offset 2960 --pubkeyhash pub_key.key
[ 0.1141 ] Key size is 384 bytes
[ 0.1987 ] Saving pkc public key in pub_key.key
[ 0.1988 ] Saving Montgomery values in montgomery.bin
[ 0.1956 ] tegrahost_v2 --chip 0x19 0 --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin --updatesigheader mb1_t194_prod_encrypt_sigheader.bin mb1_t194_prod_encrypt_sigheader.sig oem-rsa
[ 0.2544 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[ 0.2602 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 0.2621 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.2633 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.2633 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.2633 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.2633 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.2634 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.2634 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.2634 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.2634 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.2634 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.2634 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.2634 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.2634 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.2634 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.2634 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.2635 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.2635 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.2635 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.2635 ]
[ 0.2673 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_encrypt_sigheader.bin 0 0
[ 0.2692 ] RCM 0 is saved as rcm_0.rcm
[ 0.2744 ] RCM 1 is saved as rcm_1.rcm
[ 0.2748 ] RCM 2 is saved as rcm_2.rcm
[ 0.2752 ] List of rcm files are saved in rcm_list.xml
[ 0.2753 ]
[ 0.2753 ] Signing RCM messages
[ 0.2854 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list rcm_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[ 0.2878 ] Key size is 384 bytes
[ 0.5297 ] Saving pkc public key in pub_key.key
[ 0.5298 ] Saving Montgomery values in montgomery.bin
[ 0.5231 ] Copying signature to RCM mesages
[ 0.5279 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 0.5313 ] odmdata (to decode) = 152633344
[ 0.5314 ] Odmdata strings: PCIE_XBAR_4_1_0_1_2,UFS_x1_L1,NVHS_PCIE,enable-debug-console,enable-denver-wdt
[ 0.5314 ] Bpmp odmdata config: {'pcie-xbar-config': [0, 1, 'PCIE_XBAR_4_1_0_1_2'], 'pcie-c0-endpoint-enable': [1, 0, ''], 'pcie-c4-endpoint-enable': [1, 0, ''], 'ufs-config': [0, 1, 'UFS_x1_L1'], 'sata-enable': [1, 0, ''], 'nvhs-owner': [0, 1, 'PCIE'], 'pcie-c5-endpoint-enable': [1, 0, '']}
[ 0.5824 ] bpmp_dtb is compressed; decompressing...
[ 0.5824 ] lz4c -df tegra194-a02-bpmp-p2888-a04_lz4.dtb tegra194-a02-bpmp-p2888-a04_lz4_with_odm.dtb
[ 0.5901 ] tegra194-a02-bpmp-p2 : decoded 989312 bytes
[ 0.5901 ]
[ 1.0193 ] Re-compressing updated bpmp_dtb
[ 1.0193 ] lz4c -zf tegra194-a02-bpmp-p2888-a04_lz4_with_odm.dtb tegra194-a02-bpmp-p2888-a04_lz4.dtb
[ 1.0262 ] Compressed 989271 bytes into 86508 bytes ==> 8.74%
[ 1.0263 ]
[ 1.8395 ] Concatenating L4TConfiguration.dtbo,tegra194-p2822-camera-dual-imx274-overlay.dtbo,tegra194-p2822-camera-e3326-overlay.dtbo,tegra194-p2822-camera-e3331-overlay.dtbo,tegra194-p2822-camera-e3333-overlay.dtbo,tegra194-p2822-camera-imx185-overlay.dtbo,tegra194-p2822-camera-imx390-overlay.dtbo,tegra194-p2888-0005-overlay.dtbo,tegra194-p2888-0001-p2822-0000-overlay.dtbo to tegra194-p2888-0001-p2822-0000_with_odm_overlay.dtb
[ 1.8428 ] Parsing partition layout
[ 1.8811 ] tegraparser_v2 --pt flash.xml.tmp
[ 1.8846 ] Creating list of images to be signed
[ 1.8882 ] tegrahost_v2 --chip 0x19 --partitionlayout flash.xml.bin --list images_list.xml --ratchet_blob ratchet_blob.bin
[ 1.8903 ] MB1: Nvheader already present is mb1_t194_prod_aligned.bin
[ 1.8923 ] Header already present for mb1_t194_prod_aligned_sigheader.bin
[ 1.8932 ] MB1: Nvheader already present is mb1_b_t194_prod_aligned.bin
[ 1.8982 ] Header already present for mb1_b_t194_prod_aligned_sigheader.bin
[ 1.8991 ] adding BCH for spe_t194_aligned.bin
[ 1.9684 ] adding BCH for nvtboot_t194_aligned.bin
[ 1.9770 ] Header already present for preboot_c10_prod_cr_aligned.bin
[ 1.9914 ] adding BCH for spe_t194_aligned.bin
[ 1.9923 ] adding BCH for nvtboot_t194_aligned.bin
[ 1.9989 ] Header already present for preboot_c10_prod_cr_aligned.bin
[ 2.0078 ] Header already present for mce_c10_prod_cr_aligned.bin
[ 2.0088 ] adding BCH for mts_c10_prod_cr_aligned.bin
[ 2.0275 ] adding BCH for nvdisp-init_aligned.bin
[ 2.1619 ] adding BCH for tegra194-p2888-0001-p2822-0000_aligned.dtb
[ 2.2682 ] adding BCH for tos-optee_t194_aligned.img
[ 2.3560 ] adding BCH for eks_t194_aligned.img
[ 2.4022 ] adding BCH for bpmp-2_t194_aligned.bin
[ 2.4070 ] adding BCH for tegra194-a02-bpmp-p2888-a04_lz4_aligned.dtb
[ 2.4434 ] adding BCH for camera-rtcpu-t194-rce_aligned.img
[ 2.4484 ] adding BCH for adsp-fw_aligned.bin
[ 2.4686 ] Header already present for warmboot_t194_prod_aligned.bin
[ 2.4829 ] Header already present for mce_c10_prod_cr_aligned.bin
[ 2.4845 ] adding BCH for mts_c10_prod_cr_aligned.bin
[ 2.5045 ] adding BCH for nvdisp-init_aligned.bin
[ 2.6412 ] adding BCH for tegra194-p2888-0001-p2822-0000_aligned.dtb
[ 2.7487 ] adding BCH for tos-optee_t194_aligned.img
[ 2.7709 ] adding BCH for eks_t194_aligned.img
[ 2.8063 ] adding BCH for bpmp-2_t194_aligned.bin
[ 2.8114 ] adding BCH for tegra194-a02-bpmp-p2888-a04_lz4_aligned.dtb
[ 2.8483 ] adding BCH for camera-rtcpu-t194-rce_aligned.img
[ 2.8542 ] adding BCH for adsp-fw_aligned.bin
[ 2.8747 ] Header already present for warmboot_t194_prod_aligned.bin
[ 2.9013 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list images_list.xml --pubkeyhash pub_key.key
[ 2.9040 ] Key size is 384 bytes
[ 5.2835 ] Saving pkc public key in pub_key.key
[ 5.2768 ] Parsing dev params for multi chains
[ 5.2769 ] Generating br-bct
[ 5.2806 ] Performing cfg overlay
[ 5.2807 ] ['tegra194-mb1-bct-memcfg-p2888.cfg', 'tegra194-memcfg-sw-override.cfg']
[ 5.2812 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p2888.cfg -s tegra194-memcfg-sw-override.cfg -o /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1.cfg
[ 5.3802 ] Updating dev and MSS params in BR BCT
[ 5.3803 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 5.5298 ] Updating bl info
[ 5.5338 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 5.5455 ] Generating br-bct
[ 5.5498 ] Performing cfg overlay
[ 5.5498 ] ['/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1.cfg']
[ 5.5498 ] Updating dev and MSS params in BR BCT
[ 5.5499 ] tegrabct_v2 --dev_param tegra194-br-bct_b-sdmmc.cfg --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 5.7020 ] Updating bl info
[ 5.7059 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 5.7172 ] Generating BCT backup image
[ 5.7174 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 5.7284 ] 记录了32768+0 的读入
[ 5.8939 ] 记录了32768+0 的写出
[ 5.8939 ] 32768字节(33 kB,32 KiB)已复制,0.164696 s,199 kB/s
[ 5.8939 ]
[ 5.8940 ] Concatenating BCT for chain A to bct_backup.img
[ 5.8940 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 5.8967 ] 记录了2888+0 的读入
[ 5.9098 ] 记录了2888+0 的写出
[ 5.9099 ] 2888字节(2.9 kB,2.8 KiB)已复制,0.0123224 s,234 kB/s
[ 5.9099 ]
[ 5.9099 ] Concatenating BCT for chain B to bct_backup.img
[ 5.9100 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 5.9126 ] 记录了2888+0 的读入
[ 5.9258 ] 记录了2888+0 的写出
[ 5.9258 ] 2888字节(2.9 kB,2.8 KiB)已复制,0.012307 s,235 kB/s
[ 5.9258 ]
[ 5.9314 ] tegrahost_v2 --chip 0x19 --align mb1_t194_prod_aligned_sigheader_aligned.bin
[ 5.9339 ] header_magic: 4e564441
[ 5.9449 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list mb1_t194_prod_aligned_sigheader_aligned.bin_list.xml
[ 5.9455 ] Key is a SBK key
[ 5.9455 ] Key Size is 16 bytes
[ 5.9610 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_aligned_sigheader_aligned.bin.encrypt mb1_t194_prod_aligned_sigheader_aligned.bin.hash zerosbk
[ 5.9728 ] tegrahost_v2 --chip 0x19 --align mb1_t194_prod_sigheader.bin_aligned.encrypt
[ 5.9752 ] header_magic: 4e564441
[ 5.9861 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list mb1_t194_prod_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 5.9889 ] Key size is 384 bytes
[ 6.0672 ] Saving pkc public key in pub_key.key
[ 6.0644 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin_aligned.encrypt.signed mb1_t194_prod_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 6.0771 ] tegrahost_v2 --chip 0x19 --align mb1_b_t194_prod_aligned_sigheader_aligned.bin
[ 6.0796 ] header_magic: 4e564441
[ 6.0906 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list mb1_b_t194_prod_aligned_sigheader_aligned.bin_list.xml
[ 6.0912 ] Key is a SBK key
[ 6.0912 ] Key Size is 16 bytes
[ 6.1066 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_b_t194_prod_aligned_sigheader_aligned.bin.encrypt mb1_b_t194_prod_aligned_sigheader_aligned.bin.hash zerosbk
[ 6.1185 ] tegrahost_v2 --chip 0x19 --align mb1_b_t194_prod_sigheader.bin_aligned.encrypt
[ 6.1209 ] header_magic: 4e564441
[ 6.1319 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list mb1_b_t194_prod_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 6.1347 ] Key size is 384 bytes
[ 6.2134 ] Saving pkc public key in pub_key.key
[ 6.2106 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_b_t194_prod_sigheader.bin_aligned.encrypt.signed mb1_b_t194_prod_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 6.2229 ] tegrahost_v2 --chip 0x19 --align spe_t194_sigheader_aligned.bin
[ 6.2254 ] header_magic: 4e564441
[ 6.2364 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list spe_t194_sigheader_aligned.bin_list.xml
[ 6.2371 ] Key is a SBK key
[ 6.2371 ] Key Size is 16 bytes
[ 6.2456 ] tegrahost_v2 --chip 0x19 0 --updatesigheader spe_t194_sigheader_aligned.bin.encrypt spe_t194_sigheader_aligned.bin.hash zerosbk
[ 6.2544 ] tegrahost_v2 --chip 0x19 --align spe_t194_sigheader.bin_aligned.encrypt
[ 6.2568 ] header_magic: 4e564441
[ 6.2679 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list spe_t194_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 6.2707 ] Key size is 384 bytes
[ 6.3495 ] Saving pkc public key in pub_key.key
[ 6.3467 ] tegrahost_v2 --chip 0x19 0 --updatesigheader spe_t194_sigheader.bin_aligned.encrypt.signed spe_t194_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 6.3559 ] tegrahost_v2 --chip 0x19 --align nvtboot_t194_sigheader_aligned.bin
[ 6.3585 ] header_magic: 4e564441
[ 6.3694 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list nvtboot_t194_sigheader_aligned.bin_list.xml
[ 6.3699 ] Key is a SBK key
[ 6.3699 ] Key Size is 16 bytes
[ 6.3834 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_t194_sigheader_aligned.bin.encrypt nvtboot_t194_sigheader_aligned.bin.hash zerosbk
[ 6.3945 ] tegrahost_v2 --chip 0x19 --align nvtboot_t194_sigheader.bin_aligned.encrypt
[ 6.3970 ] header_magic: 4e564441
[ 6.4081 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list nvtboot_t194_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 6.4108 ] Key size is 384 bytes
[ 6.4906 ] Saving pkc public key in pub_key.key
[ 6.4880 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_t194_sigheader.bin_aligned.encrypt.signed nvtboot_t194_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 6.4994 ] tegrahost_v2 --chip 0x19 --align preboot_c10_prod_cr_sigheader_aligned.bin
[ 6.5020 ] header_magic: 4e564441
[ 6.5129 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list preboot_c10_prod_cr_sigheader_aligned.bin_list.xml
[ 6.5135 ] Key is a SBK key
[ 6.5135 ] Key Size is 16 bytes
[ 6.5183 ] tegrahost_v2 --chip 0x19 0 --updatesigheader preboot_c10_prod_cr_sigheader_aligned.bin.encrypt preboot_c10_prod_cr_sigheader_aligned.bin.hash zerosbk
[ 6.5257 ] tegrahost_v2 --chip 0x19 --align preboot_c10_prod_cr_sigheader.bin_aligned.encrypt
[ 6.5283 ] header_magic: 4e564441
[ 6.5394 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list preboot_c10_prod_cr_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 6.5421 ] Key size is 384 bytes
[ 6.6219 ] Saving pkc public key in pub_key.key
[ 6.6192 ] tegrahost_v2 --chip 0x19 0 --updatesigheader preboot_c10_prod_cr_sigheader.bin_aligned.encrypt.signed preboot_c10_prod_cr_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 6.6266 ] tegrahost_v2 --chip 0x19 --align spe_t194_sigheader_aligned.bin
[ 6.6292 ] header_magic: 4e564441
[ 6.6403 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list spe_t194_sigheader_aligned.bin_list.xml
[ 6.6408 ] Key is a SBK key
[ 6.6408 ] Key Size is 16 bytes
[ 6.6496 ] tegrahost_v2 --chip 0x19 0 --updatesigheader spe_t194_sigheader_aligned.bin.encrypt spe_t194_sigheader_aligned.bin.hash zerosbk
[ 6.6585 ] tegrahost_v2 --chip 0x19 --align spe_t194_sigheader.bin_aligned.encrypt
[ 6.6611 ] header_magic: 4e564441
[ 6.6721 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list spe_t194_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 6.6750 ] Key size is 384 bytes
[ 6.7536 ] Saving pkc public key in pub_key.key
[ 6.7511 ] tegrahost_v2 --chip 0x19 0 --updatesigheader spe_t194_sigheader.bin_aligned.encrypt.signed spe_t194_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 6.7604 ] tegrahost_v2 --chip 0x19 --align nvtboot_t194_sigheader_aligned.bin
[ 6.7630 ] header_magic: 4e564441
[ 6.7740 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list nvtboot_t194_sigheader_aligned.bin_list.xml
[ 6.7745 ] Key is a SBK key
[ 6.7745 ] Key Size is 16 bytes
[ 6.7888 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_t194_sigheader_aligned.bin.encrypt nvtboot_t194_sigheader_aligned.bin.hash zerosbk
[ 6.8003 ] tegrahost_v2 --chip 0x19 --align nvtboot_t194_sigheader.bin_aligned.encrypt
[ 6.8028 ] header_magic: 4e564441
[ 6.8139 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list nvtboot_t194_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 6.8167 ] Key size is 384 bytes
