Failed to write Fuses,Fuse burn is not supported
Hi all,
Hello guys.
I’m testing the safe boot feature right now and it involves writing fuses
I’m using software version 35.4.1 and hardware jetson-agx-xavier
My burn command is as follows: sudo . /odmfuse.sh --test -X uefi_keys/rsa_3k.xml -i 0x19 jetson-agx-xavier-devkit
The log is as follows:
[work:~/nvidia/35.4.1/Linux_for_Tegra]$ sudo ./odmfuse.sh --test -X uefi_keys/rsa_3k.xml -i 0x19 jetson-agx-xavier-devkit
copying soft_fuses(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0108 ] Generating RCM messages
[   0.0129 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[   0.0141 ] Header already present for /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[   0.0191 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0194 ] Assuming zero filled SBK key
[   0.0216 ] tegrasign_v3.py --file /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[   0.0218 ] Assuming zero filled SBK key
[   0.0243 ] Warning: pub_key.key is not found
[   0.0264 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[   0.0315 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[   0.0345 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[   0.0352 ] RCM 0 is saved as rcm_0.rcm
[   0.0372 ] RCM 1 is saved as rcm_1.rcm
[   0.0375 ] RCM 2 is saved as rcm_2.rcm
[   0.0375 ] List of rcm files are saved in rcm_list.xml
[   0.0375 ]
[   0.0375 ] Signing RCM messages
[   0.0412 ] tegrasign_v3.py --key None --list rcm_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[   0.0414 ] Assuming zero filled SBK key
[   0.0466 ] Warning: pub_key.key is not found
[   0.0460 ] Copying signature to RCM mesages
[   0.0480 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.0495 ] Boot Rom communication
[   0.0518 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[   0.0527 ] RCM version 0X190001
[   0.1599 ] Boot Rom communication completed
[   2.2079 ] tegrarcm_v2 --isapplet
[   2.2121 ] Applet version 01.00.0000
[   2.4734 ] tegrarcm_v2 --ismb2
[   2.7358 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194_aligned.bin
[   2.7390 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194_aligned.bin zerosbk
[   2.7403 ] adding BCH for nvtboot_applet_t194_aligned.bin
[   2.7439 ] tegrasign_v3.py --key None --list nvtboot_applet_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   2.7441 ] Assuming zero filled SBK key
[   2.7457 ] Warning: pub_key.key is not found
[   2.7463 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_aligned_sigheader.bin.encrypt nvtboot_applet_t194_aligned_sigheader.bin.hash zerosbk
[   2.7494 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[   2.7505 ] Applet version 01.00.0000
[   3.0090 ] Sending mb2
[   3.0093 ] [................................................] 100%
[   3.0781 ] tegrarcm_v2 --boot recovery
[   3.0792 ] Applet version 01.00.0000
[   4.3730 ] tegrarcm_v2 --isapplet
[   4.6425 ] tegrarcm_v2 --ismb2
[   4.6452 ] MB2 Applet version 01.00.0000
[   4.9073 ] tegrarcm_v2 --ismb2
[   4.9090 ] MB2 Applet version 01.00.0000
[   5.1697 ] Retrieving board information
[   5.1715 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[   5.1725 ] MB2 Applet version 01.00.0000
[   5.4794 ] Saved platform info in chip_info.bin
[   5.5113 ] Chip minor revision: 2
[   5.5114 ] Bootrom revision: 0xf
[   5.5116 ] Ram code: 0x2
[   5.5116 ] Chip sku: 0xd0
[   5.5118 ] Chip Sample: non es
[   5.5307 ] Retrieving EEPROM data
[   5.5308 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/cvm.bin
[   5.5317 ] MB2 Applet version 01.00.0000
[   5.8536 ] Saved platform info in /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/cvm.bin
[   5.9496 ] Rebooting to recovery mode
[   5.9531 ] tegrarcm_v2 --ismb2
[   5.9554 ] MB2 Applet version 01.00.0000
[   6.2106 ] Rebooting to recovery mode
[   6.2151 ] tegrarcm_v2 --reboot recovery
[   6.2165 ] MB2 Applet version 01.00.0000
Board ID(2888) FAB(400) sku(0004) revision(P.0)
copying sdram_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p2888.cfg)... done.
copying sdram_config1(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying scr_cold_boot_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying misc_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg)... done.
copying scr_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying pmc_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg)... done.
copying pmic_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg)... done.
copying br_cmd_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg)... done.
copying prod_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg)... done.
copying device_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-sdmmc.cfg)... done.
copying gpioint_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg)... done.
copying misc_cold_boot_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying dev_params(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-sdmmc.cfg)... done.
copying uphy_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg)... done.
copying minratchet_config(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg)... done.
