Burn fuses on custom carrier board
Hi, I want to burn fuses of a Jetson Xavier NX on a custom carrier board. Somehow I get the following error:
$ /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/odmfuse.sh -i 0x19 -X $PWD/fuse.xml --test 3dvl-ecm-xnx-avt
copying soft_fuses(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0171 ] Generating RCM messages
[   0.0188 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/mb1_t194_prod.bin zerosbk
[   0.0192 ] Header already present for /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/mb1_t194_prod.bin
[   0.0267 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0268 ] Assuming zero filled SBK key
[   0.0285 ] tegrasign_v3.py --file /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[   0.0286 ] Assuming zero filled SBK key
[   0.0302 ] Warning: pub_key.key is not found
[   0.0286 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/mb1_t194_prod_sigheader.bin /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[   0.0330 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[   0.0350 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/mb1_t194_prod_sigheader.bin 0 0
[   0.0353 ] RCM 0 is saved as rcm_0.rcm
[   0.0382 ] RCM 1 is saved as rcm_1.rcm
[   0.0383 ] RCM 2 is saved as rcm_2.rcm
[   0.0384 ] List of rcm files are saved in rcm_list.xml
[   0.0385 ]
[   0.0385 ] Signing RCM messages
[   0.0432 ] tegrasign_v3.py --key None --list rcm_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[   0.0434 ] Assuming zero filled SBK key
[   0.0467 ] Warning: pub_key.key is not found
[   0.0436 ] Copying signature to RCM mesages
[   0.0451 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.0460 ] Boot Rom communication
[   0.0476 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[   0.0479 ] RCM version 0X190001
[   0.0490 ] Boot Rom communication completed
[   2.0691 ] tegrarcm_v2 --isapplet
[   2.0694 ] Applet version 01.00.0000
[   2.0735 ] tegrarcm_v2 --ismb2
[   2.0774 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194_aligned.bin
[   2.0795 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194_aligned.bin zerosbk
[   2.0808 ] adding BCH for nvtboot_applet_t194_aligned.bin
[   2.0929 ] tegrasign_v3.py --key None --list nvtboot_applet_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   2.0929 ] Assuming zero filled SBK key
[   2.0940 ] Warning: pub_key.key is not found
[   2.0924 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_aligned_sigheader.bin.encrypt nvtboot_applet_t194_aligned_sigheader.bin.hash zerosbk
[   2.0959 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[   2.0963 ] Applet version 01.00.0000
[   2.0984 ] Sending mb2
[   2.0985 ] [................................................] 100%
[   2.1166 ] tegrarcm_v2 --boot recovery
[   2.1171 ] Applet version 01.00.0000
[   3.1261 ] tegrarcm_v2 --isapplet
[   3.1330 ] tegrarcm_v2 --ismb2
[   3.1334 ] MB2 Applet version 01.00.0000
[   3.1376 ] tegrarcm_v2 --ismb2
[   3.1379 ] MB2 Applet version 01.00.0000
[   3.1424 ] Retrieving board information
[   3.1440 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[   3.1444 ] MB2 Applet version 01.00.0000
[   3.1492 ] Saved platform info in chip_info.bin
[   3.1535 ] Chip minor revision: 2
[   3.1536 ] Bootrom revision: 0xf
[   3.1537 ] Ram code: 0x0
[   3.1537 ] Chip sku: 0xde
[   3.1538 ] Chip Sample: non es
[   3.1545 ] Retrieving EEPROM data
[   3.1545 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/cvm.bin
[   3.1553 ] MB2 Applet version 01.00.0000
[   3.1603 ] Saved platform info in /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/cvm.bin
[   3.2005 ] Rebooting to recovery mode
[   3.2023 ] tegrarcm_v2 --ismb2
[   3.2032 ] MB2 Applet version 01.00.0000
[   3.2061 ] Rebooting to recovery mode
[   3.2078 ] tegrarcm_v2 --reboot recovery
[   3.2085 ] MB2 Applet version 01.00.0000
Board ID(3668) version(200) sku(0001) revision(G.0)
copying sdram_config(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg)... done.
copying sdram_config1(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying scr_cold_boot_config(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
copying misc_config(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p3668-a01.cfg)... done.