[ 6.8959 ] Saving pkc public key in pub_key.key
[ 6.8933 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_t194_sigheader.bin_aligned.encrypt.signed nvtboot_t194_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 6.9076 ] tegrahost_v2 --chip 0x19 --align preboot_c10_prod_cr_sigheader_aligned.bin
[ 6.9101 ] header_magic: 4e564441
[ 6.9212 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list preboot_c10_prod_cr_sigheader_aligned.bin_list.xml
[ 6.9217 ] Key is a SBK key
[ 6.9217 ] Key Size is 16 bytes
[ 6.9269 ] tegrahost_v2 --chip 0x19 0 --updatesigheader preboot_c10_prod_cr_sigheader_aligned.bin.encrypt preboot_c10_prod_cr_sigheader_aligned.bin.hash zerosbk
[ 6.9342 ] tegrahost_v2 --chip 0x19 --align preboot_c10_prod_cr_sigheader.bin_aligned.encrypt
[ 6.9369 ] header_magic: 4e564441
[ 6.9482 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list preboot_c10_prod_cr_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 6.9511 ] Key size is 384 bytes
[ 7.0301 ] Saving pkc public key in pub_key.key
[ 7.0276 ] tegrahost_v2 --chip 0x19 0 --updatesigheader preboot_c10_prod_cr_sigheader.bin_aligned.encrypt.signed preboot_c10_prod_cr_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 7.0354 ] tegrahost_v2 --chip 0x19 --align mce_c10_prod_cr_sigheader_aligned.bin
[ 7.0381 ] header_magic: 4e564441
[ 7.0492 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list mce_c10_prod_cr_sigheader_aligned.bin_list.xml
[ 7.0498 ] Key is a SBK key
[ 7.0498 ] Key Size is 16 bytes
[ 7.0607 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mce_c10_prod_cr_sigheader_aligned.bin.encrypt mce_c10_prod_cr_sigheader_aligned.bin.hash zerosbk
[ 7.0705 ] tegrahost_v2 --chip 0x19 --align mce_c10_prod_cr_sigheader.bin_aligned.encrypt
[ 7.0730 ] header_magic: 4e564441
[ 7.0842 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list mce_c10_prod_cr_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 7.0871 ] Key size is 384 bytes
[ 7.1664 ] Saving pkc public key in pub_key.key
[ 7.1640 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mce_c10_prod_cr_sigheader.bin_aligned.encrypt.signed mce_c10_prod_cr_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 7.1878 ] tegrahost_v2 --chip 0x19 --align mts_c10_prod_cr_sigheader_aligned.bin
[ 7.1917 ] header_magic: 4e564441
[ 7.2041 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list mts_c10_prod_cr_sigheader_aligned.bin_list.xml
[ 7.2049 ] Key is a SBK key
[ 7.2049 ] Key Size is 16 bytes
[ 7.3775 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mts_c10_prod_cr_sigheader_aligned.bin.encrypt mts_c10_prod_cr_sigheader_aligned.bin.hash zerosbk
[ 7.4570 ] tegrahost_v2 --chip 0x19 --align mts_c10_prod_cr_sigheader.bin_aligned.encrypt
[ 7.4596 ] header_magic: 4e564441
[ 7.4705 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list mts_c10_prod_cr_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 7.4732 ] Key size is 384 bytes
[ 7.5583 ] Saving pkc public key in pub_key.key
[ 7.5560 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mts_c10_prod_cr_sigheader.bin_aligned.encrypt.signed mts_c10_prod_cr_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 7.6405 ] tegrahost_v2 --chip 0x19 --align nvdisp-init_sigheader_aligned.bin
[ 7.6433 ] header_magic: 4e564441
[ 7.6545 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list nvdisp-init_sigheader_aligned.bin_list.xml
[ 7.6550 ] Key is a SBK key
[ 7.6550 ] Key Size is 16 bytes
[ 7.8009 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvdisp-init_sigheader_aligned.bin.encrypt nvdisp-init_sigheader_aligned.bin.hash zerosbk
[ 7.8704 ] tegrahost_v2 --chip 0x19 --align nvdisp-init_sigheader.bin_aligned.encrypt
[ 7.8729 ] header_magic: 4e564441
[ 7.8838 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list nvdisp-init_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 7.8866 ] Key size is 384 bytes
[ 7.9699 ] Saving pkc public key in pub_key.key
[ 7.9672 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvdisp-init_sigheader.bin_aligned.encrypt.signed nvdisp-init_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 8.0378 ] tegrahost_v2 --chip 0x19 --align tegra194-p2888-0001-p2822-0000_sigheader_aligned.dtb
[ 8.0405 ] header_magic: 4e564441
[ 8.0515 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list tegra194-p2888-0001-p2822-0000_sigheader_aligned.dtb_list.xml
[ 8.0521 ] Key is a SBK key
[ 8.0521 ] Key Size is 16 bytes
[ 8.0790 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p2888-0001-p2822-0000_sigheader_aligned.dtb.encrypt tegra194-p2888-0001-p2822-0000_sigheader_aligned.dtb.hash zerosbk
[ 8.0962 ] tegrahost_v2 --chip 0x19 --align tegra194-p2888-0001-p2822-0000_sigheader.dtb_aligned.encrypt
[ 8.0987 ] header_magic: 4e564441
[ 8.1098 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list tegra194-p2888-0001-p2822-0000_sigheader.dtb_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 8.1126 ] Key size is 384 bytes
[ 8.1922 ] Saving pkc public key in pub_key.key
[ 8.1895 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p2888-0001-p2822-0000_sigheader.dtb_aligned.encrypt.signed tegra194-p2888-0001-p2822-0000_sigheader.dtb_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 8.2099 ] tegrahost_v2 --chip 0x19 --align tos-optee_t194_sigheader_aligned.img
[ 8.2125 ] header_magic: 4e564441
[ 8.2236 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list tos-optee_t194_sigheader_aligned.img_list.xml
[ 8.2241 ] Key is a SBK key
[ 8.2241 ] Key Size is 16 bytes
[ 8.2733 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tos-optee_t194_sigheader_aligned.img.encrypt tos-optee_t194_sigheader_aligned.img.hash zerosbk
[ 8.3008 ] tegrahost_v2 --chip 0x19 --align tos-optee_t194_sigheader.img_aligned.encrypt
[ 8.3034 ] header_magic: 4e564441
[ 8.3145 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list tos-optee_t194_sigheader.img_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 8.3173 ] Key size is 384 bytes
[ 8.3978 ] Saving pkc public key in pub_key.key
[ 8.3952 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tos-optee_t194_sigheader.img_aligned.encrypt.signed tos-optee_t194_sigheader.img_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 8.4229 ] tegrahost_v2 --chip 0x19 --align eks_t194_sigheader_aligned.img
[ 8.4255 ] header_magic: 4e564441
[ 8.4365 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list eks_t194_sigheader_aligned.img_list.xml
[ 8.4371 ] Key is a SBK key
[ 8.4371 ] Key Size is 16 bytes
[ 8.4411 ] tegrahost_v2 --chip 0x19 0 --updatesigheader eks_t194_sigheader_aligned.img.encrypt eks_t194_sigheader_aligned.img.hash zerosbk
[ 8.4481 ] tegrahost_v2 --chip 0x19 --align eks_t194_sigheader.img_aligned.encrypt
[ 8.4507 ] header_magic: 4e564441
[ 8.4618 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list eks_t194_sigheader.img_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 8.4648 ] Key size is 384 bytes
[ 8.5434 ] Saving pkc public key in pub_key.key
[ 8.5409 ] tegrahost_v2 --chip 0x19 0 --updatesigheader eks_t194_sigheader.img_aligned.encrypt.signed eks_t194_sigheader.img_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 8.5492 ] tegrahost_v2 --chip 0x19 --align bpmp-2_t194_sigheader_aligned.bin
[ 8.5518 ] header_magic: 4e564441
[ 8.5630 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list bpmp-2_t194_sigheader_aligned.bin_list.xml
[ 8.5636 ] Key is a SBK key
[ 8.5636 ] Key Size is 16 bytes
[ 8.6145 ] tegrahost_v2 --chip 0x19 0 --updatesigheader bpmp-2_t194_sigheader_aligned.bin.encrypt bpmp-2_t194_sigheader_aligned.bin.hash zerosbk
[ 8.6426 ] tegrahost_v2 --chip 0x19 --align bpmp-2_t194_sigheader.bin_aligned.encrypt
[ 8.6451 ] header_magic: 4e564441
[ 8.6563 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list bpmp-2_t194_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 8.6593 ] Key size is 384 bytes
[ 8.7390 ] Saving pkc public key in pub_key.key
[ 8.7364 ] tegrahost_v2 --chip 0x19 0 --updatesigheader bpmp-2_t194_sigheader.bin_aligned.encrypt.signed bpmp-2_t194_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 8.7665 ] tegrahost_v2 --chip 0x19 --align tegra194-a02-bpmp-p2888-a04_lz4_sigheader_aligned.dtb
[ 8.7691 ] header_magic: 4e564441
[ 8.7801 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list tegra194-a02-bpmp-p2888-a04_lz4_sigheader_aligned.dtb_list.xml
[ 8.7807 ] Key is a SBK key
[ 8.7807 ] Key Size is 16 bytes
[ 8.7891 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-a02-bpmp-p2888-a04_lz4_sigheader_aligned.dtb.encrypt tegra194-a02-bpmp-p2888-a04_lz4_sigheader_aligned.dtb.hash zerosbk
[ 8.7980 ] tegrahost_v2 --chip 0x19 --align tegra194-a02-bpmp-p2888-a04_lz4_sigheader.dtb_aligned.encrypt
[ 8.8007 ] header_magic: 4e564441
[ 8.8118 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list tegra194-a02-bpmp-p2888-a04_lz4_sigheader.dtb_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 8.8147 ] Key size is 384 bytes
[ 8.8934 ] Saving pkc public key in pub_key.key
[ 8.8907 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-a02-bpmp-p2888-a04_lz4_sigheader.dtb_aligned.encrypt.signed tegra194-a02-bpmp-p2888-a04_lz4_sigheader.dtb_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 8.9002 ] tegrahost_v2 --chip 0x19 --align camera-rtcpu-t194-rce_sigheader_aligned.img
[ 8.9028 ] header_magic: 4e564441
[ 8.9139 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list camera-rtcpu-t194-rce_sigheader_aligned.img_list.xml
[ 8.9145 ] Key is a SBK key
[ 8.9145 ] Key Size is 16 bytes
[ 8.9464 ] tegrahost_v2 --chip 0x19 0 --updatesigheader camera-rtcpu-t194-rce_sigheader_aligned.img.encrypt camera-rtcpu-t194-rce_sigheader_aligned.img.hash zerosbk
[ 8.9655 ] tegrahost_v2 --chip 0x19 --align camera-rtcpu-t194-rce_sigheader.img_aligned.encrypt
[ 8.9682 ] header_magic: 4e564441
[ 8.9794 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list camera-rtcpu-t194-rce_sigheader.img_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 8.9823 ] Key size is 384 bytes
[ 9.0618 ] Saving pkc public key in pub_key.key
[ 9.0593 ] tegrahost_v2 --chip 0x19 0 --updatesigheader camera-rtcpu-t194-rce_sigheader.img_aligned.encrypt.signed camera-rtcpu-t194-rce_sigheader.img_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 9.0782 ] tegrahost_v2 --chip 0x19 --align adsp-fw_sigheader_aligned.bin
[ 9.0808 ] header_magic: 4e564441
[ 9.0918 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list adsp-fw_sigheader_aligned.bin_list.xml
[ 9.0925 ] Key is a SBK key
[ 9.0925 ] Key Size is 16 bytes
[ 9.1152 ] tegrahost_v2 --chip 0x19 0 --updatesigheader adsp-fw_sigheader_aligned.bin.encrypt adsp-fw_sigheader_aligned.bin.hash zerosbk
[ 9.1305 ] tegrahost_v2 --chip 0x19 --align adsp-fw_sigheader.bin_aligned.encrypt
[ 9.1331 ] header_magic: 4e564441
[ 9.1442 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list adsp-fw_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 9.1471 ] Key size is 384 bytes
[ 9.2262 ] Saving pkc public key in pub_key.key
[ 9.2239 ] tegrahost_v2 --chip 0x19 0 --updatesigheader adsp-fw_sigheader.bin_aligned.encrypt.signed adsp-fw_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 9.2489 ] tegrahost_v2 --chip 0x19 --align warmboot_t194_prod_sigheader_aligned.bin
[ 9.2515 ] header_magic: 4e564441
[ 9.2625 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list warmboot_t194_prod_sigheader_aligned.bin_list.xml
[ 9.2631 ] Key is a SBK key
[ 9.2631 ] Key Size is 16 bytes
[ 9.2697 ] tegrahost_v2 --chip 0x19 0 --updatesigheader warmboot_t194_prod_sigheader_aligned.bin.encrypt warmboot_t194_prod_sigheader_aligned.bin.hash zerosbk
[ 9.2776 ] tegrahost_v2 --chip 0x19 --align warmboot_t194_prod_sigheader.bin_aligned.encrypt
[ 9.2802 ] header_magic: 4e564441
[ 9.2914 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list warmboot_t194_prod_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 9.2955 ] Key size is 384 bytes
[ 9.3743 ] Saving pkc public key in pub_key.key
[ 9.3720 ] tegrahost_v2 --chip 0x19 0 --updatesigheader warmboot_t194_prod_sigheader.bin_aligned.encrypt.signed warmboot_t194_prod_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 9.3806 ] tegrahost_v2 --chip 0x19 --align mce_c10_prod_cr_sigheader_aligned.bin
[ 9.3832 ] header_magic: 4e564441
[ 9.3945 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list mce_c10_prod_cr_sigheader_aligned.bin_list.xml
[ 9.3951 ] Key is a SBK key
[ 9.3951 ] Key Size is 16 bytes
[ 9.4061 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mce_c10_prod_cr_sigheader_aligned.bin.encrypt mce_c10_prod_cr_sigheader_aligned.bin.hash zerosbk
[ 9.4167 ] tegrahost_v2 --chip 0x19 --align mce_c10_prod_cr_sigheader.bin_aligned.encrypt
[ 9.4193 ] header_magic: 4e564441
[ 9.4304 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list mce_c10_prod_cr_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 9.4333 ] Key size is 384 bytes
[ 9.5126 ] Saving pkc public key in pub_key.key
[ 9.5104 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mce_c10_prod_cr_sigheader.bin_aligned.encrypt.signed mce_c10_prod_cr_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 9.5331 ] tegrahost_v2 --chip 0x19 --align mts_c10_prod_cr_sigheader_aligned.bin
[ 9.5357 ] header_magic: 4e564441
[ 9.5468 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list mts_c10_prod_cr_sigheader_aligned.bin_list.xml
[ 9.5474 ] Key is a SBK key
[ 9.5474 ] Key Size is 16 bytes
[ 9.7193 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mts_c10_prod_cr_sigheader_aligned.bin.encrypt mts_c10_prod_cr_sigheader_aligned.bin.hash zerosbk
[ 9.8037 ] tegrahost_v2 --chip 0x19 --align mts_c10_prod_cr_sigheader.bin_aligned.encrypt
[ 9.8062 ] header_magic: 4e564441
[ 9.8172 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list mts_c10_prod_cr_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 9.8199 ] Key size is 384 bytes
[ 9.9057 ] Saving pkc public key in pub_key.key