Existing mb2_bootloader(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mts_preboot(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mts_mce(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mts_proper(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
copying bootloader_dtb(/home/work/nvidia/35.4.1/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
Existing tlk(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/tos-optee_t194.img) reused.
Existing bpmp_fw(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/bpmp-2_t194.bin) reused.
copying bpmp_fw_dtb(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb)... done.
Existing eks(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/eks_t194.img) reused.
Existing spe_fw(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing mb1file(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing spefile(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing tegraboot(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing tbcfile(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/nvdisp-init.bin) reused.
Existing scefile(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/camera-rtcpu-t194-rce.img) reused.
Existing wb0boot(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
done.
Existing cfg(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/flash.xml) reused.
Existing applet(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing bl(/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
./tegraflash.py --sdram_config tegra194-mb1-bct-memcfg-p2888.cfg,tegra194-memcfg-sw-override.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini.cfg --pmc_config tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic_config tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --br_cmd_config tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod_config tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --device_config tegra19x-mb1-bct-device-sdmmc.cfg --gpioint_config tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --dev_params tegra194-br-bct-sdmmc.cfg --uphy_config tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg  --bins "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bootloader_dtb tegra194-p2888-0001-p2822-0000.dtb; tlk tos-optee_t194.img; bpmp_fw bpmp-2_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a04.dtb; eks eks_t194.img; kernel boot.img; kernel_dtb tegra194-p2888-0001-p2822-0000.dtb; spe_fw spe_t194.bin" --cfg flash.xml --odmdata 0x9190000 --chip 0x19 --applet mb1_t194_prod.bin --bl nvtboot_recovery_cpu_t194.bin   --cmd "readfuses fuse_info.txt fuses_to_read.xml; reboot recovery"
version 1.0.0
[   0.0148 ] Reading fuses
[   0.0148 ] Generating RCM messages
[   0.0174 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[   0.0182 ] Header already present for mb1_t194_prod.bin
[   0.0251 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0257 ] Assuming zero filled SBK key
[   0.0283 ] tegrasign_v3.py --file mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[   0.0285 ] Assuming zero filled SBK key
[   0.0309 ] Warning: pub_key.key is not found
[   0.0312 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[   0.0356 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[   0.0388 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[   0.0395 ] FwIndex: 1, MinRatchetLevel: 0
[   0.0398 ] FwIndex: 2, MinRatchetLevel: 0
[   0.0398 ] FwIndex: 3, MinRatchetLevel: 0
[   0.0398 ] FwIndex: 4, MinRatchetLevel: 0
[   0.0398 ] FwIndex: 5, MinRatchetLevel: 0
[   0.0398 ] FwIndex: 6, MinRatchetLevel: 0
[   0.0398 ] FwIndex: 7, MinRatchetLevel: 0
[   0.0398 ] FwIndex: 11, MinRatchetLevel: 0
[   0.0398 ] FwIndex: 12, MinRatchetLevel: 0
[   0.0398 ] FwIndex: 13, MinRatchetLevel: 0
[   0.0398 ] FwIndex: 14, MinRatchetLevel: 0
[   0.0399 ] FwIndex: 15, MinRatchetLevel: 0
[   0.0399 ] FwIndex: 16, MinRatchetLevel: 0
[   0.0399 ] FwIndex: 17, MinRatchetLevel: 0
[   0.0399 ] FwIndex: 18, MinRatchetLevel: 0
[   0.0399 ] FwIndex: 19, MinRatchetLevel: 0
[   0.0399 ] FwIndex: 30, MinRatchetLevel: 0