copying scr_config(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
copying pmc_config(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p3668-a01.cfg)... done.
copying pmic_config(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p3668-0001-a00.cfg)... done.
copying br_cmd_config(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p3668-0001-a00.cfg)... done.
copying prod_config(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/t186ref/BCT/tegra19x-mb1-prod-p3668-0001-a00.cfg)... done.
copying device_config(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-qspi-p3668.cfg)... done.
copying gpioint_config(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg)... done.
copying misc_cold_boot_config(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying dev_params(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/t186ref/BCT/tegra194-br-bct-qspi-l4t.cfg)... done.
copying minratchet_config(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/t186ref/BCT/tegra194-mb1-bct-ratchet-p3668.cfg)... done.
Existing mb2_bootloader(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mts_preboot(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mts_mce(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/mce_c10_prod_cr.bin) reused.
Existing mts_proper(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/mts_c10_prod_cr.bin) reused.
copying bootloader_dtb(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/kernel/dtb/tegra194-p3668-3dvl-ecm-camera-avt.dtb)... done.
Existing tlk(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/tos-optee_t194.img) reused.
Existing bpmp_fw(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/bpmp-2_t194.bin) reused.
copying bpmp_fw_dtb(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/t186ref/tegra194-a02-bpmp-p3668-a00.dtb)... done.
Existing eks(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/eks_t194.img) reused.
Existing spe_fw(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/spe_t194.bin) reused.
Existing mb1file(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/mb1_t194_prod.bin) reused.
Existing spefile(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/spe_t194.bin) reused.
Existing tegraboot(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/nvtboot_t194.bin) reused.
Existing tbcfile(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/nvdisp-init.bin) reused.
Existing scefile(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/camera-rtcpu-t194-rce.img) reused.
Existing wb0boot(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/warmboot_t194_prod.bin) reused.
done.
Existing cfg(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/flash.xml) reused.
Existing applet(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/mb1_t194_prod.bin) reused.
Existing bl(/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
./tegraflash.py --sdram_config tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg,tegra194-memcfg-sw-override.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p3668-a01.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pmc_config tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic_config tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --br_cmd_config tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod_config tegra19x-mb1-prod-p3668-0001-a00.cfg --device_config tegra19x-mb1-bct-device-qspi-p3668.cfg --gpioint_config tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --dev_params tegra194-br-bct-qspi-l4t.cfg --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg  --bins "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bootloader_dtb tegra194-p3668-3dvl-ecm-camera-avt.dtb; tlk tos-optee_t194.img; bpmp_fw bpmp-2_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p3668-a00.dtb; eks eks_t194.img; kernel boot.img; kernel_dtb tegra194-p3668-3dvl-ecm-camera-avt.dtb; spe_fw spe_t194.bin" --cfg flash.xml --odmdata 0xB8190000 --chip 0x19 --applet mb1_t194_prod.bin --bl nvtboot_recovery_cpu_t194.bin   --cmd "readfuses fuse_info.txt fuses_to_read.xml; reboot recovery"