[ 9.9031 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mts_c10_prod_cr_sigheader.bin_aligned.encrypt.signed mts_c10_prod_cr_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 10.0025 ] tegrahost_v2 --chip 0x19 --align nvdisp-init_sigheader_aligned.bin
[ 10.0051 ] header_magic: 4e564441
[ 10.0163 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list nvdisp-init_sigheader_aligned.bin_list.xml
[ 10.0169 ] Key is a SBK key
[ 10.0169 ] Key Size is 16 bytes
[ 10.1664 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvdisp-init_sigheader_aligned.bin.encrypt nvdisp-init_sigheader_aligned.bin.hash zerosbk
[ 10.2387 ] tegrahost_v2 --chip 0x19 --align nvdisp-init_sigheader.bin_aligned.encrypt
[ 10.2413 ] header_magic: 4e564441
[ 10.2524 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list nvdisp-init_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 10.2552 ] Key size is 384 bytes
[ 10.3402 ] Saving pkc public key in pub_key.key
[ 10.3376 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvdisp-init_sigheader.bin_aligned.encrypt.signed nvdisp-init_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 10.4109 ] tegrahost_v2 --chip 0x19 --align tegra194-p2888-0001-p2822-0000_sigheader_aligned.dtb
[ 10.4137 ] header_magic: 4e564441
[ 10.4249 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list tegra194-p2888-0001-p2822-0000_sigheader_aligned.dtb_list.xml
[ 10.4255 ] Key is a SBK key
[ 10.4255 ] Key Size is 16 bytes
[ 10.4530 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p2888-0001-p2822-0000_sigheader_aligned.dtb.encrypt tegra194-p2888-0001-p2822-0000_sigheader_aligned.dtb.hash zerosbk
[ 10.4872 ] tegrahost_v2 --chip 0x19 --align tegra194-p2888-0001-p2822-0000_sigheader.dtb_aligned.encrypt
[ 10.4898 ] header_magic: 4e564441
[ 10.5009 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list tegra194-p2888-0001-p2822-0000_sigheader.dtb_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 10.5037 ] Key size is 384 bytes
[ 10.5829 ] Saving pkc public key in pub_key.key
[ 10.5804 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p2888-0001-p2822-0000_sigheader.dtb_aligned.encrypt.signed tegra194-p2888-0001-p2822-0000_sigheader.dtb_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 10.5999 ] tegrahost_v2 --chip 0x19 --align tos-optee_t194_sigheader_aligned.img
[ 10.6025 ] header_magic: 4e564441
[ 10.6133 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list tos-optee_t194_sigheader_aligned.img_list.xml
[ 10.6139 ] Key is a SBK key
[ 10.6139 ] Key Size is 16 bytes
[ 10.6638 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tos-optee_t194_sigheader_aligned.img.encrypt tos-optee_t194_sigheader_aligned.img.hash zerosbk
[ 10.6921 ] tegrahost_v2 --chip 0x19 --align tos-optee_t194_sigheader.img_aligned.encrypt
[ 10.6947 ] header_magic: 4e564441
[ 10.7058 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list tos-optee_t194_sigheader.img_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 10.7087 ] Key size is 384 bytes
[ 10.7889 ] Saving pkc public key in pub_key.key
[ 10.7864 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tos-optee_t194_sigheader.img_aligned.encrypt.signed tos-optee_t194_sigheader.img_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 10.8150 ] tegrahost_v2 --chip 0x19 --align eks_t194_sigheader_aligned.img
[ 10.8176 ] header_magic: 4e564441
[ 10.8287 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list eks_t194_sigheader_aligned.img_list.xml
[ 10.8293 ] Key is a SBK key
[ 10.8293 ] Key Size is 16 bytes
[ 10.8336 ] tegrahost_v2 --chip 0x19 0 --updatesigheader eks_t194_sigheader_aligned.img.encrypt eks_t194_sigheader_aligned.img.hash zerosbk
[ 10.8406 ] tegrahost_v2 --chip 0x19 --align eks_t194_sigheader.img_aligned.encrypt
[ 10.8432 ] header_magic: 4e564441
[ 10.8543 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list eks_t194_sigheader.img_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 10.8572 ] Key size is 384 bytes
[ 10.9357 ] Saving pkc public key in pub_key.key
[ 10.9332 ] tegrahost_v2 --chip 0x19 0 --updatesigheader eks_t194_sigheader.img_aligned.encrypt.signed eks_t194_sigheader.img_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 10.9471 ] tegrahost_v2 --chip 0x19 --align bpmp-2_t194_sigheader_aligned.bin
[ 10.9498 ] header_magic: 4e564441
[ 10.9610 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list bpmp-2_t194_sigheader_aligned.bin_list.xml
[ 10.9615 ] Key is a SBK key
[ 10.9615 ] Key Size is 16 bytes
[ 11.0184 ] tegrahost_v2 --chip 0x19 0 --updatesigheader bpmp-2_t194_sigheader_aligned.bin.encrypt bpmp-2_t194_sigheader_aligned.bin.hash zerosbk
[ 11.0489 ] tegrahost_v2 --chip 0x19 --align bpmp-2_t194_sigheader.bin_aligned.encrypt
[ 11.0515 ] header_magic: 4e564441
[ 11.0626 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list bpmp-2_t194_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 11.0655 ] Key size is 384 bytes
[ 11.1616 ] Saving pkc public key in pub_key.key
[ 11.1591 ] tegrahost_v2 --chip 0x19 0 --updatesigheader bpmp-2_t194_sigheader.bin_aligned.encrypt.signed bpmp-2_t194_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 11.1894 ] tegrahost_v2 --chip 0x19 --align tegra194-a02-bpmp-p2888-a04_lz4_sigheader_aligned.dtb
[ 11.1921 ] header_magic: 4e564441
[ 11.2032 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list tegra194-a02-bpmp-p2888-a04_lz4_sigheader_aligned.dtb_list.xml
[ 11.2037 ] Key is a SBK key
[ 11.2038 ] Key Size is 16 bytes
[ 11.2123 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-a02-bpmp-p2888-a04_lz4_sigheader_aligned.dtb.encrypt tegra194-a02-bpmp-p2888-a04_lz4_sigheader_aligned.dtb.hash zerosbk
[ 11.2213 ] tegrahost_v2 --chip 0x19 --align tegra194-a02-bpmp-p2888-a04_lz4_sigheader.dtb_aligned.encrypt
[ 11.2239 ] header_magic: 4e564441
[ 11.2351 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list tegra194-a02-bpmp-p2888-a04_lz4_sigheader.dtb_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 11.2380 ] Key size is 384 bytes
[ 11.3170 ] Saving pkc public key in pub_key.key
[ 11.3145 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-a02-bpmp-p2888-a04_lz4_sigheader.dtb_aligned.encrypt.signed tegra194-a02-bpmp-p2888-a04_lz4_sigheader.dtb_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 11.3245 ] tegrahost_v2 --chip 0x19 --align camera-rtcpu-t194-rce_sigheader_aligned.img
[ 11.3272 ] header_magic: 4e564441
[ 11.3383 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list camera-rtcpu-t194-rce_sigheader_aligned.img_list.xml
[ 11.3389 ] Key is a SBK key
[ 11.3389 ] Key Size is 16 bytes
[ 11.3683 ] tegrahost_v2 --chip 0x19 0 --updatesigheader camera-rtcpu-t194-rce_sigheader_aligned.img.encrypt camera-rtcpu-t194-rce_sigheader_aligned.img.hash zerosbk
[ 11.3880 ] tegrahost_v2 --chip 0x19 --align camera-rtcpu-t194-rce_sigheader.img_aligned.encrypt
[ 11.3908 ] header_magic: 4e564441
[ 11.4020 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list camera-rtcpu-t194-rce_sigheader.img_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 11.4049 ] Key size is 384 bytes
[ 11.4843 ] Saving pkc public key in pub_key.key
[ 11.4822 ] tegrahost_v2 --chip 0x19 0 --updatesigheader camera-rtcpu-t194-rce_sigheader.img_aligned.encrypt.signed camera-rtcpu-t194-rce_sigheader.img_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 11.5043 ] tegrahost_v2 --chip 0x19 --align adsp-fw_sigheader_aligned.bin
[ 11.5070 ] header_magic: 4e564441
[ 11.5181 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list adsp-fw_sigheader_aligned.bin_list.xml
[ 11.5187 ] Key is a SBK key
[ 11.5187 ] Key Size is 16 bytes
[ 11.5421 ] tegrahost_v2 --chip 0x19 0 --updatesigheader adsp-fw_sigheader_aligned.bin.encrypt adsp-fw_sigheader_aligned.bin.hash zerosbk
[ 11.5595 ] tegrahost_v2 --chip 0x19 --align adsp-fw_sigheader.bin_aligned.encrypt
[ 11.5622 ] header_magic: 4e564441
[ 11.5734 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list adsp-fw_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 11.5762 ] Key size is 384 bytes
[ 11.6552 ] Saving pkc public key in pub_key.key
[ 11.6527 ] tegrahost_v2 --chip 0x19 0 --updatesigheader adsp-fw_sigheader.bin_aligned.encrypt.signed adsp-fw_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 11.6755 ] tegrahost_v2 --chip 0x19 --align warmboot_t194_prod_sigheader_aligned.bin
[ 11.6781 ] header_magic: 4e564441
[ 11.6893 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list warmboot_t194_prod_sigheader_aligned.bin_list.xml
[ 11.6898 ] Key is a SBK key
[ 11.6898 ] Key Size is 16 bytes
[ 11.6966 ] tegrahost_v2 --chip 0x19 0 --updatesigheader warmboot_t194_prod_sigheader_aligned.bin.encrypt warmboot_t194_prod_sigheader_aligned.bin.hash zerosbk
[ 11.7047 ] tegrahost_v2 --chip 0x19 --align warmboot_t194_prod_sigheader.bin_aligned.encrypt
[ 11.7074 ] header_magic: 4e564441
[ 11.7186 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list warmboot_t194_prod_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 11.7215 ] Key size is 384 bytes
[ 11.7999 ] Saving pkc public key in pub_key.key
[ 11.7976 ] tegrahost_v2 --chip 0x19 0 --updatesigheader warmboot_t194_prod_sigheader.bin_aligned.encrypt.signed warmboot_t194_prod_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 11.8154 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_t194_aligned.bin
[ 11.8181 ] header_magic: 50000ea
[ 11.8292 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list nvtboot_recovery_t194_aligned.bin_list.xml
[ 11.8299 ] Key is a SBK key
[ 11.8299 ] Key Size is 16 bytes
[ 11.8435 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_t194_aligned.bin.encrypt nvtboot_recovery_t194_aligned.bin.hash zerosbk
[ 11.8515 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_t194.bin_aligned.encrypt
[ 11.8540 ] header_magic: 2fb97ba0
[ 11.8580 ] tegrahost_v2 --appendsigheader nvtboot_recovery_t194.bin_aligned.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MB2B --ratchet_blob ratchet_blob.bin
[ 11.8604 ] adding BCH for nvtboot_recovery_t194.bin_aligned.encrypt
[ 11.8797 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list nvtboot_recovery_t194.bin_aligned_sigheader.encrypt_list.xml --pubkeyhash pub_key.key
[ 11.8826 ] Key size is 384 bytes
[ 11.9620 ] Saving pkc public key in pub_key.key
[ 11.9595 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_t194.bin_aligned_sigheader.encrypt.signed nvtboot_recovery_t194.bin_aligned_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 11.9710 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_cpu_t194_aligned.bin
[ 11.9737 ] header_magic: 9000014
[ 11.9851 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list nvtboot_recovery_cpu_t194_aligned.bin_list.xml
[ 11.9857 ] Key is a SBK key
[ 11.9857 ] Key Size is 16 bytes
[ 12.0006 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_cpu_t194_aligned.bin.encrypt nvtboot_recovery_cpu_t194_aligned.bin.hash zerosbk
[ 12.0086 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_cpu_t194.bin_aligned.encrypt
[ 12.0113 ] header_magic: 329de335
[ 12.0151 ] tegrahost_v2 --appendsigheader nvtboot_recovery_cpu_t194.bin_aligned.encrypt oem-rsa-sbk --chip 0x19 0 --magicid CPBL --ratchet_blob ratchet_blob.bin
[ 12.0175 ] adding BCH for nvtboot_recovery_cpu_t194.bin_aligned.encrypt
[ 12.0378 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list nvtboot_recovery_cpu_t194.bin_aligned_sigheader.encrypt_list.xml --pubkeyhash pub_key.key
[ 12.0408 ] Key size is 384 bytes
[ 12.1195 ] Saving pkc public key in pub_key.key
[ 12.1171 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_cpu_t194.bin_aligned_sigheader.encrypt.signed nvtboot_recovery_cpu_t194.bin_aligned_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 12.1249 ] Copying signed file in /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/encrypted_signed_t19x
[ 12.1260 ] Parsing dev params for multi chains
[ 12.1260 ] Generating br-bct
[ 12.1299 ] Performing cfg overlay
[ 12.1299 ] ['/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1.cfg']
[ 12.1300 ] Updating dev and MSS params in BR BCT
[ 12.1301 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 12.2853 ] Updating bl info
[ 12.2898 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 12.2952 ] Generating br-bct
[ 12.2991 ] Performing cfg overlay
[ 12.2991 ] ['/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1.cfg']
[ 12.2992 ] Updating dev and MSS params in BR BCT
[ 12.2993 ] tegrabct_v2 --dev_param tegra194-br-bct_b-sdmmc.cfg --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 12.4564 ] Updating bl info
[ 12.4606 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 12.4651 ] Generating BCT backup image
[ 12.4652 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 12.4677 ] 记录了32768+0 的读入
[ 12.6340 ] 记录了32768+0 的写出
[ 12.6341 ] 32768字节(33 kB,32 KiB)已复制,0.165442 s,198 kB/s
[ 12.6341 ]
[ 12.6341 ] Concatenating BCT for chain A to bct_backup.img
[ 12.6342 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 12.6371 ] 记录了2888+0 的读入
[ 12.6501 ] 记录了2888+0 的写出
[ 12.6502 ] 2888字节(2.9 kB,2.8 KiB)已复制,0.0122251 s,236 kB/s
[ 12.6502 ]
[ 12.6502 ] Concatenating BCT for chain B to bct_backup.img
[ 12.6503 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 12.6533 ] 记录了2888+0 的读入
[ 12.6664 ] 记录了2888+0 的写出
[ 12.6664 ] 2888字节(2.9 kB,2.8 KiB)已复制,0.0122824 s,235 kB/s
[ 12.6664 ]
[ 12.6665 ] Parsing dev params for multi chains
[ 12.6665 ] Generating br-bct
[ 12.6707 ] Performing cfg overlay
[ 12.6707 ] ['/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1.cfg']
[ 12.6708 ] Updating dev and MSS params in BR BCT
[ 12.6709 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 12.8252 ] Updating bl info
[ 12.8292 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 12.8381 ] Updating smd info
[ 12.8420 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 12.8448 ] Updating Odmdata
[ 12.8486 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0x9190000
[ 12.8516 ] Get encrypted section of bct