[   0.0399 ] FwIndex: 31, MinRatchetLevel: 0
[   0.0399 ]
[   0.0423 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[   0.0431 ] RCM 0 is saved as rcm_0.rcm
[   0.0453 ] RCM 1 is saved as rcm_1.rcm
[   0.0453 ] RCM 2 is saved as rcm_2.rcm
[   0.0453 ] List of rcm files are saved in rcm_list.xml
[   0.0453 ]
[   0.0453 ] Signing RCM messages
[   0.0485 ] tegrasign_v3.py --key None --list rcm_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[   0.0487 ] Assuming zero filled SBK key
[   0.0536 ] Warning: pub_key.key is not found
[   0.0530 ] Copying signature to RCM mesages
[   0.0554 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.0569 ] Boot Rom communication
[   0.0598 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[   0.0606 ] BR_CID: 0x88021911643171840800000010ff8180
[   0.1627 ] RCM version 0X190001
[   0.2669 ] Boot Rom communication completed
[   2.3125 ] tegrarcm_v2 --isapplet
[   2.3155 ] Applet version 01.00.0000
[   2.5836 ] Parsing fuse info as per xml file
[   2.5848 ] tegraparser_v2 --get_fuse_names fuses_to_read.xml read_fuse_names.txt
[   2.5865 ] WARNING: default chip 0x19 for getting fuse name
[   2.5865 ] MagicId=0x45535546 version=0x1
[   2.5865 ]
[   2.5866 ] trying to read fuse with CPU binary
[   2.5884 ] tegrasign_v3.py --key None --getmode mode.txt
[   2.5886 ] Assuming zero filled SBK key
[   2.5882 ] Parsing partition layout
[   2.5894 ] tegraparser_v2 --pt flash.xml.tmp
[   2.5907 ] Creating list of images to be signed
[   2.5920 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[   2.5934 ] MB1: Nvheader already present is mb1_t194_prod_aligned.bin
[   2.5946 ] Header already present for mb1_t194_prod_aligned_sigheader.bin
[   2.5957 ] MB1: Nvheader already present is mb1_t194_prod_aligned.bin
[   2.5977 ] Header already present for mb1_t194_prod_aligned_sigheader.bin
[   2.5985 ] adding BCH for spe_t194_aligned.bin
[   2.5994 ] adding BCH for nvtboot_t194_aligned.bin
[   2.6007 ] Header already present for preboot_c10_prod_cr_aligned.bin
[   2.6035 ] adding BCH for spe_t194_aligned.bin
[   2.6038 ] adding BCH for nvtboot_t194_aligned.bin
[   2.6052 ] Header already present for preboot_c10_prod_cr_aligned.bin
[   2.6082 ] Header already present for mce_c10_prod_cr_aligned.bin
[   2.6087 ] adding BCH for mts_c10_prod_cr_aligned.bin
[   2.6173 ] adding BCH for nvdisp-init_aligned.bin
[   2.6718 ] adding BCH for tegra194-p2888-0001-p2822-0000_aligned.dtb
[   2.7176 ] adding BCH for tos-optee_t194_aligned.img
[   2.7246 ] adding BCH for eks_t194_aligned.img
[   2.7398 ] adding BCH for bpmp-2_t194_aligned.bin
[   2.7419 ] adding BCH for tegra194-a02-bpmp-p2888-a04_aligned.dtb
[   2.7593 ] adding BCH for camera-rtcpu-t194-rce_aligned.img
[   2.7746 ] adding BCH for adsp-fw_aligned.bin
[   2.7831 ] Header already present for warmboot_t194_prod_aligned.bin
[   2.7893 ] Header already present for mce_c10_prod_cr_aligned.bin
[   2.7901 ] adding BCH for mts_c10_prod_cr_aligned.bin
[   2.8036 ] adding BCH for nvdisp-init_aligned.bin
[   2.8687 ] adding BCH for tegra194-p2888-0001-p2822-0000_aligned.dtb
[   2.9169 ] adding BCH for tos-optee_t194_aligned.img
[   2.9258 ] adding BCH for eks_t194_aligned.img
[   2.9419 ] adding BCH for bpmp-2_t194_aligned.bin
[   2.9446 ] adding BCH for tegra194-a02-bpmp-p2888-a04_aligned.dtb
[   2.9630 ] adding BCH for camera-rtcpu-t194-rce_aligned.img
[   2.9802 ] adding BCH for adsp-fw_aligned.bin
[   2.9900 ] Header already present for warmboot_t194_prod_aligned.bin
[   2.9971 ] Filling MB1 storage info
[   2.9971 ] Parsing dev params for multi chains
[   2.9971 ] Generating br-bct
[   2.9997 ] Performing cfg overlay
[   2.9997 ] ['tegra194-mb1-bct-memcfg-p2888.cfg', 'tegra194-memcfg-sw-override.cfg']
[   3.0000 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p2888.cfg -s tegra194-memcfg-sw-override.cfg -o /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/5238/tmp8blf2yfw1.cfg
[   3.0366 ] Updating dev and MSS params in BR BCT
[   3.0366 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/5238/tmp8blf2yfw1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   3.0916 ] Updating bl info