version 1.0.0
[   0.0198 ] Reading fuses
[   0.0198 ] Generating RCM messages
[   0.0215 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[   0.0219 ] Header already present for mb1_t194_prod.bin
[   0.0292 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0293 ] Assuming zero filled SBK key
[   0.0310 ] tegrasign_v3.py --file mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[   0.0311 ] Assuming zero filled SBK key
[   0.0331 ] Warning: pub_key.key is not found
[   0.0314 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[   0.0358 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[   0.0380 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[   0.0390 ] FwIndex: 1, MinRatchetLevel: 0
[   0.0399 ] FwIndex: 2, MinRatchetLevel: 0
[   0.0399 ] FwIndex: 3, MinRatchetLevel: 0
[   0.0399 ] FwIndex: 4, MinRatchetLevel: 0
[   0.0399 ] FwIndex: 5, MinRatchetLevel: 0
[   0.0399 ] FwIndex: 6, MinRatchetLevel: 0
[   0.0400 ] FwIndex: 7, MinRatchetLevel: 0
[   0.0400 ] FwIndex: 11, MinRatchetLevel: 0
[   0.0400 ] FwIndex: 12, MinRatchetLevel: 0
[   0.0400 ] FwIndex: 13, MinRatchetLevel: 0
[   0.0400 ] FwIndex: 14, MinRatchetLevel: 0
[   0.0400 ] FwIndex: 15, MinRatchetLevel: 0
[   0.0400 ] FwIndex: 16, MinRatchetLevel: 0
[   0.0400 ] FwIndex: 17, MinRatchetLevel: 0
[   0.0400 ] FwIndex: 18, MinRatchetLevel: 0
[   0.0400 ] FwIndex: 19, MinRatchetLevel: 0
[   0.0400 ] FwIndex: 30, MinRatchetLevel: 0
[   0.0401 ] FwIndex: 31, MinRatchetLevel: 0
[   0.0401 ]
[   0.0424 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[   0.0434 ] RCM 0 is saved as rcm_0.rcm
[   0.0499 ] RCM 1 is saved as rcm_1.rcm
[   0.0501 ] RCM 2 is saved as rcm_2.rcm
[   0.0501 ] List of rcm files are saved in rcm_list.xml
[   0.0501 ]
[   0.0502 ] Signing RCM messages
[   0.0554 ] tegrasign_v3.py --key None --list rcm_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[   0.0556 ] Assuming zero filled SBK key
[   0.0623 ] Warning: pub_key.key is not found
[   0.0590 ] Copying signature to RCM mesages
[   0.0611 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.0637 ] Boot Rom communication
[   0.0657 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[   0.0666 ] BR_CID: 0x88021911646e1586180000000fff8180
[   0.0677 ] RCM version 0X190001
[   0.0682 ] Boot Rom communication completed
[   2.0895 ] tegrarcm_v2 --isapplet
[   2.0909 ] Applet version 01.00.0000
[   2.0946 ] Parsing fuse info as per xml file
[   2.0965 ] tegraparser_v2 --get_fuse_names fuses_to_read.xml read_fuse_names.txt
[   2.0969 ] WARNING: default chip 0x19 for getting fuse name
[   2.0971 ] MagicId=0x45535546 version=0x1
[   2.0971 ]
[   2.0971 ] trying to read fuse with CPU binary
[   2.1019 ] tegrasign_v3.py --key None --getmode mode.txt
[   2.1019 ] Assuming zero filled SBK key
[   2.0988 ] Parsing partition layout
[   2.1002 ] tegraparser_v2 --pt flash.xml.tmp
[   2.1011 ] Creating list of images to be signed
[   2.1028 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[   2.1031 ] MB1: Nvheader already present is mb1_t194_prod_aligned.bin
[   2.1039 ] Header already present for mb1_t194_prod_aligned_sigheader.bin
[   2.1041 ] MB1: Nvheader already present is mb1_t194_prod_aligned.bin
[   2.1067 ] Header already present for mb1_t194_prod_aligned_sigheader.bin
[   2.1070 ] adding BCH for spe_t194_aligned.bin
[   2.1095 ] adding BCH for nvtboot_t194_aligned.bin
[   2.1117 ] Header already present for preboot_c10_prod_cr_aligned.bin
[   2.1165 ] Header already present for mce_c10_prod_cr_aligned.bin
[   2.1169 ] adding BCH for mts_c10_prod_cr_aligned.bin
[   2.1244 ] Header already present for warmboot_t194_prod_aligned.bin
[   2.1870 ] adding BCH for nvdisp-init_aligned.bin
[   2.1881 ] adding BCH for tegra194-p3668-3dvl-ecm-camera-avt_aligned.dtb
[   2.1951 ] adding BCH for tos-optee_t194_aligned.img
[   2.2005 ] adding BCH for eks_t194_aligned.img
[   2.2205 ] adding BCH for adsp-fw_aligned.bin
[   2.2211 ] adding BCH for camera-rtcpu-t194-rce_aligned.img
[   2.2288 ] adding BCH for bpmp-2_t194_aligned.bin