[ 12.8555 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listencbct bct_list.xml
[ 12.8582 ] Signing BCT
[ 12.8582 ] Generating signatures with encryption
[ 12.8690 ] tegrasign_v3.py --file br_bct_BR.bct --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --offset 2328
[ 12.8696 ] Key is a SBK key
[ 12.8696 ] Key Size is 16 bytes
[ 12.8694 ] Updating BCT with signature
[ 12.8700 ] Get Signed section of bct
[ 12.8740 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 12.8877 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list bct_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[ 12.8907 ] Key size is 384 bytes
[ 12.9736 ] Saving pkc public key in pub_key.key
[ 12.9737 ] Saving Montgomery values in montgomery.bin
[ 12.9670 ] Updating BCT with signature
[ 12.9710 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 12.9778 ] Generating br-bct
[ 12.9818 ] Performing cfg overlay
[ 12.9819 ] ['/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1.cfg']
[ 12.9819 ] Updating dev and MSS params in BR BCT
[ 12.9820 ] tegrabct_v2 --dev_param tegra194-br-bct_b-sdmmc.cfg --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 13.1307 ] Updating bl info
[ 13.1345 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 13.1485 ] Updating smd info
[ 13.1526 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 13.1555 ] Updating Odmdata
[ 13.1593 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0x9190000
[ 13.1621 ] Get encrypted section of bct
[ 13.1660 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listencbct bct_list.xml
[ 13.1687 ] Signing BCT
[ 13.1688 ] Generating signatures with encryption
[ 13.1794 ] tegrasign_v3.py --file br_bct_BR.bct --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --offset 2328
[ 13.1800 ] Key is a SBK key
[ 13.1801 ] Key Size is 16 bytes
[ 13.1799 ] Updating BCT with signature
[ 13.1805 ] Get Signed section of bct
[ 13.1844 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 13.1980 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list bct_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[ 13.2009 ] Key size is 384 bytes
[ 13.2836 ] Saving pkc public key in pub_key.key
[ 13.2837 ] Saving Montgomery values in montgomery.bin
[ 13.2770 ] Updating BCT with signature
[ 13.2810 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 13.2881 ] Generating BCT backup image
[ 13.2882 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 13.2910 ] 记录了32768+0 的读入
[ 13.4570 ] 记录了32768+0 的写出
[ 13.4570 ] 32768字节(33 kB,32 KiB)已复制,0.165246 s,198 kB/s
[ 13.4571 ]
[ 13.4571 ] Concatenating BCT for chain A to bct_backup.img
[ 13.4572 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 13.4602 ] 记录了2888+0 的读入
[ 13.4733 ] 记录了2888+0 的写出
[ 13.4733 ] 2888字节(2.9 kB,2.8 KiB)已复制,0.0122659 s,235 kB/s
[ 13.4733 ]
[ 13.4734 ] Concatenating BCT for chain B to bct_backup.img
[ 13.4734 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 13.4765 ] 记录了2888+0 的读入
[ 13.4896 ] 记录了2888+0 的写出
[ 13.4896 ] 2888字节(2.9 kB,2.8 KiB)已复制,0.012298 s,235 kB/s
[ 13.4896 ]
[ 13.4897 ] Generating coldboot mb1-bct
[ 13.4948 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[ 13.4973 ] MB1-BCT version: 0x1
[ 13.4979 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 13.4990 ] Added Platform Config 0 data with size :- 3168
[ 13.5035 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 13.5043 ] Added Platform Config 1 data with size :- 19640
[ 13.5396 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 13.5406 ] Added Platform Config 2 data with size :- 24
[ 13.5412 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[ 13.5424 ] File read failed
[ 13.5426 ] File read failed
[ 13.5429 ] Added Platform Config 4 data with size :- 348
[ 13.5434 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 13.5443 ] Added Platform Config 3 data with size :- 92
[ 13.5448 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 13.5457 ] Added Platform Config 5 data with size :- 68
[ 13.5465 ]
[ 13.5465 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 13.5465 ] Added Platform Config 7 data with size :- 392
[ 13.5465 ]
[ 13.5465 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 13.5465 ] Added Platform Config 8 data with size :- 12
[ 13.5465 ]
[ 13.5465 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 13.5465 ] Added Platform Config 9 data with size :- 32
[ 13.5465 ]
[ 13.5466 ] Updating mb1-bct with firmware information
[ 13.5505 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 13.5536 ] Updating mb1-bct with storage information
[ 13.5575 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 13.5608 ] Updating mb1-bct with ratchet information
[ 13.5647 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 13.5671 ] FwIndex: 1, MinRatchetLevel: 0
[ 13.5678 ] FwIndex: 2, MinRatchetLevel: 0
[ 13.5678 ] FwIndex: 3, MinRatchetLevel: 0
[ 13.5679 ] FwIndex: 4, MinRatchetLevel: 0
[ 13.5679 ] FwIndex: 5, MinRatchetLevel: 0
[ 13.5679 ] FwIndex: 6, MinRatchetLevel: 0
[ 13.5679 ] FwIndex: 7, MinRatchetLevel: 0
[ 13.5679 ] FwIndex: 11, MinRatchetLevel: 0
[ 13.5679 ] FwIndex: 12, MinRatchetLevel: 0
[ 13.5679 ] FwIndex: 13, MinRatchetLevel: 0
[ 13.5679 ] FwIndex: 14, MinRatchetLevel: 0
[ 13.5679 ] FwIndex: 15, MinRatchetLevel: 0
[ 13.5680 ] FwIndex: 16, MinRatchetLevel: 0
[ 13.5680 ] FwIndex: 17, MinRatchetLevel: 0
[ 13.5680 ] FwIndex: 18, MinRatchetLevel: 0
[ 13.5680 ] FwIndex: 19, MinRatchetLevel: 0
[ 13.5680 ] FwIndex: 30, MinRatchetLevel: 0
[ 13.5680 ] FwIndex: 31, MinRatchetLevel: 0
[ 13.5680 ]
[ 13.5727 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 13.5783 ] header_magic: 30690000
[ 13.5908 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list mb1_cold_boot_bct_MB1_aligned.bct_list.xml
[ 13.5914 ] Key is a SBK key
[ 13.5915 ] Key Size is 16 bytes
[ 13.5974 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned.bct.encrypt mb1_cold_boot_bct_MB1_aligned.bct.hash zerosbk
[ 13.6045 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct_aligned.encrypt
[ 13.6072 ] header_magic: de4c39e7
[ 13.6109 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct_aligned.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin
[ 13.6133 ] adding BCH for mb1_cold_boot_bct_MB1.bct_aligned.encrypt
[ 13.6266 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list mb1_cold_boot_bct_MB1.bct_aligned_sigheader.encrypt_list.xml --pubkeyhash pub_key.key
[ 13.6300 ] Key size is 384 bytes
[ 13.7084 ] Saving pkc public key in pub_key.key
[ 13.7061 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1.bct_aligned_sigheader.encrypt.signed mb1_cold_boot_bct_MB1.bct_aligned_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 13.7101 ] Generating recovery mb1-bct
[ 13.7144 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[ 13.7167 ] MB1-BCT version: 0x1
[ 13.7173 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 13.7184 ] Added Platform Config 0 data with size :- 3168
[ 13.7227 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 13.7235 ] Added Platform Config 1 data with size :- 19640
[ 13.7588 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 13.7598 ] Added Platform Config 2 data with size :- 24
[ 13.7604 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[ 13.7614 ] File read failed
[ 13.7616 ] File read failed
[ 13.7619 ] Added Platform Config 4 data with size :- 348
[ 13.7625 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 13.7635 ] Added Platform Config 3 data with size :- 92
[ 13.7640 ]
[ 13.7640 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 13.7640 ] Added Platform Config 5 data with size :- 68
[ 13.7640 ]
[ 13.7640 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 13.7640 ] Added Platform Config 7 data with size :- 392
[ 13.7641 ]
[ 13.7641 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 13.7641 ] Added Platform Config 8 data with size :- 12
[ 13.7641 ]
[ 13.7641 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 13.7641 ] Added Platform Config 9 data with size :- 32
[ 13.7641 ]
[ 13.7642 ] Updating mb1-bct with firmware information
[ 13.7682 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[ 13.7766 ] Updating mb1-bct with storage information
[ 13.7806 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 13.7853 ] Updating mb1-bct with ratchet information
[ 13.7895 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 13.7921 ] FwIndex: 1, MinRatchetLevel: 0
[ 13.7928 ] FwIndex: 2, MinRatchetLevel: 0
[ 13.7928 ] FwIndex: 3, MinRatchetLevel: 0
[ 13.7928 ] FwIndex: 4, MinRatchetLevel: 0
[ 13.7928 ] FwIndex: 5, MinRatchetLevel: 0
[ 13.7928 ] FwIndex: 6, MinRatchetLevel: 0
[ 13.7928 ] FwIndex: 7, MinRatchetLevel: 0
[ 13.7928 ] FwIndex: 11, MinRatchetLevel: 0
[ 13.7928 ] FwIndex: 12, MinRatchetLevel: 0
[ 13.7928 ] FwIndex: 13, MinRatchetLevel: 0
[ 13.7929 ] FwIndex: 14, MinRatchetLevel: 0
[ 13.7929 ] FwIndex: 15, MinRatchetLevel: 0
[ 13.7929 ] FwIndex: 16, MinRatchetLevel: 0
[ 13.7929 ] FwIndex: 17, MinRatchetLevel: 0
[ 13.7929 ] FwIndex: 18, MinRatchetLevel: 0
[ 13.7929 ] FwIndex: 19, MinRatchetLevel: 0
[ 13.7929 ] FwIndex: 30, MinRatchetLevel: 0
[ 13.7929 ] FwIndex: 31, MinRatchetLevel: 0
[ 13.7929 ]
[ 13.7977 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1_aligned.bct
[ 13.8034 ] header_magic: 30690000
[ 13.8178 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list mb1_bct_MB1_aligned.bct_list.xml
[ 13.8190 ] Key is a SBK key
[ 13.8191 ] Key Size is 16 bytes
[ 13.8360 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_aligned.bct.encrypt mb1_bct_MB1_aligned.bct.hash zerosbk
[ 13.8455 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct_aligned.encrypt
[ 13.8488 ] header_magic: de4c39e7
[ 13.8527 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct_aligned.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin
[ 13.8551 ] adding BCH for mb1_bct_MB1.bct_aligned.encrypt
[ 13.8676 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list mb1_bct_MB1.bct_aligned_sigheader.encrypt_list.xml --pubkeyhash pub_key.key
[ 13.8707 ] Key size is 384 bytes
[ 13.9496 ] Saving pkc public key in pub_key.key
[ 13.9472 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1.bct_aligned_sigheader.encrypt.signed mb1_bct_MB1.bct_aligned_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 13.9512 ] Generating coldboot mem-bct
[ 13.9552 ] tegrabct_v2 --chip 0x19 0 --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1.cfg --membct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1_1.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1_2.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1_3.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1_4.bct
[ 13.9576 ] Packing sdram param for instance[0]
[ 14.1049 ] Packing sdram param for instance[1]
[ 14.1054 ] Packing sdram param for instance[2]
[ 14.1059 ] Packing sdram param for instance[3]
[ 14.1064 ] Packing sdram param for instance[4]
[ 14.1064 ] Packing sdram param for instance[5]
[ 14.1064 ] Packing sdram param for instance[6]
[ 14.1064 ] Packing sdram param for instance[7]
[ 14.1064 ] Packing sdram param for instance[8]
[ 14.1064 ] Packing sdram param for instance[9]
[ 14.1064 ] Packing sdram param for instance[10]
[ 14.1065 ] Packing sdram param for instance[11]
[ 14.1065 ] Packing sdram param for instance[12]
[ 14.1065 ] Packing sdram param for instance[13]
[ 14.1065 ] Packing sdram param for instance[14]
[ 14.1065 ] Packing sdram param for instance[15]
[ 14.1065 ]
[ 14.1066 ] Getting sector size from pt
[ 14.1108 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 14.1139 ] BlockSize read from layout is 200
[ 14.1248 ] tegrasign_v3.py --file /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1_1.bct --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt
[ 14.1254 ] Key is a SBK key
[ 14.1255 ] Key Size is 16 bytes
[ 14.1386 ] tegrasign_v3.py --file /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1_2.bct --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt
[ 14.1392 ] Key is a SBK key
[ 14.1392 ] Key Size is 16 bytes
[ 14.1522 ] tegrasign_v3.py --file /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1_3.bct --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt
[ 14.1528 ] Key is a SBK key
[ 14.1528 ] Key Size is 16 bytes
[ 14.1659 ] tegrasign_v3.py --file /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1_4.bct --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt
[ 14.1664 ] Key is a SBK key
[ 14.1665 ] Key Size is 16 bytes
[ 14.1725 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1_1_encrypt.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1_2_encrypt.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1_3_encrypt.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1_4_encrypt.bct
[ 14.1750 ] adding BCH for /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1_1_encrypt.bct
[ 14.1841 ] tegrahost_v2 --chip 0x19 --align mem_coldboot_aligned.bct
[ 14.1868 ] header_magic: 4e564441
[ 14.1980 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list mem_coldboot_aligned.bct_list.xml --pubkeyhash pub_key.key
[ 14.2009 ] Key size is 384 bytes
[ 14.2979 ] Saving pkc public key in pub_key.key
[ 14.2955 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_aligned.bct.signed mem_coldboot_aligned.bct.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 14.3038 ] tegrahost_v2 --chip 0x19 --align mem_coldboot_aligned.bct
[ 14.3104 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct oem-rsa
[ 14.3129 ] Header already present for mem_coldboot_aligned.bct
[ 14.3253 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list mem_coldboot_aligned_sigheader.bct_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[ 14.3282 ] Key size is 384 bytes
[ 14.4119 ] Saving pkc public key in pub_key.key
[ 14.4119 ] Saving Montgomery values in montgomery.bin
[ 14.4095 ] tegrahost_v2 --chip 0x19 0 --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin --updatesigheader mem_coldboot_aligned_sigheader.bct.signed mem_coldboot_aligned_sigheader.bct.sig oem-rsa