[   3.0951 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[   3.0978 ] Generating signatures
[   3.1007 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key
[   3.1009 ] Assuming zero filled SBK key
[   3.2022 ] Warning: pub_key.key is not found
[   3.2017 ] Parsing dev params for multi chains
[   3.2017 ] Generating br-bct
[   3.2047 ] Performing cfg overlay
[   3.2047 ] ['/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/5238/tmp8blf2yfw1.cfg']
[   3.2047 ] Updating dev and MSS params in BR BCT
[   3.2048 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/5238/tmp8blf2yfw1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   3.2602 ] Updating bl info
[   3.2624 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   3.2657 ] Updating smd info
[   3.2681 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[   3.2694 ] Updating Odmdata
[   3.2718 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0x9190000
[   3.2749 ] Signing BCT
[   3.2750 ] Get Signed section of bct
[   3.2784 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[   3.2825 ] tegrasign_v3.py --key None --list bct_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[   3.2827 ] Assuming zero filled SBK key
[   3.2840 ] Warning: pub_key.key is not found
[   3.2835 ] Updating BCT with signature
[   3.2856 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[   3.2866 ] Generating coldboot mb1-bct
[   3.2891 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/5238/tmp8blf2yfw1.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[   3.2899 ] MB1-BCT version: 0x1
[   3.2904 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[   3.2906 ] Added Platform Config 0 data with size :- 3168
[   3.2926 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[   3.2927 ] Added Platform Config 1 data with size :- 19640
[   3.2992 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[   3.2994 ] Added Platform Config 2 data with size :- 24
[   3.2996 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[   3.2999 ] File read failed
[   3.2999 ] Added Platform Config 4 data with size :- 348
[   3.3001 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[   3.3003 ] Added Platform Config 3 data with size :- 92
[   3.3003 ]
[   3.3003 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[   3.3003 ] Added Platform Config 5 data with size :- 68
[   3.3003 ]
[   3.3003 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[   3.3003 ] Added Platform Config 7 data with size :- 392
[   3.3003 ]
[   3.3003 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[   3.3003 ] Added Platform Config 8 data with size :- 12
[   3.3003 ]
[   3.3003 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[   3.3003 ] Added Platform Config 9 data with size :- 32
[   3.3003 ]
[   3.3004 ] Updating mb1-bct with firmware information
[   3.3030 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   3.3044 ] Updating mb1-bct with storage information
[   3.3070 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[   3.3096 ] Updating mb1-bct with ratchet information
[   3.3118 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[   3.3126 ] FwIndex: 1, MinRatchetLevel: 0
[   3.3130 ] FwIndex: 2, MinRatchetLevel: 0
[   3.3130 ] FwIndex: 3, MinRatchetLevel: 0
[   3.3131 ] FwIndex: 4, MinRatchetLevel: 0
[   3.3131 ] FwIndex: 5, MinRatchetLevel: 0
[   3.3131 ] FwIndex: 6, MinRatchetLevel: 0
[   3.3131 ] FwIndex: 7, MinRatchetLevel: 0
[   3.3131 ] FwIndex: 11, MinRatchetLevel: 0
[   3.3131 ] FwIndex: 12, MinRatchetLevel: 0
[   3.3131 ] FwIndex: 13, MinRatchetLevel: 0
[   3.3131 ] FwIndex: 14, MinRatchetLevel: 0
[   3.3131 ] FwIndex: 15, MinRatchetLevel: 0
[   3.3131 ] FwIndex: 16, MinRatchetLevel: 0
[   3.3131 ] FwIndex: 17, MinRatchetLevel: 0
[   3.3131 ] FwIndex: 18, MinRatchetLevel: 0
[   3.3131 ] FwIndex: 19, MinRatchetLevel: 0
[   3.3131 ] FwIndex: 30, MinRatchetLevel: 0
[   3.3131 ] FwIndex: 31, MinRatchetLevel: 0
[   3.3131 ]
[   3.3154 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1_aligned.bct