[   2.2401 ] adding BCH for tegra194-a02-bpmp-p3668-a00_aligned.dtb
[   2.2589 ] adding BCH for spe_t194_aligned.bin
[   2.2700 ] adding BCH for nvtboot_t194_aligned.bin
[   2.2719 ] Header already present for preboot_c10_prod_cr_aligned.bin
[   2.2757 ] Header already present for mce_c10_prod_cr_aligned.bin
[   2.2761 ] adding BCH for mts_c10_prod_cr_aligned.bin
[   2.2837 ] Header already present for warmboot_t194_prod_aligned.bin
[   2.3439 ] adding BCH for nvdisp-init_aligned.bin
[   2.3449 ] adding BCH for tegra194-p3668-3dvl-ecm-camera-avt_aligned.dtb
[   2.3523 ] adding BCH for tos-optee_t194_aligned.img
[   2.3576 ] adding BCH for eks_t194_aligned.img
[   2.3782 ] adding BCH for adsp-fw_aligned.bin
[   2.3790 ] adding BCH for camera-rtcpu-t194-rce_aligned.img
[   2.3873 ] adding BCH for bpmp-2_t194_aligned.bin
[   2.3992 ] adding BCH for tegra194-a02-bpmp-p3668-a00_aligned.dtb
[   2.4303 ] Filling MB1 storage info
[   2.4304 ] Parsing dev params for multi chains
[   2.4304 ] Generating br-bct
[   2.4320 ] Performing cfg overlay
[   2.4320 ] ['tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg', 'tegra194-memcfg-sw-override.cfg']
[   2.4321 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg -s tegra194-memcfg-sw-override.cfg -o /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/117498/tmp0xm5cdgr1.cfg
[   2.4756 ] Updating dev and MSS params in BR BCT
[   2.4757 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi-l4t.cfg --sdram /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/117498/tmp0xm5cdgr1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   2.5413 ] Updating bl info
[   2.5429 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[   2.5510 ] Generating signatures
[   2.5563 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key
[   2.5565 ] Assuming zero filled SBK key
[   2.6033 ] Warning: pub_key.key is not found
[   2.6000 ] Parsing dev params for multi chains
[   2.6000 ] Generating br-bct
[   2.6016 ] Performing cfg overlay
[   2.6016 ] ['/home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/117498/tmp0xm5cdgr1.cfg']
[   2.6016 ] Updating dev and MSS params in BR BCT
[   2.6016 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi-l4t.cfg --sdram /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/117498/tmp0xm5cdgr1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   2.6691 ] Updating bl info
[   2.6709 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   2.6728 ] Updating smd info
[   2.6744 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[   2.6750 ] Updating Odmdata
[   2.6766 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0xB8190000
[   2.6773 ] Signing BCT
[   2.6773 ] Get Signed section of bct
[   2.6791 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[   2.6850 ] tegrasign_v3.py --key None --list bct_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[   2.6850 ] Assuming zero filled SBK key
[   2.6860 ] Warning: pub_key.key is not found
[   2.6827 ] Updating BCT with signature
[   2.6844 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[   2.6851 ] Generating coldboot mb1-bct
[   2.6867 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/117498/tmp0xm5cdgr1.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pinmux tegra19x-mb1-pinmux-p3668-a01.cfg --pmc tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --brcommand tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod tegra19x-mb1-prod-p3668-0001-a00.cfg --gpioint tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --device tegra19x-mb1-bct-device-qspi-p3668.cfg
[   2.6870 ] MB1-BCT version: 0x1
[   2.6874 ] Parsing config file :tegra19x-mb1-pinmux-p3668-a01.cfg
[   2.6876 ] Added Platform Config 0 data with size :- 2496
[   2.6891 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini-p3668.cfg
[   2.6895 ] Added Platform Config 1 data with size :- 19640
[   2.7047 ] Parsing config file :tegra19x-mb1-padvoltage-p3668-a01.cfg
[   2.7049 ] Added Platform Config 2 data with size :- 24
[   2.7051 ] Parsing config file :tegra194-mb1-bct-pmic-p3668-0001-a00.cfg