[ 14.4134 ] Generating recovery mem-bct
[ 14.4173 ] tegrabct_v2 --chip 0x19 0 --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1.cfg --membct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1_1.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1_2.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1_3.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/92917/tmpna1eoomi1_4.bct
[ 14.4197 ] Packing sdram param for instance[0]
[ 14.5665 ] Packing sdram param for instance[1]
[ 14.5670 ] Packing sdram param for instance[2]
[ 14.5676 ] Packing sdram param for instance[3]
[ 14.5682 ] Packing sdram param for instance[4]
[ 14.5683 ] Packing sdram param for instance[5]
[ 14.5683 ] Packing sdram param for instance[6]
[ 14.5683 ] Packing sdram param for instance[7]
[ 14.5683 ] Packing sdram param for instance[8]
[ 14.5683 ] Packing sdram param for instance[9]
[ 14.5683 ] Packing sdram param for instance[10]
[ 14.5683 ] Packing sdram param for instance[11]
[ 14.5683 ] Packing sdram param for instance[12]
[ 14.5684 ] Packing sdram param for instance[13]
[ 14.5684 ] Packing sdram param for instance[14]
[ 14.5684 ] Packing sdram param for instance[15]
[ 14.5684 ]
[ 14.5733 ] tegrahost_v2 --chip 0x19 --align mem_rcm_aligned.bct
[ 14.5760 ] header_magic: 3000000
[ 14.5872 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/sbk.txt --list mem_rcm_aligned.bct_list.xml
[ 14.5877 ] Key is a SBK key
[ 14.5878 ] Key Size is 16 bytes
[ 14.5944 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_aligned.bct.encrypt mem_rcm_aligned.bct.hash zerosbk
[ 14.6016 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct_aligned.encrypt
[ 14.6045 ] header_magic: 27624384
[ 14.6085 ] tegrahost_v2 --appendsigheader mem_rcm.bct_aligned.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin
[ 14.6108 ] adding BCH for mem_rcm.bct_aligned.encrypt
[ 14.6249 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list mem_rcm.bct_aligned_sigheader.encrypt_list.xml --pubkeyhash pub_key.key
[ 14.6320 ] Key size is 384 bytes
[ 14.7225 ] Saving pkc public key in pub_key.key
[ 14.7199 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm.bct_aligned_sigheader.encrypt.signed mem_rcm.bct_aligned_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 14.7243 ] Copying br bct for multi chains
[ 14.7245 ] Signed BCT for boot chain A is copied to /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/encrypted_signed_t19x/br_bct_BR.bct
[ 14.7247 ] Signed BCT for boot chain B is copied to /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/encrypted_signed_t19x/br_bct_b_BR.bct
[ 14.7247 ] Copying BCT backup image bct_backup.img to /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/encrypted_signed_t19x/bct_backup.img
[ 14.7257 ] nvtboot_recovery_t194.bin_sigheader.encrypt.signed
[ 14.7260 ] preboot_c10_prod_cr.bin
[ 14.7262 ] mce_c10_prod_cr.bin
[ 14.7265 ] mts_c10_prod_cr.bin
[ 14.7301 ] bpmp-2_t194.bin
[ 14.7313 ] tegra194-a02-bpmp-p2888-a04_lz4.dtb
[ 14.7316 ] spe_t194.bin
[ 14.7318 ] tos-optee_t194.img
[ 14.7329 ] eks_t194.img
[ 14.7330 ] tegra194-p2888-0001-p2822-0000.dtb
[ 14.7336 ] nvtboot_recovery_cpu_t194.bin_sigheader.encrypt.signed
[ 14.7385 ] tegrahost_v2 --chip 0x19 --align mb1_t194_prod_sigheader.bin_aligned.encrypt
[ 14.7413 ] header_magic: 4e564441
[ 14.7526 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/uefi_keys/rsa_3k.pem --list mb1_t194_prod_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 14.7556 ] Key size is 384 bytes
[ 14.8339 ] Saving pkc public key in pub_key.key
[ 14.8315 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin_aligned.encrypt.signed mb1_t194_prod_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 14.8489 ] tegraparser_v2 --generategpt --pt flash.xml.bin
[ 14.8514 ] gpt_secondary_0_3.bin:
[ 14.8520 ] partition_id partition_name StartingLba EndingLba
[ 14.8528 ] 1 BCT 0 63
[ 14.8537 ] 2 mb1 64 575
[ 14.8547 ] 3 mb1_b 576 1087
[ 14.8556 ] 4 MB1_BCT 1088 1215
[ 14.8566 ] 5 MEM_BCT 1216 1663
[ 14.8575 ] 6 spe-fw 1664 2175
[ 14.8585 ] 7 mb2 2176 2623
[ 14.8595 ] 8 mts-preboot 2624 2687
[ 14.8604 ] 9 reserved_for_chain_A_boot 2688 6783
[ 14.8614 ] 10 MB1_BCT_b 6784 6911
[ 14.8624 ] 11 MEM_BCT_b 6912 7359
[ 14.8634 ] 12 spe-fw_b 7360 7871
[ 14.8643 ] 13 mb2_b 7872 8319
[ 14.8653 ] 14 mts-preboot_b 8320 8383
[ 14.8663 ] 15 reserved_for_chain_B_boot 8384 12479
[ 14.8673 ] 16 BCT-boot-chain_backup 15616 15743
[ 14.8680 ] 17 reserved_partition 15744 15871
[ 14.8680 ] 18 secondary_gpt_backup 15872 15999
[ 14.8680 ] 19 VER_b 16000 16127
[ 14.8680 ] 20 VER 16128 16255
[ 14.8681 ] gpt_primary_1_3.bin:
[ 14.8681 ] partition_id partition_name StartingLba EndingLba
[ 14.8681 ] 1 APP 40 58720295
[ 14.8681 ] 2 mts-mce 58720296 58720615
[ 14.8681 ] 3 mts-proper 58720616 58728807
[ 14.8681 ] 4 cpu-bootloader 58728808 58736999
[ 14.8681 ] 5 bootloader-dtb 58737000 58738023
[ 14.8681 ] 6 secure-os 58738024 58743143
[ 14.8681 ] 7 eks 58743144 58743271
[ 14.8682 ] 8 bpmp-fw 58743272 58746343
[ 14.8682 ] 9 bpmp-fw-dtb 58746344 58748391
[ 14.8682 ] 10 xusb-fw 58748392 58748711
[ 14.8682 ] 11 rce-fw 58748712 58752807
[ 14.8682 ] 12 adsp-fw 58752808 58756903
[ 14.8682 ] 13 sce-fw 58756904 58758951
[ 14.8682 ] 14 sc7 58758952 58759207
[ 14.8682 ] 15 kernel 58759208 58923047
[ 14.8683 ] 16 kernel-dtb 58923048 58924071
[ 14.8683 ] 17 reserved_for_chain_A_user 58924072 58989607
[ 14.8683 ] 18 mts-mce_b 58990592 58990911
[ 14.8683 ] 19 mts-proper_b 58990912 58999103
[ 14.8683 ] 20 cpu-bootloader_b 58999104 59007295
[ 14.8683 ] 21 bootloader-dtb_b 59007296 59008319
[ 14.8683 ] 22 secure-os_b 59008320 59013439
[ 14.8683 ] 23 eks_b 59013440 59013567
[ 14.8683 ] 24 bpmp-fw_b 59013568 59016639
[ 14.8684 ] 25 bpmp-fw-dtb_b 59016640 59018687
[ 14.8684 ] 26 xusb-fw_b 59018688 59019007
[ 14.8684 ] 27 rce-fw_b 59019008 59023103
[ 14.8684 ] 28 adsp-fw_b 59023104 59027199
[ 14.8684 ] 29 sce-fw_b 59027200 59029247
[ 14.8684 ] 30 sc7_b 59029248 59029503
[ 14.8684 ] 31 kernel_b 59029504 59193343
[ 14.8684 ] 32 kernel-dtb_b 59193344 59194367
[ 14.8685 ] 33 reserved_for_chain_B_user 59194368 59260927
[ 14.8685 ] 34 recovery 59260928 59424767
[ 14.8685 ] 35 recovery-dtb 59424768 59425791
[ 14.8685 ] 36 RP1 59425792 59442175
[ 14.8685 ] 37 RP2 59442176 59458559
[ 14.8685 ] 38 RECROOTFS 59458560 60072959
[ 14.8685 ] 39 uefi_variables 60072960 60073215
[ 14.8685 ] 40 esp 60073216 60204287
[ 14.8686 ] 41 recovery_alt 60204288 60368127
[ 14.8686 ] 42 recovery-dtb_alt 60368128 60369151
[ 14.8686 ] 43 esp_alt 60369152 60500223
[ 14.8686 ] 44 UDA 60500224 61079518
[ 14.8686 ] gpt_secondary_1_3.bin:
[ 14.8686 ] partition_id partition_name StartingLba EndingLba
[ 14.8686 ] 1 APP 40 58720295
[ 14.8686 ] 2 mts-mce 58720296 58720615
[ 14.8686 ] 3 mts-proper 58720616 58728807
[ 14.8687 ] 4 cpu-bootloader 58728808 58736999
[ 14.8687 ] 5 bootloader-dtb 58737000 58738023
[ 14.8687 ] 6 secure-os 58738024 58743143
[ 14.8687 ] 7 eks 58743144 58743271
[ 14.8687 ] 8 bpmp-fw 58743272 58746343
[ 14.8687 ] 9 bpmp-fw-dtb 58746344 58748391
[ 14.8687 ] 10 xusb-fw 58748392 58748711
[ 14.8687 ] 11 rce-fw 58748712 58752807
[ 14.8688 ] 12 adsp-fw 58752808 58756903
[ 14.8688 ] 13 sce-fw 58756904 58758951
[ 14.8688 ] 14 sc7 58758952 58759207
[ 14.8688 ] 15 kernel 58759208 58923047
[ 14.8688 ] 16 kernel-dtb 58923048 58924071
[ 14.8688 ] 17 reserved_for_chain_A_user 58924072 58989607
[ 14.8688 ] 18 mts-mce_b 58990592 58990911
[ 14.8688 ] 19 mts-proper_b 58990912 58999103
[ 14.8688 ] 20 cpu-bootloader_b 58999104 59007295
[ 14.8689 ] 21 bootloader-dtb_b 59007296 59008319
[ 14.8689 ] 22 secure-os_b 59008320 59013439
[ 14.8689 ] 23 eks_b 59013440 59013567
[ 14.8689 ] 24 bpmp-fw_b 59013568 59016639
[ 14.8689 ] 25 bpmp-fw-dtb_b 59016640 59018687
[ 14.8689 ] 26 xusb-fw_b 59018688 59019007
[ 14.8689 ] 27 rce-fw_b 59019008 59023103
[ 14.8689 ] 28 adsp-fw_b 59023104 59027199
[ 14.8690 ] 29 sce-fw_b 59027200 59029247
[ 14.8690 ] 30 sc7_b 59029248 59029503
[ 14.8690 ] 31 kernel_b 59029504 59193343
[ 14.8690 ] 32 kernel-dtb_b 59193344 59194367
[ 14.8690 ] 33 reserved_for_chain_B_user 59194368 59260927
[ 14.8690 ] 34 recovery 59260928 59424767
[ 14.8690 ] 35 recovery-dtb 59424768 59425791
[ 14.8690 ] 36 RP1 59425792 59442175
[ 14.8690 ] 37 RP2 59442176 59458559
[ 14.8691 ] 38 RECROOTFS 59458560 60072959
[ 14.8691 ] 39 uefi_variables 60072960 60073215
[ 14.8691 ] 40 esp 60073216 60204287
[ 14.8691 ] 41 recovery_alt 60204288 60368127
[ 14.8691 ] 42 recovery-dtb_alt 60368128 60369151
[ 14.8691 ] 43 esp_alt 60369152 60500223
[ 14.8691 ] 44 UDA 60500224 61079518
[ 14.8691 ]
[ 14.8836 ] tegraparser_v2 --pt flash.xml.bin --generateflashindex /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/encrypted_signed_t19x/flash.xml.tmp flash.idx
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin_sigheader.encrypt.signed --bct br_bct_BR.bct --bldtb tegra194-p2888-0001-p2822-0000.dtb --applet rcm_2_signed.rcm --applet_softfuse rcm_1_signed.rcm --cmd "secureflash;reboot" --cfg secureflash.xml --chip 0x19 --mb1_bct mb1_bct_MB1.bct_sigheader.encrypt.signed --mem_bct mem_rcm.bct_sigheader.encrypt.signed --mb1_cold_boot_bct mb1_cold_boot_bct_MB1.bct_sigheader.encrypt.signed --mem_bct_cold_boot mem_coldboot_sigheader.bct.signed --bins "mb2_bootloader nvtboot_recovery_t194.bin_sigheader.encrypt.signed; mts_preboot preboot_c10_prod_cr_sigheader.bin.encrypt.signed; mts_mce mce_c10_prod_cr_sigheader.bin.encrypt.signed; mts_proper mts_c10_prod_cr_sigheader.bin.encrypt.signed; bpmp_fw bpmp-2_t194_sigheader.bin.encrypt.signed; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a04_lz4_sigheader.dtb.encrypt.signed; spe_fw spe_t194_sigheader.bin.encrypt.signed; tos tos-optee_t194_sigheader.img.encrypt.signed; eks eks_t194_sigheader.img.encrypt.signed; bootloader_dtb tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt.signed" --skipuid --secondary_gpt_backup --bct_backup
saving flash command in flashcmd.txt
*** no-flash flag enabled. Exiting now... ***
User can run above saved command in factory environment without
providing pkc and sbk keys to flash a device
Example:
$ cd bootloader
$ sudo bash ./flashcmd.txt
work@E470c:~/nvidia/35.4.1/Linux_for_Tegra$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 5986:110f Acer, Inc Integrated Camera
Bus 001 Device 002: ID 0cf3:e500 Qualcomm Atheros Communications
Bus 001 Device 004: ID 046d:c542 Logitech, Inc. Wireless Receiver
Bus 001 Device 030: ID 0955:7019 NVIDIA Corp. APX
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
work@E470c:~/nvidia/35.4.1/Linux_for_Tegra$ cd bootloader/
work@E470c:~/nvidia/35.4.1/Linux_for_Tegra/bootloader$ sudo bash ./flashcmd.txt
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0452 ] Parsing partition layout
[ 0.0484 ] tegraparser_v2 --pt secureflash.xml.tmp
[ 0.0512 ] Boot Rom communication
[ 0.0543 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_1_signed.rcm --rcm rcm_2_signed.rcm
[ 0.0559 ] BR_CID: 0x88021911643171840800000010ff8180
[ 0.0838 ] Bootrom returned error 22
[ 0.1474 ] Boot Rom communication failed
[ 0.1474 ]
Error: Return value 22
Command tegrarcm_v2 --chip 0x19 0 --rcm rcm_1_signed.rcm --rcm rcm_2_signed.rcm
hi Jerry,
Sorry, I may have made a mistake in expressing myself. I will use sudo first/ Odmfuse.sh - X uefi_ Keys/rsa_ 3k.xml - i 0x19 Jetson agx xavier devkit burned xavier, uefi_ Keys/rsa_ The content of the 3k.xml file is
<genericfuse MagicId="0x45535546" version="1.0.0">
<fuse name="PublicKeyHash" size="32" value="0xe297bd68a275dc373dbec6f9cdbdabca9a690e3d32f3261bcb8aa6422a389adf"/>
<fuse name="Kek0" size="16" value="0x112233445566778899AABBCCDDEEFF00"/>
<fuse name="Kek1" size="16" value="0x123456789ABCDEF0FEDCBA9876543210"/>
<fuse name="SecureBootKey" size="16" value="0x123456789ABCDEF0FEDCBA9876543210"/>
</genericfuse>
I can still execute this command on the same board, but modify uefi_ Keys/rsa_3k.xml The content of is as follows
<fuse name="BootSecurityInfo" size="4" value="0x06"/>
<fuse name="SecurityMode" size="4" value="0x1"/>
</genericfuse>
Is this operation correct? Do you need to add any additional modifications to uefi_ Keys/rsa_3k.xml?
hello Youke,
may I know what’s your host environment, is it still a virtual machine?
I can tell the image blob has created, but there’s USB communication issue with… Boot Rom communication failed
error report.
you may add the fuse before SecurityMode
has burned,
please note that (as mentioned before), the recommended way is to burn all fuses together instead of burning fuses step-by-step.
hi Jerry,
After your reminder, the host environment I will use in the future is ubuntu20.04
You can see the output of lsusb, and I think the USB has been properly connected
hi Jerry,
I understand. May I ask how to query the current fuse data? I believe that my previous burning was unsuccessful, and I would like to confirm that as mentioned earlier, I am currently unable to use odmfuseread.sh to read the key
thanks
hello Youke,
it’s confirmed odmfuseread has worked normally.
we’ve also checked for reading fuse value by using r35.4.1 on a SBKPKC Xavier-NX.
is your target really fused with PKC+SBK?
you may also give it a try to remove the "-k"
and "-S"
options from your command-line and try again.
hi Jerry,
I don’t confirm this, I executed the burn-in command as: sudo ./odmfuse.sh -X uefi_keys/rsa_3k.xml -i 0x19 jetson-agx-xavier-devkit
The execution log is as in the previous post, please help to confirm if burning in the fuse was successful.
I didn’t use the -k, -S option while burning fuses, what is the retry command, please give an example,
thanks.
Hi all,
Is there a solution for this?
thanks,
I meant remove the "-k"
and "-S"
options from your odmfuseread
command-line to parse fuse values.
Hi Jerry,
I re-executed odmfuseread.sh without the -k, -S parameters with the following results, can you confirm if I burned in the fuse successfully?