[   3.3184 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   3.3191 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   3.3224 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   3.3226 ] Assuming zero filled SBK key
[   3.3246 ] Warning: pub_key.key is not found
[   3.3264 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   3.3280 ] Generating recovery mb1-bct
[   3.3305 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/5238/tmp8blf2yfw1.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[   3.3313 ] MB1-BCT version: 0x1
[   3.3318 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[   3.3321 ] Added Platform Config 0 data with size :- 3168
[   3.3332 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[   3.3334 ] Added Platform Config 1 data with size :- 19640
[   3.3407 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[   3.3409 ] Added Platform Config 2 data with size :- 24
[   3.3411 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[   3.3414 ] File read failed
[   3.3415 ] File read failed
[   3.3415 ] Added Platform Config 4 data with size :- 348
[   3.3420 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[   3.3420 ] Added Platform Config 3 data with size :- 92
[   3.3420 ]
[   3.3420 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[   3.3420 ] Added Platform Config 5 data with size :- 68
[   3.3420 ]
[   3.3420 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[   3.3420 ] Added Platform Config 7 data with size :- 392
[   3.3420 ]
[   3.3420 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[   3.3420 ] Added Platform Config 8 data with size :- 12
[   3.3420 ]
[   3.3420 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[   3.3420 ] Added Platform Config 9 data with size :- 32
[   3.3420 ]
[   3.3421 ] Updating mb1-bct with firmware information
[   3.3448 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[   3.3463 ] Updating mb1-bct with storage information
[   3.3484 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[   3.3497 ] Updating mb1-bct with ratchet information
[   3.3508 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[   3.3520 ] FwIndex: 1, MinRatchetLevel: 0
[   3.3523 ] FwIndex: 2, MinRatchetLevel: 0
[   3.3523 ] FwIndex: 3, MinRatchetLevel: 0
[   3.3523 ] FwIndex: 4, MinRatchetLevel: 0
[   3.3523 ] FwIndex: 5, MinRatchetLevel: 0
[   3.3523 ] FwIndex: 6, MinRatchetLevel: 0
[   3.3523 ] FwIndex: 7, MinRatchetLevel: 0
[   3.3523 ] FwIndex: 11, MinRatchetLevel: 0
[   3.3523 ] FwIndex: 12, MinRatchetLevel: 0
[   3.3523 ] FwIndex: 13, MinRatchetLevel: 0
[   3.3523 ] FwIndex: 14, MinRatchetLevel: 0
[   3.3523 ] FwIndex: 15, MinRatchetLevel: 0
[   3.3523 ] FwIndex: 16, MinRatchetLevel: 0
[   3.3523 ] FwIndex: 17, MinRatchetLevel: 0
[   3.3523 ] FwIndex: 18, MinRatchetLevel: 0
[   3.3523 ] FwIndex: 19, MinRatchetLevel: 0
[   3.3523 ] FwIndex: 30, MinRatchetLevel: 0
[   3.3523 ] FwIndex: 31, MinRatchetLevel: 0
[   3.3523 ]
[   3.3537 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1_aligned.bct
[   3.3569 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   3.3575 ] adding BCH for mb1_bct_MB1_aligned.bct
[   3.3610 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   3.3612 ] Assuming zero filled SBK key
[   3.3632 ] Warning: pub_key.key is not found
[   3.3649 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   3.3667 ] Generating coldboot mem-bct
[   3.3691 ] tegrabct_v2 --chip 0x19 0 --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/5238/tmp8blf2yfw1.cfg --membct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/5238/tmp8blf2yfw1_1.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/5238/tmp8blf2yfw1_2.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/5238/tmp8blf2yfw1_3.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/5238/tmp8blf2yfw1_4.bct
[   3.3719 ] Packing sdram param for instance[0]
[   3.4259 ] Packing sdram param for instance[1]
[   3.4259 ] Packing sdram param for instance[2]
[   3.4260 ] Packing sdram param for instance[3]
[   3.4260 ] Packing sdram param for instance[4]