[   2.7053 ] Added Platform Config 4 data with size :- 348
[   2.7054 ] Parsing config file :tegra194-mb1-bct-reset-p3668-0001-a00.cfg
[   2.7056 ] Added Platform Config 3 data with size :- 92
[   2.7058 ] Parsing config file :tegra19x-mb1-prod-p3668-0001-a00.cfg
[   2.7060 ] Added Platform Config 5 data with size :- 140
[   2.7061 ] Parsing config file :tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg
[   2.7064 ] Added Platform Config 7 data with size :- 392
[   2.7064 ]
[   2.7064 ] Parsing config file :tegra19x-mb1-bct-device-qspi-p3668.cfg
[   2.7064 ] Added Platform Config 9 data with size :- 40
[   2.7064 ]
[   2.7064 ] Updating mb1-bct with firmware information
[   2.7081 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   2.7089 ] Updating mb1-bct with storage information
[   2.7105 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[   2.7113 ] Updating mb1-bct with ratchet information
[   2.7131 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[   2.7134 ] FwIndex: 1, MinRatchetLevel: 0
[   2.7137 ] FwIndex: 2, MinRatchetLevel: 0
[   2.7138 ] FwIndex: 3, MinRatchetLevel: 0
[   2.7138 ] FwIndex: 4, MinRatchetLevel: 0
[   2.7138 ] FwIndex: 5, MinRatchetLevel: 0
[   2.7138 ] FwIndex: 6, MinRatchetLevel: 0
[   2.7138 ] FwIndex: 7, MinRatchetLevel: 0
[   2.7138 ] FwIndex: 11, MinRatchetLevel: 0
[   2.7138 ] FwIndex: 12, MinRatchetLevel: 0
[   2.7138 ] FwIndex: 13, MinRatchetLevel: 0
[   2.7138 ] FwIndex: 14, MinRatchetLevel: 0
[   2.7138 ] FwIndex: 15, MinRatchetLevel: 0
[   2.7138 ] FwIndex: 16, MinRatchetLevel: 0
[   2.7138 ] FwIndex: 17, MinRatchetLevel: 0
[   2.7138 ] FwIndex: 18, MinRatchetLevel: 0
[   2.7138 ] FwIndex: 19, MinRatchetLevel: 0
[   2.7138 ] FwIndex: 30, MinRatchetLevel: 0
[   2.7138 ] FwIndex: 31, MinRatchetLevel: 0
[   2.7138 ]
[   2.7154 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1_aligned.bct
[   2.7175 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   2.7178 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   2.7235 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   2.7236 ] Assuming zero filled SBK key
[   2.7245 ] Warning: pub_key.key is not found
[   2.7229 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   2.7237 ] Generating recovery mb1-bct
[   2.7254 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/117498/tmp0xm5cdgr1.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pinmux tegra19x-mb1-pinmux-p3668-a01.cfg --pmc tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --brcommand tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod tegra19x-mb1-prod-p3668-0001-a00.cfg --gpioint tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --device tegra19x-mb1-bct-device-qspi-p3668.cfg
[   2.7258 ] MB1-BCT version: 0x1
[   2.7262 ] Parsing config file :tegra19x-mb1-pinmux-p3668-a01.cfg
[   2.7265 ] Added Platform Config 0 data with size :- 2496
[   2.7281 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini-p3668.cfg
[   2.7285 ] Added Platform Config 1 data with size :- 19640
[   2.7467 ] Parsing config file :tegra19x-mb1-padvoltage-p3668-a01.cfg
[   2.7471 ] Added Platform Config 2 data with size :- 24
[   2.7474 ] Parsing config file :tegra194-mb1-bct-pmic-p3668-0001-a00.cfg
[   2.7478 ] Added Platform Config 4 data with size :- 348
[   2.7481 ] Parsing config file :tegra194-mb1-bct-reset-p3668-0001-a00.cfg
[   2.7485 ] Added Platform Config 3 data with size :- 92
[   2.7485 ]
[   2.7485 ] Parsing config file :tegra19x-mb1-prod-p3668-0001-a00.cfg
[   2.7485 ] Added Platform Config 5 data with size :- 140
[   2.7485 ]
[   2.7485 ] Parsing config file :tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg
[   2.7485 ] Added Platform Config 7 data with size :- 392
[   2.7485 ]
[   2.7485 ] Parsing config file :tegra19x-mb1-bct-device-qspi-p3668.cfg
[   2.7485 ] Added Platform Config 9 data with size :- 40
[   2.7485 ]
[   2.7486 ] Updating mb1-bct with firmware information
[   2.7502 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[   2.7511 ] Updating mb1-bct with storage information