Bus 001 Device 004: ID 0955:7019 NVIDIA Corp. APX
work@E470c:~/nvidia/35.4.1/Linux_for_Tegra$ sudo ./odmfuseread.sh -i 0x19 jetson-agx-xavier-devkit
[sudo] work 的密码:
copying soft_fuses(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
version 1.0.0
[ 0.0595 ] Generating RCM messages
[ 0.0625 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[ 0.0640 ] Header already present for /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[ 0.0820 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0826 ] Assuming zero filled SBK key
[ 0.0860 ] tegrasign_v3.py --file /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[ 0.0865 ] Assuming zero filled SBK key
[ 0.1016 ] Warning: pub_key.key is not found
[ 0.1035 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[ 0.1245 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[ 0.1337 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[ 0.1356 ] RCM 0 is saved as rcm_0.rcm
[ 0.1420 ] RCM 1 is saved as rcm_1.rcm
[ 0.1428 ] RCM 2 is saved as rcm_2.rcm
[ 0.1428 ] List of rcm files are saved in rcm_list.xml
[ 0.1428 ]
[ 0.1429 ] Signing RCM messages
[ 0.1507 ] tegrasign_v3.py --key None --list rcm_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[ 0.1512 ] Assuming zero filled SBK key
[ 0.1630 ] Warning: pub_key.key is not found
[ 0.1591 ] Copying signature to RCM mesages
[ 0.1627 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.1662 ] Boot Rom communication
[ 0.1697 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[ 0.1717 ] RCM version 0X190001
[ 0.1986 ] Boot Rom communication completed
[ 2.2242 ] tegrarcm_v2 --isapplet
[ 2.2262 ] Applet version 01.00.0000
[ 2.3196 ] tegrarcm_v2 --ismb2
[ 2.4255 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194_aligned.bin
[ 2.4384 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194_aligned.bin zerosbk
[ 2.4433 ] adding BCH for nvtboot_applet_t194_aligned.bin
[ 2.4709 ] tegrasign_v3.py --key None --list nvtboot_applet_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 2.4721 ] Assuming zero filled SBK key
[ 2.4806 ] Warning: pub_key.key is not found
[ 2.4830 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_aligned_sigheader.bin.encrypt nvtboot_applet_t194_aligned_sigheader.bin.hash zerosbk
[ 2.4997 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[ 2.5034 ] Applet version 01.00.0000
[ 2.5798 ] Sending mb2
[ 2.5804 ] [................................................] 100%
[ 2.6025 ] tegrarcm_v2 --boot recovery
[ 2.6069 ] Applet version 01.00.0000
[ 3.6992 ] tegrarcm_v2 --isapplet
[ 3.7898 ] tegrarcm_v2 --ismb2
[ 3.7914 ] MB2 Applet version 01.00.0000
[ 3.8780 ] tegrarcm_v2 --ismb2
[ 3.8838 ] MB2 Applet version 01.00.0000
[ 3.9701 ] Retrieving board information
[ 3.9780 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[ 3.9834 ] MB2 Applet version 01.00.0000
[ 4.0636 ] Saved platform info in chip_info.bin
[ 4.0680 ] Chip minor revision: 2
[ 4.0684 ] Bootrom revision: 0xf
[ 4.0686 ] Ram code: 0x2
[ 4.0686 ] Chip sku: 0xd0
[ 4.0686 ] Chip Sample: non es
[ 4.0687 ]
[ 4.0692 ] Retrieving EEPROM data
[ 4.0693 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/cvm.bin
[ 4.0710 ] MB2 Applet version 01.00.0000
[ 4.1510 ] Saved platform info in /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/cvm.bin
[ 4.1925 ] Rebooting to recovery mode
[ 4.1979 ] tegrarcm_v2 --ismb2
[ 4.2017 ] MB2 Applet version 01.00.0000
[ 4.2779 ] Rebooting to recovery mode
[ 4.2856 ] tegrarcm_v2 --reboot recovery
[ 4.2914 ] MB2 Applet version 01.00.0000
Board ID(2888) FAB(400) sku(0004) revision(P.0)
copying sdram_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p2888.cfg)... done.
copying sdram_config1(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying scr_cold_boot_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying misc_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg)... done.
copying scr_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying pmc_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg)... done.
copying pmic_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg)... done.
copying br_cmd_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg)... done.
copying prod_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg)... done.
copying device_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-sdmmc.cfg)... done.
copying gpioint_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg)... done.
copying misc_cold_boot_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying dev_params(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-sdmmc.cfg)... done.
copying uphy_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg)... done.
copying minratchet_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg)... done.
Existing mb2_bootloader(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mts_preboot(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mts_mce(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mts_proper(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
copying bootloader_dtb(/home/work/nvidia/35.4.1/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
Existing tlk(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/tos-optee_t194.img) reused.
Existing bpmp_fw(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/bpmp-2_t194.bin) reused.
copying bpmp_fw_dtb(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb)... done.
Existing eks(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/eks_t194.img) reused.
Existing spe_fw(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing mb1file(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing spefile(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing tegraboot(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing tbcfile(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/nvdisp-init.bin) reused.
Existing scefile(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/camera-rtcpu-t194-rce.img) reused.
Existing wb0boot(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
done.
Existing cfg(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/flash.xml) reused.
Existing applet(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing bl(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
./tegraflash.py --sdram_config tegra194-mb1-bct-memcfg-p2888.cfg,tegra194-memcfg-sw-override.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini.cfg --pmc_config tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic_config tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --br_cmd_config tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod_config tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --device_config tegra19x-mb1-bct-device-sdmmc.cfg --gpioint_config tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --dev_params tegra194-br-bct-sdmmc.cfg --uphy_config tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bootloader_dtb tegra194-p2888-0001-p2822-0000.dtb; tlk tos-optee_t194.img; bpmp_fw bpmp-2_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a04.dtb; eks eks_t194.img; kernel boot.img; kernel_dtb tegra194-p2888-0001-p2822-0000.dtb; spe_fw spe_t194.bin" --cfg flash.xml --odmdata 0x9190000 --chip 0x19 --applet mb1_t194_prod.bin --bl nvtboot_recovery_cpu_t194.bin --cmd "readfuses fuse_info.txt fuses_to_read.xml; reboot recovery"
version 1.0.0
[ 0.0454 ] Reading fuses
[ 0.0454 ] Generating RCM messages
[ 0.0484 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[ 0.0500 ] Header already present for mb1_t194_prod.bin
[ 0.0614 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0620 ] Assuming zero filled SBK key
[ 0.0655 ] tegrasign_v3.py --file mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[ 0.0659 ] Assuming zero filled SBK key
[ 0.0706 ] Warning: pub_key.key is not found
[ 0.0711 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[ 0.0810 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[ 0.0862 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 0.0878 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0901 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0901 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0901 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0901 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0902 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0902 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0902 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0902 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0902 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0902 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0902 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0902 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0902 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0902 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0903 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0903 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0903 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0903 ]
[ 0.0922 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[ 0.0940 ] RCM 0 is saved as rcm_0.rcm
[ 0.0991 ] RCM 1 is saved as rcm_1.rcm
[ 0.0994 ] RCM 2 is saved as rcm_2.rcm
[ 0.0994 ] List of rcm files are saved in rcm_list.xml
[ 0.0994 ]
[ 0.0994 ] Signing RCM messages
[ 0.1055 ] tegrasign_v3.py --key None --list rcm_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[ 0.1060 ] Assuming zero filled SBK key
[ 0.1154 ] Warning: pub_key.key is not found
[ 0.1126 ] Copying signature to RCM mesages
[ 0.1158 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.1186 ] Boot Rom communication
[ 0.1206 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[ 0.1222 ] BR_CID: 0x88021911643171840800000010ff8180
[ 0.1509 ] RCM version 0X190001
[ 0.1959 ] Boot Rom communication completed
[ 2.2254 ] tegrarcm_v2 --isapplet
[ 2.2303 ] Applet version 01.00.0000
[ 2.3063 ] Parsing fuse info as per xml file
[ 2.3167 ] tegraparser_v2 --get_fuse_names fuses_to_read.xml read_fuse_names.txt
[ 2.3226 ] WARNING: default chip 0x19 for getting fuse name
[ 2.3266 ] MagicId=0x45535546 version=0x1
[ 2.3266 ]
[ 2.3273 ] trying to read fuse with CPU binary
[ 2.3390 ] tegrasign_v3.py --key None --getmode mode.txt
[ 2.3409 ] Assuming zero filled SBK key
[ 2.3393 ] Parsing partition layout
[ 2.3474 ] tegraparser_v2 --pt flash.xml.tmp
[ 2.3552 ] Creating list of images to be signed
[ 2.3597 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[ 2.3622 ] MB1: Nvheader already present is mb1_t194_prod_aligned.bin
[ 2.3647 ] Header already present for mb1_t194_prod_aligned_sigheader.bin
[ 2.3655 ] MB1: Nvheader already present is mb1_t194_prod_aligned.bin
[ 2.3709 ] Header already present for mb1_t194_prod_aligned_sigheader.bin
[ 2.3716 ] adding BCH for spe_t194_aligned.bin
[ 2.3763 ] adding BCH for nvtboot_t194_aligned.bin
[ 2.3804 ] Header already present for preboot_c10_prod_cr_aligned.bin
[ 2.3880 ] adding BCH for spe_t194_aligned.bin
[ 2.3888 ] adding BCH for nvtboot_t194_aligned.bin
[ 2.3930 ] Header already present for preboot_c10_prod_cr_aligned.bin
[ 2.4009 ] Header already present for mce_c10_prod_cr_aligned.bin
[ 2.4018 ] adding BCH for mts_c10_prod_cr_aligned.bin
[ 2.4226 ] adding BCH for nvdisp-init_aligned.bin
[ 2.5731 ] adding BCH for tegra194-p2888-0001-p2822-0000_aligned.dtb
[ 2.6791 ] adding BCH for tos-optee_t194_aligned.img
[ 2.6970 ] adding BCH for eks_t194_aligned.img
[ 2.7316 ] adding BCH for bpmp-2_t194_aligned.bin
[ 2.7360 ] adding BCH for tegra194-a02-bpmp-p2888-a04_aligned.dtb
[ 2.7758 ] adding BCH for camera-rtcpu-t194-rce_aligned.img
[ 2.8121 ] adding BCH for adsp-fw_aligned.bin
[ 2.8442 ] Header already present for warmboot_t194_prod_aligned.bin
[ 2.8591 ] Header already present for mce_c10_prod_cr_aligned.bin
[ 2.8608 ] adding BCH for mts_c10_prod_cr_aligned.bin
[ 2.8798 ] adding BCH for nvdisp-init_aligned.bin
[ 3.0157 ] adding BCH for tegra194-p2888-0001-p2822-0000_aligned.dtb
[ 3.1231 ] adding BCH for tos-optee_t194_aligned.img
[ 3.1419 ] adding BCH for eks_t194_aligned.img
[ 3.1774 ] adding BCH for bpmp-2_t194_aligned.bin
[ 3.1824 ] adding BCH for tegra194-a02-bpmp-p2888-a04_aligned.dtb
[ 3.2233 ] adding BCH for camera-rtcpu-t194-rce_aligned.img
[ 3.2612 ] adding BCH for adsp-fw_aligned.bin
[ 3.2817 ] Header already present for warmboot_t194_prod_aligned.bin
[ 3.2975 ] Filling MB1 storage info
[ 3.2975 ] Parsing dev params for multi chains
[ 3.2976 ] Generating br-bct
[ 3.3007 ] Performing cfg overlay
[ 3.3008 ] ['tegra194-mb1-bct-memcfg-p2888.cfg', 'tegra194-memcfg-sw-override.cfg']
[ 3.3013 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p2888.cfg -s tegra194-memcfg-sw-override.cfg -o /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6120/tmpnm5y4cei1.cfg
[ 3.3995 ] Updating dev and MSS params in BR BCT
[ 3.3996 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6120/tmpnm5y4cei1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 3.5602 ] Updating bl info
[ 3.5635 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 3.5739 ] Generating signatures
[ 3.5802 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key
[ 3.5808 ] Assuming zero filled SBK key
[ 3.7817 ] Warning: pub_key.key is not found
[ 3.7789 ] Parsing dev params for multi chains
[ 3.7789 ] Generating br-bct
[ 3.7821 ] Performing cfg overlay
[ 3.7821 ] ['/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6120/tmpnm5y4cei1.cfg']
[ 3.7821 ] Updating dev and MSS params in BR BCT
[ 3.7823 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6120/tmpnm5y4cei1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 3.9306 ] Updating bl info
[ 3.9340 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 3.9477 ] Updating smd info
[ 3.9519 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 3.9546 ] Updating Odmdata
[ 3.9580 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0x9190000
[ 3.9603 ] Signing BCT
[ 3.9603 ] Get Signed section of bct
[ 3.9636 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 3.9721 ] tegrasign_v3.py --key None --list bct_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[ 3.9726 ] Assuming zero filled SBK key
[ 3.9761 ] Warning: pub_key.key is not found
[ 3.9733 ] Updating BCT with signature
[ 3.9766 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[ 3.9791 ] Generating coldboot mb1-bct
[ 3.9827 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6120/tmpnm5y4cei1.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[ 3.9845 ] MB1-BCT version: 0x1
[ 3.9852 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 3.9863 ] Added Platform Config 0 data with size :- 3168
[ 3.9905 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 3.9913 ] Added Platform Config 1 data with size :- 19640
[ 4.0267 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 4.0279 ] Added Platform Config 2 data with size :- 24
[ 4.0285 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[ 4.0297 ] File read failed
[ 4.0299 ] File read failed
[ 4.0302 ] Added Platform Config 4 data with size :- 348
[ 4.0309 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 4.0319 ] Added Platform Config 3 data with size :- 92
[ 4.0323 ]
[ 4.0323 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 4.0323 ] Added Platform Config 5 data with size :- 68
[ 4.0323 ]
[ 4.0323 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 4.0324 ] Added Platform Config 7 data with size :- 392
[ 4.0324 ]
[ 4.0324 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 4.0324 ] Added Platform Config 8 data with size :- 12
[ 4.0324 ]
[ 4.0324 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 4.0324 ] Added Platform Config 9 data with size :- 32
[ 4.0324 ]
[ 4.0326 ] Updating mb1-bct with firmware information
[ 4.0358 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 4.0407 ] Updating mb1-bct with storage information
[ 4.0441 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 4.0500 ] Updating mb1-bct with ratchet information
[ 4.0533 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 4.0550 ] FwIndex: 1, MinRatchetLevel: 0
[ 4.0557 ] FwIndex: 2, MinRatchetLevel: 0
[ 4.0557 ] FwIndex: 3, MinRatchetLevel: 0
[ 4.0557 ] FwIndex: 4, MinRatchetLevel: 0
[ 4.0557 ] FwIndex: 5, MinRatchetLevel: 0
[ 4.0558 ] FwIndex: 6, MinRatchetLevel: 0
[ 4.0558 ] FwIndex: 7, MinRatchetLevel: 0
[ 4.0558 ] FwIndex: 11, MinRatchetLevel: 0
[ 4.0558 ] FwIndex: 12, MinRatchetLevel: 0
[ 4.0558 ] FwIndex: 13, MinRatchetLevel: 0
[ 4.0558 ] FwIndex: 14, MinRatchetLevel: 0
[ 4.0558 ] FwIndex: 15, MinRatchetLevel: 0
[ 4.0558 ] FwIndex: 16, MinRatchetLevel: 0
[ 4.0558 ] FwIndex: 17, MinRatchetLevel: 0
[ 4.0558 ] FwIndex: 18, MinRatchetLevel: 0
[ 4.0559 ] FwIndex: 19, MinRatchetLevel: 0
[ 4.0559 ] FwIndex: 30, MinRatchetLevel: 0
[ 4.0559 ] FwIndex: 31, MinRatchetLevel: 0
[ 4.0559 ]
[ 4.0595 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 4.0647 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 4.0665 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 4.0748 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 4.0753 ] Assuming zero filled SBK key
[ 4.0791 ] Warning: pub_key.key is not found
[ 4.0798 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 4.0828 ] Generating recovery mb1-bct
[ 4.0864 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6120/tmpnm5y4cei1.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[ 4.0882 ] MB1-BCT version: 0x1
[ 4.0888 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 4.0898 ] Added Platform Config 0 data with size :- 3168
[ 4.0940 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 4.0948 ] Added Platform Config 1 data with size :- 19640
[ 4.1300 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 4.1312 ] Added Platform Config 2 data with size :- 24
[ 4.1319 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[ 4.1330 ] File read failed
[ 4.1333 ] File read failed
[ 4.1335 ] Added Platform Config 4 data with size :- 348
[ 4.1342 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 4.1353 ] Added Platform Config 3 data with size :- 92
[ 4.1356 ]
[ 4.1356 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 4.1356 ] Added Platform Config 5 data with size :- 68
[ 4.1357 ]
[ 4.1357 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 4.1357 ] Added Platform Config 7 data with size :- 392
[ 4.1357 ]
[ 4.1357 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 4.1357 ] Added Platform Config 8 data with size :- 12
[ 4.1357 ]
[ 4.1357 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 4.1357 ] Added Platform Config 9 data with size :- 32
[ 4.1358 ]
[ 4.1359 ] Updating mb1-bct with firmware information
[ 4.1393 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[ 4.1444 ] Updating mb1-bct with storage information
[ 4.1476 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 4.1536 ] Updating mb1-bct with ratchet information
[ 4.1570 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 4.1587 ] FwIndex: 1, MinRatchetLevel: 0
[ 4.1594 ] FwIndex: 2, MinRatchetLevel: 0
[ 4.1594 ] FwIndex: 3, MinRatchetLevel: 0
[ 4.1594 ] FwIndex: 4, MinRatchetLevel: 0
[ 4.1594 ] FwIndex: 5, MinRatchetLevel: 0
[ 4.1594 ] FwIndex: 6, MinRatchetLevel: 0
[ 4.1594 ] FwIndex: 7, MinRatchetLevel: 0
[ 4.1594 ] FwIndex: 11, MinRatchetLevel: 0
[ 4.1595 ] FwIndex: 12, MinRatchetLevel: 0
[ 4.1595 ] FwIndex: 13, MinRatchetLevel: 0
[ 4.1595 ] FwIndex: 14, MinRatchetLevel: 0
[ 4.1595 ] FwIndex: 15, MinRatchetLevel: 0
[ 4.1595 ] FwIndex: 16, MinRatchetLevel: 0
[ 4.1595 ] FwIndex: 17, MinRatchetLevel: 0
[ 4.1595 ] FwIndex: 18, MinRatchetLevel: 0
[ 4.1595 ] FwIndex: 19, MinRatchetLevel: 0
[ 4.1595 ] FwIndex: 30, MinRatchetLevel: 0
[ 4.1595 ] FwIndex: 31, MinRatchetLevel: 0
[ 4.1596 ]
[ 4.1631 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1_aligned.bct
[ 4.1683 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 4.1702 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 4.1784 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 4.1789 ] Assuming zero filled SBK key
[ 4.1826 ] Warning: pub_key.key is not found
[ 4.1833 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 4.1863 ] Generating coldboot mem-bct
[ 4.1896 ] tegrabct_v2 --chip 0x19 0 --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6120/tmpnm5y4cei1.cfg --membct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6120/tmpnm5y4cei1_1.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6120/tmpnm5y4cei1_2.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6120/tmpnm5y4cei1_3.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6120/tmpnm5y4cei1_4.bct
[ 4.1914 ] Packing sdram param for instance[0]
[ 4.3375 ] Packing sdram param for instance[1]
[ 4.3380 ] Packing sdram param for instance[2]
[ 4.3385 ] Packing sdram param for instance[3]
[ 4.3391 ] Packing sdram param for instance[4]
[ 4.3396 ] Packing sdram param for instance[5]
[ 4.3401 ] Packing sdram param for instance[6]
[ 4.3402 ] Packing sdram param for instance[7]
[ 4.3402 ] Packing sdram param for instance[8]
[ 4.3402 ] Packing sdram param for instance[9]
[ 4.3402 ] Packing sdram param for instance[10]
[ 4.3402 ] Packing sdram param for instance[11]
[ 4.3402 ] Packing sdram param for instance[12]
[ 4.3402 ] Packing sdram param for instance[13]
[ 4.3402 ] Packing sdram param for instance[14]
[ 4.3402 ] Packing sdram param for instance[15]
[ 4.3403 ]
[ 4.3403 ] Getting sector size from pt
[ 4.3435 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 4.3458 ] BlockSize read from layout is 200
[ 4.3490 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6120/tmpnm5y4cei1_1.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6120/tmpnm5y4cei1_2.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6120/tmpnm5y4cei1_3.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6120/tmpnm5y4cei1_4.bct
[ 4.3508 ] adding BCH for /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6120/tmpnm5y4cei1_1.bct
[ 4.3591 ] tegrahost_v2 --chip 0x19 --align mem_coldboot_aligned.bct
[ 4.3641 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[ 4.3659 ] Header already present for mem_coldboot_aligned.bct
[ 4.3737 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 4.3742 ] Assuming zero filled SBK key
[ 4.3784 ] Warning: pub_key.key is not found
[ 4.3792 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[ 4.3829 ] Generating recovery mem-bct
[ 4.3866 ] tegrabct_v2 --chip 0x19 0 --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6120/tmpnm5y4cei1.cfg --membct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6120/tmpnm5y4cei1_1.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6120/tmpnm5y4cei1_2.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6120/tmpnm5y4cei1_3.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6120/tmpnm5y4cei1_4.bct
[ 4.3902 ] Packing sdram param for instance[0]
[ 4.5394 ] Packing sdram param for instance[1]
[ 4.5399 ] Packing sdram param for instance[2]
[ 4.5404 ] Packing sdram param for instance[3]
[ 4.5411 ] Packing sdram param for instance[4]
[ 4.5411 ] Packing sdram param for instance[5]
[ 4.5411 ] Packing sdram param for instance[6]
[ 4.5412 ] Packing sdram param for instance[7]
[ 4.5412 ] Packing sdram param for instance[8]
[ 4.5412 ] Packing sdram param for instance[9]
[ 4.5412 ] Packing sdram param for instance[10]
[ 4.5412 ] Packing sdram param for instance[11]
[ 4.5412 ] Packing sdram param for instance[12]
[ 4.5412 ] Packing sdram param for instance[13]
[ 4.5412 ] Packing sdram param for instance[14]
[ 4.5412 ] Packing sdram param for instance[15]
[ 4.5413 ]
[ 4.5415 ] Reading ramcode from backup chip_info.bin file
[ 4.5416 ] RAMCODE Read from Device: 2
[ 4.5456 ] tegrahost_v2 --chip 0x19 --align mem_rcm_aligned.bct
[ 4.5507 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[ 4.5524 ] adding BCH for mem_rcm_aligned.bct
[ 4.5604 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 4.5609 ] Assuming zero filled SBK key
[ 4.5645 ] Warning: pub_key.key is not found
[ 4.5652 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[ 4.5687 ] Copying signatures
[ 4.5721 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 5.0303 ] Sending BCTs
[ 5.0336 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[ 5.0354 ] Applet version 01.00.0000
[ 5.1093 ] Sending bct_bootrom
[ 5.1097 ] [................................................] 100%
[ 5.1107 ] Sending bct_mb1
[ 5.1155 ] [................................................] 100%
[ 5.1193 ] Sending bct_mem
[ 5.1658 ] [................................................] 100%
[ 5.2099 ] Generating blob
[ 5.2164 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_cpu_t194_aligned.bin
[ 5.2255 ] tegrahost_v2 --chip 0x19 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvtboot_recovery_cpu_t194_aligned.bin zerosbk
[ 5.2292 ] adding BCH for blob_nvtboot_recovery_cpu_t194_aligned.bin
[ 5.2581 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_cpu_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 5.2592 ] Assuming zero filled SBK key
[ 5.2677 ] Warning: pub_key.key is not found
[ 5.2708 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_cpu_t194_aligned_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_t194_aligned_sigheader.bin.hash zerosbk
[ 5.2924 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_t194_aligned.bin
[ 5.3018 ] tegrahost_v2 --chip 0x19 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvtboot_recovery_t194_aligned.bin zerosbk
[ 5.3054 ] adding BCH for blob_nvtboot_recovery_t194_aligned.bin
[ 5.3278 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 5.3284 ] Assuming zero filled SBK key
[ 5.3325 ] Warning: pub_key.key is not found
[ 5.3332 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_t194_aligned_sigheader.bin.encrypt blob_nvtboot_recovery_t194_aligned_sigheader.bin.hash zerosbk
[ 5.3434 ] tegrahost_v2 --chip 0x19 --align blob_preboot_c10_prod_cr_aligned.bin
[ 5.3485 ] tegrahost_v2 --chip 0x19 0 --magicid MTSP --appendsigheader blob_preboot_c10_prod_cr_aligned.bin zerosbk
[ 5.3505 ] Header already present for blob_preboot_c10_prod_cr_aligned.bin
[ 5.3578 ] tegrasign_v3.py --key None --list blob_preboot_c10_prod_cr_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 5.3583 ] Assuming zero filled SBK key
[ 5.3618 ] Warning: pub_key.key is not found
[ 5.3625 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_preboot_c10_prod_cr_aligned_sigheader.bin.encrypt blob_preboot_c10_prod_cr_aligned_sigheader.bin.hash zerosbk
[ 5.3691 ] tegrahost_v2 --chip 0x19 --align blob_mce_c10_prod_cr_aligned.bin
[ 5.3742 ] tegrahost_v2 --chip 0x19 0 --magicid MTSM --appendsigheader blob_mce_c10_prod_cr_aligned.bin zerosbk
[ 5.3760 ] Header already present for blob_mce_c10_prod_cr_aligned.bin
[ 5.3858 ] tegrasign_v3.py --key None --list blob_mce_c10_prod_cr_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 5.3863 ] Assuming zero filled SBK key
[ 5.3906 ] Warning: pub_key.key is not found
[ 5.3914 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mce_c10_prod_cr_aligned_sigheader.bin.encrypt blob_mce_c10_prod_cr_aligned_sigheader.bin.hash zerosbk
[ 5.4037 ] tegrahost_v2 --chip 0x19 --align blob_mts_c10_prod_cr_aligned.bin
[ 5.4088 ] tegrahost_v2 --chip 0x19 0 --magicid MTSB --appendsigheader blob_mts_c10_prod_cr_aligned.bin zerosbk
[ 5.4105 ] adding BCH for blob_mts_c10_prod_cr_aligned.bin
[ 5.5426 ] tegrasign_v3.py --key None --list blob_mts_c10_prod_cr_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 5.5430 ] Assuming zero filled SBK key
[ 5.5587 ] Warning: pub_key.key is not found
[ 5.5594 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mts_c10_prod_cr_aligned_sigheader.bin.encrypt blob_mts_c10_prod_cr_aligned_sigheader.bin.hash zerosbk
[ 5.6346 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-p2888-0001-p2822-0000_aligned.dtb
[ 5.6400 ] tegrahost_v2 --chip 0x19 0 --magicid CDTB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-p2888-0001-p2822-0000_aligned.dtb zerosbk
[ 5.6418 ] adding BCH for blob_tegra194-p2888-0001-p2822-0000_aligned.dtb
[ 5.6635 ] tegrasign_v3.py --key None --list blob_tegra194-p2888-0001-p2822-0000_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 5.6640 ] Assuming zero filled SBK key
[ 5.6688 ] Warning: pub_key.key is not found
[ 5.6694 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-p2888-0001-p2822-0000_aligned_sigheader.dtb.encrypt blob_tegra194-p2888-0001-p2822-0000_aligned_sigheader.dtb.hash zerosbk
[ 5.6841 ] tegrahost_v2 --chip 0x19 --align blob_tos-optee_t194_aligned.img
[ 5.6890 ] tegrahost_v2 --chip 0x19 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tos-optee_t194_aligned.img zerosbk
[ 5.6907 ] adding BCH for blob_tos-optee_t194_aligned.img
[ 5.7334 ] tegrasign_v3.py --key None --list blob_tos-optee_t194_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 5.7339 ] Assuming zero filled SBK key
[ 5.7405 ] Warning: pub_key.key is not found
[ 5.7412 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tos-optee_t194_aligned_sigheader.img.encrypt blob_tos-optee_t194_aligned_sigheader.img.hash zerosbk
[ 5.7678 ] tegrahost_v2 --chip 0x19 --align blob_bpmp-2_t194_aligned.bin
[ 5.7731 ] tegrahost_v2 --chip 0x19 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader blob_bpmp-2_t194_aligned.bin zerosbk
[ 5.7749 ] adding BCH for blob_bpmp-2_t194_aligned.bin
[ 5.8189 ] tegrasign_v3.py --key None --list blob_bpmp-2_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 5.8194 ] Assuming zero filled SBK key
[ 5.8258 ] Warning: pub_key.key is not found
[ 5.8252 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_bpmp-2_t194_aligned_sigheader.bin.encrypt blob_bpmp-2_t194_aligned_sigheader.bin.hash zerosbk
[ 5.8523 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-a02-bpmp-p2888-a04_aligned.dtb
[ 5.8576 ] tegrahost_v2 --chip 0x19 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-a02-bpmp-p2888-a04_aligned.dtb zerosbk
[ 5.8593 ] adding BCH for blob_tegra194-a02-bpmp-p2888-a04_aligned.dtb
[ 5.9025 ] tegrasign_v3.py --key None --list blob_tegra194-a02-bpmp-p2888-a04_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 5.9030 ] Assuming zero filled SBK key
[ 5.9094 ] Warning: pub_key.key is not found
[ 5.9101 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-a02-bpmp-p2888-a04_aligned_sigheader.dtb.encrypt blob_tegra194-a02-bpmp-p2888-a04_aligned_sigheader.dtb.hash zerosbk
[ 5.9362 ] tegrahost_v2 --chip 0x19 --align blob_eks_t194_aligned.img
[ 5.9415 ] tegrahost_v2 --chip 0x19 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_eks_t194_aligned.img zerosbk
[ 5.9434 ] adding BCH for blob_eks_t194_aligned.img
[ 5.9506 ] tegrasign_v3.py --key None --list blob_eks_t194_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 5.9511 ] Assuming zero filled SBK key
[ 5.9547 ] Warning: pub_key.key is not found
[ 5.9554 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_eks_t194_aligned_sigheader.img.encrypt blob_eks_t194_aligned_sigheader.img.hash zerosbk
[ 6.6186 ] Disable RCE in rcm kernel-dtb.