[   2.7527 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[   2.7537 ] Updating mb1-bct with ratchet information
[   2.7554 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[   2.7558 ] FwIndex: 1, MinRatchetLevel: 0
[   2.7562 ] FwIndex: 2, MinRatchetLevel: 0
[   2.7563 ] FwIndex: 3, MinRatchetLevel: 0
[   2.7564 ] FwIndex: 4, MinRatchetLevel: 0
[   2.7564 ] FwIndex: 5, MinRatchetLevel: 0
[   2.7564 ] FwIndex: 6, MinRatchetLevel: 0
[   2.7564 ] FwIndex: 7, MinRatchetLevel: 0
[   2.7564 ] FwIndex: 11, MinRatchetLevel: 0
[   2.7564 ] FwIndex: 12, MinRatchetLevel: 0
[   2.7564 ] FwIndex: 13, MinRatchetLevel: 0
[   2.7564 ] FwIndex: 14, MinRatchetLevel: 0
[   2.7564 ] FwIndex: 15, MinRatchetLevel: 0
[   2.7564 ] FwIndex: 16, MinRatchetLevel: 0
[   2.7564 ] FwIndex: 17, MinRatchetLevel: 0
[   2.7564 ] FwIndex: 18, MinRatchetLevel: 0
[   2.7564 ] FwIndex: 19, MinRatchetLevel: 0
[   2.7564 ] FwIndex: 30, MinRatchetLevel: 0
[   2.7564 ] FwIndex: 31, MinRatchetLevel: 0
[   2.7564 ]
[   2.7581 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1_aligned.bct
[   2.7602 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   2.7606 ] adding BCH for mb1_bct_MB1_aligned.bct
[   2.7664 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   2.7665 ] Assuming zero filled SBK key
[   2.7676 ] Warning: pub_key.key is not found
[   2.7661 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   2.7671 ] Generating coldboot mem-bct
[   2.7688 ] tegrabct_v2 --chip 0x19 0 --sdram /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/117498/tmp0xm5cdgr1.cfg --membct /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/117498/tmp0xm5cdgr1_1.bct /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/117498/tmp0xm5cdgr1_2.bct /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/117498/tmp0xm5cdgr1_3.bct /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/117498/tmp0xm5cdgr1_4.bct
[   2.7692 ] Packing sdram param for instance[0]
[   2.8421 ] Packing sdram param for instance[1]
[   2.8423 ] Packing sdram param for instance[2]
[   2.8425 ] Packing sdram param for instance[3]
[   2.8425 ] Packing sdram param for instance[4]
[   2.8425 ] Packing sdram param for instance[5]
[   2.8425 ] Packing sdram param for instance[6]
[   2.8425 ] Packing sdram param for instance[7]
[   2.8425 ] Packing sdram param for instance[8]
[   2.8425 ] Packing sdram param for instance[9]
[   2.8425 ] Packing sdram param for instance[10]
[   2.8425 ] Packing sdram param for instance[11]
[   2.8425 ] Packing sdram param for instance[12]
[   2.8425 ] Packing sdram param for instance[13]
[   2.8425 ] Packing sdram param for instance[14]
[   2.8426 ] Packing sdram param for instance[15]
[   2.8426 ]
[   2.8426 ] Getting sector size from pt
[   2.8442 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[   2.8447 ] BlockSize read from layout is 200
[   2.8464 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/117498/tmp0xm5cdgr1_1.bct /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/117498/tmp0xm5cdgr1_2.bct /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/117498/tmp0xm5cdgr1_3.bct /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/117498/tmp0xm5cdgr1_4.bct
[   2.8468 ] adding BCH for /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/117498/tmp0xm5cdgr1_1.bct
[   2.8505 ] tegrahost_v2 --chip 0x19 --align mem_coldboot_aligned.bct
[   2.8542 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[   2.8553 ] Header already present for mem_coldboot_aligned.bct
[   2.8623 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   2.8626 ] Assuming zero filled SBK key
[   2.8659 ] Warning: pub_key.key is not found
[   2.8658 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[   2.8687 ] Generating recovery mem-bct
[   2.8711 ] tegrabct_v2 --chip 0x19 0 --sdram /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/117498/tmp0xm5cdgr1.cfg --membct /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/117498/tmp0xm5cdgr1_1.bct /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/117498/tmp0xm5cdgr1_2.bct /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/117498/tmp0xm5cdgr1_3.bct /home/hesmar/Development/3dvisionlabs/system/nvidia/r35.6/bootloader/117498/tmp0xm5cdgr1_4.bct