[ 6.7251 ] tegrahost_v2 --chip 0x19 --align blob_spe_t194_aligned.bin
[ 6.7308 ] tegrahost_v2 --chip 0x19 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_spe_t194_aligned.bin zerosbk
[ 6.7328 ] adding BCH for blob_spe_t194_aligned.bin
[ 6.7439 ] tegrasign_v3.py --key None --list blob_spe_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 6.7444 ] Assuming zero filled SBK key
[ 6.7485 ] Warning: pub_key.key is not found
[ 6.7494 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_spe_t194_aligned_sigheader.bin.encrypt blob_spe_t194_aligned_sigheader.bin.hash zerosbk
[ 6.7578 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[ 6.7598 ] number of images in blob are 13
[ 6.7605 ] blobsize is 7909545
[ 6.7608 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 232976
[ 6.7686 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 206016
[ 6.7696 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 24016
[ 6.7706 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 145184
[ 6.7715 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3430416
[ 6.7734 ] Added binary blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt of size 397984
[ 6.7750 ] Added binary blob_tos-optee_t194_sigheader.img.encrypt of size 977664
[ 6.7760 ] Added binary blob_bpmp-2_t194_sigheader.bin.encrypt of size 1007392
[ 6.7774 ] Added binary blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt of size 993408
[ 6.7790 ] Added binary blob_eks_t194_sigheader.img.encrypt of size 5136
[ 6.7799 ] Added binary blob_boot.img of size 21
[ 6.7804 ] Added binary blob_tegra194-p2888-0001-p2822-0000.dtb of size 393884
[ 6.7813 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 95232
[ 6.7878 ] Sending bootloader and pre-requisite binaries
[ 6.7914 ] tegrarcm_v2 --download blob blob.bin
[ 6.7934 ] Applet version 01.00.0000
[ 6.8710 ] Sending blob
[ 6.8715 ] [................................................] 100%
[ 8.0321 ] tegrarcm_v2 --boot recovery
[ 8.0375 ] Applet version 01.00.0000
[ 9.1269 ] tegrarcm_v2 --isapplet
[ 10.1488 ] tegrarcm_v2 --ismb2
[ 10.2323 ] tegradevflash_v2 --iscpubl
[ 10.2347 ] Bootloader version 01.00.0000
[ 10.2682 ] Bootloader version 01.00.0000
[ 10.2682 ]
[ 10.2762 ] tegraparser_v2 --read_fusetype PublicKeyHash read_fuse.bin
[ 10.2814 ] WARNING: default chip 0x19 for parsing fuse info
[ 10.2893 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 10.2945 ] Bootloader version 01.00.0000
[ 10.3278 ] Saved read fuses in file __fuse_read_scatter.bin
[ 10.3295 ] Fuse read successful
[ 10.3296 ]
[ 10.3367 ] tegraparser_v2 --read_fusetype SecureBootKey read_fuse.bin
[ 10.3419 ] WARNING: default chip 0x19 for parsing fuse info
[ 10.3503 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 10.3556 ] Bootloader version 01.00.0000
[ 10.3879 ] Saved read fuses in file __fuse_read_scatter.bin
[ 10.3898 ] Fuse read successful
[ 10.3898 ]
[ 10.3973 ] tegraparser_v2 --read_fusetype Kek0 read_fuse.bin
[ 10.4025 ] WARNING: default chip 0x19 for parsing fuse info
[ 10.4105 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 10.4153 ] Bootloader version 01.00.0000
[ 10.4472 ] Saved read fuses in file __fuse_read_scatter.bin
[ 10.4492 ] Fuse read successful
[ 10.4492 ]
[ 10.4566 ] tegraparser_v2 --read_fusetype Kek1 read_fuse.bin
[ 10.4620 ] WARNING: default chip 0x19 for parsing fuse info
[ 10.4693 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 10.4747 ] Bootloader version 01.00.0000
[ 10.5043 ] Saved read fuses in file __fuse_read_scatter.bin
[ 10.5070 ] Fuse read successful
[ 10.5070 ]
[ 10.5140 ] tegraparser_v2 --read_fusetype Kek2 read_fuse.bin
[ 10.5187 ] WARNING: default chip 0x19 for parsing fuse info
[ 10.5259 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 10.5306 ] Bootloader version 01.00.0000
[ 10.5616 ] Saved read fuses in file __fuse_read_scatter.bin
[ 10.5640 ] Fuse read successful
[ 10.5641 ]
[ 10.5718 ] tegraparser_v2 --read_fusetype Kek256 read_fuse.bin
[ 10.5771 ] WARNING: default chip 0x19 for parsing fuse info
[ 10.5854 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 10.5907 ] Bootloader version 01.00.0000
[ 10.6208 ] Saved read fuses in file __fuse_read_scatter.bin
[ 10.6238 ] Fuse read successful
[ 10.6238 ]
[ 10.6320 ] tegraparser_v2 --read_fusetype BootSecurityInfo read_fuse.bin
[ 10.6372 ] WARNING: default chip 0x19 for parsing fuse info
[ 10.6451 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 10.6498 ] Bootloader version 01.00.0000
[ 10.6818 ] Saved read fuses in file __fuse_read_scatter.bin
[ 10.6845 ] Fuse read successful
[ 10.6845 ]
[ 10.6915 ] tegraparser_v2 --read_fusetype JtagDisable read_fuse.bin
[ 10.6967 ] WARNING: default chip 0x19 for parsing fuse info
[ 10.7048 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 10.7101 ] Bootloader version 01.00.0000
[ 10.7419 ] Saved read fuses in file __fuse_read_scatter.bin
[ 10.7442 ] Fuse read successful
[ 10.7443 ]
[ 10.7521 ] tegraparser_v2 --read_fusetype SecurityMode read_fuse.bin
[ 10.7574 ] WARNING: default chip 0x19 for parsing fuse info
[ 10.7656 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 10.7709 ] Bootloader version 01.00.0000
[ 10.8012 ] Saved read fuses in file __fuse_read_scatter.bin
[ 10.8033 ] Fuse read successful
[ 10.8034 ]
[ 10.8108 ] tegraparser_v2 --read_fusetype SwReserved read_fuse.bin
[ 10.8155 ] WARNING: default chip 0x19 for parsing fuse info
[ 10.8216 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 10.8262 ] Bootloader version 01.00.0000
[ 10.8579 ] Saved read fuses in file __fuse_read_scatter.bin
[ 10.8601 ] Fuse read successful
[ 10.8602 ]
[ 10.8681 ] tegraparser_v2 --read_fusetype DebugAuthentication read_fuse.bin
[ 10.8734 ] WARNING: default chip 0x19 for parsing fuse info
[ 10.8815 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 10.8869 ] Bootloader version 01.00.0000
[ 10.9177 ] Saved read fuses in file __fuse_read_scatter.bin
[ 10.9201 ] Fuse read successful
[ 10.9202 ]
[ 10.9284 ] tegraparser_v2 --read_fusetype OdmId read_fuse.bin
[ 10.9338 ] WARNING: default chip 0x19 for parsing fuse info
[ 10.9420 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 10.9472 ] Bootloader version 01.00.0000
[ 10.9798 ] Saved read fuses in file __fuse_read_scatter.bin
[ 10.9816 ] Fuse read successful
[ 10.9817 ]
[ 10.9897 ] tegraparser_v2 --read_fusetype OdmLock read_fuse.bin
[ 10.9949 ] WARNING: default chip 0x19 for parsing fuse info
[ 11.0032 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 11.0086 ] Bootloader version 01.00.0000
[ 11.0421 ] Saved read fuses in file __fuse_read_scatter.bin
[ 11.0442 ] Fuse read successful
[ 11.0443 ]
[ 11.0523 ] tegraparser_v2 --read_fusetype ReservedOdm0 read_fuse.bin
[ 11.0577 ] WARNING: default chip 0x19 for parsing fuse info
[ 11.0657 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 11.0712 ] Bootloader version 01.00.0000
[ 11.1040 ] Saved read fuses in file __fuse_read_scatter.bin
[ 11.1064 ] Fuse read successful
[ 11.1065 ]
[ 11.1147 ] tegraparser_v2 --read_fusetype ReservedOdm1 read_fuse.bin
[ 11.1199 ] WARNING: default chip 0x19 for parsing fuse info
[ 11.1281 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 11.1335 ] Bootloader version 01.00.0000
[ 11.1678 ] Saved read fuses in file __fuse_read_scatter.bin
[ 11.1699 ] Fuse read successful
[ 11.1699 ]
[ 11.1784 ] tegraparser_v2 --read_fusetype ReservedOdm2 read_fuse.bin
[ 11.1839 ] WARNING: default chip 0x19 for parsing fuse info
[ 11.1920 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 11.1973 ] Bootloader version 01.00.0000
[ 11.2302 ] Saved read fuses in file __fuse_read_scatter.bin
[ 11.2331 ] Fuse read successful
[ 11.2429 ] tegraparser_v2 --read_fusetype ReservedOdm3 read_fuse.bin
[ 11.2490 ] WARNING: default chip 0x19 for parsing fuse info
[ 11.2579 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 11.2633 ] Bootloader version 01.00.0000
[ 11.2937 ] Saved read fuses in file __fuse_read_scatter.bin
[ 11.2962 ] Fuse read successful
[ 11.2962 ]
[ 11.3051 ] tegraparser_v2 --read_fusetype ReservedOdm4 read_fuse.bin
[ 11.3110 ] WARNING: default chip 0x19 for parsing fuse info
[ 11.3192 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 11.3245 ] Bootloader version 01.00.0000
[ 11.3537 ] Saved read fuses in file __fuse_read_scatter.bin
[ 11.3560 ] Fuse read successful
[ 11.3561 ]
[ 11.3651 ] tegraparser_v2 --read_fusetype ReservedOdm5 read_fuse.bin
[ 11.3709 ] WARNING: default chip 0x19 for parsing fuse info
[ 11.3792 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 11.3845 ] Bootloader version 01.00.0000
[ 11.4140 ] Saved read fuses in file __fuse_read_scatter.bin
[ 11.4164 ] Fuse read successful
[ 11.4165 ]
[ 11.4253 ] tegraparser_v2 --read_fusetype ReservedOdm6 read_fuse.bin
[ 11.4314 ] WARNING: default chip 0x19 for parsing fuse info
[ 11.4394 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 11.4451 ] Bootloader version 01.00.0000
[ 11.4785 ] Saved read fuses in file __fuse_read_scatter.bin
[ 11.4809 ] Fuse read successful
[ 11.4809 ]
[ 11.4898 ] tegraparser_v2 --read_fusetype ReservedOdm7 read_fuse.bin
[ 11.4967 ] WARNING: default chip 0x19 for parsing fuse info
[ 11.5072 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 11.5141 ] Bootloader version 01.00.0000
[ 11.5474 ] Saved read fuses in file __fuse_read_scatter.bin
[ 11.5497 ] Fuse read successful
[ 11.5497 ]
[ 11.5576 ] tegraparser_v2 --read_fusetype ReservedOdm8 read_fuse.bin
[ 11.5629 ] WARNING: default chip 0x19 for parsing fuse info
[ 11.5709 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 11.5764 ] Bootloader version 01.00.0000
[ 11.6078 ] Saved read fuses in file __fuse_read_scatter.bin
[ 11.6102 ] Fuse read successful
[ 11.6102 ]
[ 11.6189 ] tegraparser_v2 --read_fusetype ReservedOdm9 read_fuse.bin
[ 11.6242 ] WARNING: default chip 0x19 for parsing fuse info
[ 11.6323 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 11.6376 ] Bootloader version 01.00.0000
[ 11.6718 ] Saved read fuses in file __fuse_read_scatter.bin
[ 11.6742 ] Fuse read successful
[ 11.6743 ]
[ 11.6826 ] tegraparser_v2 --read_fusetype ReservedOdm10 read_fuse.bin
[ 11.6885 ] WARNING: default chip 0x19 for parsing fuse info
[ 11.6970 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 11.7025 ] Bootloader version 01.00.0000
[ 11.7356 ] Saved read fuses in file __fuse_read_scatter.bin
[ 11.7379 ] Fuse read successful
[ 11.7379 ]
[ 11.7459 ] tegraparser_v2 --read_fusetype ReservedOdm11 read_fuse.bin
[ 11.7516 ] WARNING: default chip 0x19 for parsing fuse info
[ 11.7596 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[ 11.7648 ] Bootloader version 01.00.0000
[ 11.7997 ] Saved read fuses in file __fuse_read_scatter.bin
[ 11.8024 ] Fuse read successful
[ 11.8025 ]
[ 11.8038 ] Rebooting to recovery mode
[ 11.8109 ] tegrarcm_v2 --ismb2
[ 11.8951 ] tegradevflash_v2 --reboot recovery
[ 11.8970 ] Bootloader version 01.00.0000
Fuse reading is done. The fuse values have been saved in: /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/fuse_info.txt
PublicKeyHash: e297bd68a275dc373dbec6f9cdbdabca9a690e3d32f3261bcb8aa6422a389adf
SecureBootKey: 123456789abcdef0fedcba9876543210
Kek0: 112233445566778899aabbccddeeff00
Kek1: 123456789abcdef0fedcba9876543210
Kek2: 00000000000000000000000000000000
Kek256: 112233445566778899aabbccddeeff00123456789abcdef0fedcba9876543210
BootSecurityInfo: 00000000
JtagDisable: 00000000
SecurityMode: 00000000
SwReserved: 00000000
DebugAuthentication: 00000000
OdmId: 0000000000000000
OdmLock: 00000000
ReservedOdm0: 00000000
ReservedOdm1: 00000000
ReservedOdm2: 00000000
ReservedOdm3: 00000000
ReservedOdm4: 00000000
ReservedOdm5: 00000000
ReservedOdm6: 00000000
ReservedOdm7: 00000000
ReservedOdm8: 00000000
ReservedOdm9: 00000000
ReservedOdm10: 00000000
ReservedOdm11: 00000000
hello Youke,
here’re fuse values reading by script file.
those are keys on your target, and it also save a copy to… fuse_info.txt
for instance.
as long as those keys were identical with your xml file, you’ve fuse this target correctly.
Hi Jerry,
Thanks, so it looks like I burned in the fuse successfully.
But I executed sudo . /flash.sh jetson-agx-xavier-devkit internal
to burn in the system, and it successfully entered the system after the burn was complete, which is not what I expected.
I don’t think it is possible to boot the system image without burning it with a secret key, I now have to burn a cryptographically signed system image with -u, -k parameters to boot it.
Is this correct? What other steps am I missing?
thanks.
hello Youke,
please see-also Topic 157952.
hi Jerry,
Thanks for the reply, I probably understand.
One more question, I just reused odmfuseread.sh to read the fuse value and got an error, the log is as follows, please help me to see the issue
Bus 001 Device 049: ID 0955:7019 NVIDIA Corp. APX
Error: Either PKC or SBK key is not provided for SBK+PKC protected target board.
-- The board powers down and re-enters recovery mode --
Bus 001 Device 047: ID 0955:7019 NVIDIA Corp. APX
work@E470c:~/nvidia/35.4.1/Linux_for_Tegra$ sudo ./odmfuseread.sh -i 0x19 -k uefi_keys/rsa_3k.pem -S uefi_keys/sbk.txt jetson-agx-xavier-devkit
./tegraflash.py --chip 0x19 --applet "/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery" --encrypt_key "uefi_keys/sbk.txt" --key "uefi_keys/rsa_3k.pem"
version 1.0.0
[ 0.0413 ] Generating RCM messages
[ 0.0475 ] tegrasign_v3.py --file /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod.bin --key /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/uefi_keys/sbk.txt --offset 4096
[ 0.0481 ] Assuming zero filled SBK key : not reading /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/uefi_keys/sbk.txt
[ 0.0581 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod_encrypt.bin zerosbk
[ 0.0598 ] Header already present for /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod_encrypt.bin
[ 0.0711 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/uefi_keys/rsa_3k.pem --getmode mode.txt
[ 0.0716 ] Assuming zero filled SBK key : not reading /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/uefi_keys/rsa_3k.pem
[ 0.0748 ] tegrasign_v3.py --file /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod_encrypt_sigheader.bin --key /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/uefi_keys/rsa_3k.pem --length 1136 --offset 2960 --pubkeyhash pub_key.key
[ 0.0754 ] Assuming zero filled SBK key : not reading /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/uefi_keys/rsa_3k.pem
[ 0.0797 ] Warning: pub_key.key is not found
[ 0.0802 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod_encrypt_sigheader.bin /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod_encrypt_sigheader.hash zerosbk
[ 0.0905 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[ 0.0957 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod_encrypt_sigheader.bin 0 0
[ 0.0974 ] RCM 0 is saved as rcm_0.rcm
[ 0.1024 ] RCM 1 is saved as rcm_1.rcm
[ 0.1031 ] RCM 2 is saved as rcm_2.rcm
[ 0.1031 ] List of rcm files are saved in rcm_list.xml
[ 0.1031 ]
[ 0.1031 ] Signing RCM messages
[ 0.1097 ] tegrasign_v3.py --key /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/uefi_keys/rsa_3k.pem --list rcm_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[ 0.1102 ] Assuming zero filled SBK key : not reading /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/uefi_keys/rsa_3k.pem
[ 0.1198 ] Warning: pub_key.key is not found
[ 0.1169 ] Copying signature to RCM mesages
[ 0.1203 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.1233 ] Boot Rom communication
[ 0.1265 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[ 0.1282 ] RCM version 0X13
[ 0.1552 ] Boot Rom communication failed
Error: Return value 3
Command tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
Reading board information failed.
thanks,