[   2.8723 ] Packing sdram param for instance[0]
[   2.9406 ] Packing sdram param for instance[1]
[   2.9407 ] Packing sdram param for instance[2]
[   2.9410 ] Packing sdram param for instance[3]
[   2.9412 ] Packing sdram param for instance[4]
[   2.9412 ] Packing sdram param for instance[5]
[   2.9412 ] Packing sdram param for instance[6]
[   2.9412 ] Packing sdram param for instance[7]
[   2.9412 ] Packing sdram param for instance[8]
[   2.9412 ] Packing sdram param for instance[9]
[   2.9412 ] Packing sdram param for instance[10]
[   2.9412 ] Packing sdram param for instance[11]
[   2.9412 ] Packing sdram param for instance[12]
[   2.9412 ] Packing sdram param for instance[13]
[   2.9412 ] Packing sdram param for instance[14]
[   2.9412 ] Packing sdram param for instance[15]
[   2.9412 ]
[   2.9413 ] Reading ramcode from backup chip_info.bin file
[   2.9413 ] RAMCODE Read from Device: 0
[   2.9431 ] tegrahost_v2 --chip 0x19 --align mem_rcm_aligned.bct
[   2.9451 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[   2.9454 ] adding BCH for mem_rcm_aligned.bct
[   2.9517 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   2.9518 ] Assuming zero filled SBK key
[   2.9528 ] Warning: pub_key.key is not found
[   2.9512 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[   2.9522 ] Copying signatures
[   2.9538 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[   3.1148 ] Sending BCTs
[   3.1165 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[   3.1169 ] Applet version 01.00.0000
[   3.1190 ] Sending bct_bootrom
[   3.1191 ] [................................................] 100%
[   3.1202 ] Sending bct_mb1
[   3.1253 ] [................................................] 100%
Error: Return value 8
Command tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[   3.1660 ] Rebooting to recovery mode
[   3.1677 ] tegrarcm_v2 --ismb2
[   3.1703 ] tegradevflash_v2 --reboot recovery
[   3.1707 ] CPU Bootloader is not running on device.
Error: Return value 4
Command tegradevflash_v2 --reboot recovery
Error: read fuse info failed.
If I put the Jetson on the devkit instead, it works. Flashing an unsigned image works also on the custom carrier, so it only happens when burning the fuses. What could be the reason for this?
hello MarkusHess,
is it the same module? please note that fuse burning operations are high-risk because they cannot be reversed.
I assume this is customize board config, right?
since fuse burning to the module, could you please compare the board config file with devkit to find the culprit.
Hi JerryChang,
yes, it is the same module. I executed it with the --test parameter, so that fuses are not really burned. As i wrote, this is working on devkit but fails on custom carrier board.
3dvl-ecm-xnx-avt is our custom carrier board config. It is the same as jetson-xavier-nx-devkit-emmc besides the device tree. I also tried with jetson-xavier-nx-devkit-emmc as config before with the same result.
hello MarkusHess,
you may check the USB connection, since it’ll be disconnect/connect several times during the process.
Not sure what to check here. Flashing and access via SSH over USB works fine. So I think, USB should be Ok. What is the meaning of “Return value 8”?
hello MarkusHess,
it might due to below…
according to Board ID(3668) version(200) sku(0001) revision(G.0).
could you please try follow command-line to test again, --noburn also not performing fuse burning.
$ sudo FAB=200 BOARDID=3668 BOARDSKU=0001 \
  BOARDREV=G.0 ./odmfuse.sh --noburn -i 0x19 \
  --auth NS -p -k <pkc> --KEK2 <kek2> \
  -S <sbk> jetson-xavier-nx-devkit-emmc
Hi JerryChang,
we tried it with the variables set, but the result is the same. What else could be the reason?
hello MarkusHess,
let me double check what’s the fuse types you’re going to fuse on Xavier NX, are you trying to burn all the fuse variable at once?