[   3.4260 ] Packing sdram param for instance[5]
[   3.4260 ] Packing sdram param for instance[6]
[   3.4260 ] Packing sdram param for instance[7]
[   3.4260 ] Packing sdram param for instance[8]
[   3.4260 ] Packing sdram param for instance[9]
[   3.4260 ] Packing sdram param for instance[10]
[   3.4260 ] Packing sdram param for instance[11]
[   3.4260 ] Packing sdram param for instance[12]
[   3.4260 ] Packing sdram param for instance[13]
[   3.4260 ] Packing sdram param for instance[14]
[   3.4260 ] Packing sdram param for instance[15]
[   3.4261 ]
[   3.4261 ] Getting sector size from pt
[   3.4277 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[   3.4294 ] BlockSize read from layout is 200
[   3.4318 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/5238/tmp8blf2yfw1_1.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/5238/tmp8blf2yfw1_2.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/5238/tmp8blf2yfw1_3.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/5238/tmp8blf2yfw1_4.bct
[   3.4328 ] adding BCH for /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/5238/tmp8blf2yfw1_1.bct
[   3.4369 ] tegrahost_v2 --chip 0x19 --align mem_coldboot_aligned.bct
[   3.4399 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[   3.4406 ] Header already present for mem_coldboot_aligned.bct
[   3.4445 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   3.4447 ] Assuming zero filled SBK key
[   3.4465 ] Warning: pub_key.key is not found
[   3.4479 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[   3.4497 ] Generating recovery mem-bct
[   3.4519 ] tegrabct_v2 --chip 0x19 0 --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/5238/tmp8blf2yfw1.cfg --membct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/5238/tmp8blf2yfw1_1.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/5238/tmp8blf2yfw1_2.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/5238/tmp8blf2yfw1_3.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/5238/tmp8blf2yfw1_4.bct
[   3.4526 ] Packing sdram param for instance[0]
[   3.5062 ] Packing sdram param for instance[1]
[   3.5063 ] Packing sdram param for instance[2]
[   3.5064 ] Packing sdram param for instance[3]
[   3.5065 ] Packing sdram param for instance[4]
[   3.5066 ] Packing sdram param for instance[5]
[   3.5067 ] Packing sdram param for instance[6]
[   3.5069 ] Packing sdram param for instance[7]
[   3.5069 ] Packing sdram param for instance[8]
[   3.5069 ] Packing sdram param for instance[9]
[   3.5069 ] Packing sdram param for instance[10]
[   3.5069 ] Packing sdram param for instance[11]
[   3.5069 ] Packing sdram param for instance[12]
[   3.5069 ] Packing sdram param for instance[13]
[   3.5069 ] Packing sdram param for instance[14]
[   3.5069 ] Packing sdram param for instance[15]
[   3.5070 ]
[   3.5071 ] Reading ramcode from backup chip_info.bin file
[   3.5071 ] RAMCODE Read from Device: 2
[   3.5086 ] tegrahost_v2 --chip 0x19 --align mem_rcm_aligned.bct
[   3.5129 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[   3.5138 ] adding BCH for mem_rcm_aligned.bct
[   3.5175 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   3.5177 ] Assuming zero filled SBK key
[   3.5192 ] Warning: pub_key.key is not found
[   3.5209 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[   3.5230 ] Copying signatures
[   3.5240 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[   3.7485 ] Sending BCTs
[   3.7499 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[   3.7508 ] Applet version 01.00.0000
[   4.0072 ] Sending bct_bootrom
[   4.0072 ] [................................................] 100%
[   4.0384 ] Sending bct_mb1
[   4.0617 ] [................................................] 100%
[   4.0943 ] Sending bct_mem
[   4.1527 ] [................................................] 100%
[   4.2470 ] Generating blob
[   4.2491 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_cpu_t194_aligned.bin
[   4.2525 ] tegrahost_v2 --chip 0x19 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvtboot_recovery_cpu_t194_aligned.bin zerosbk
[   4.2536 ] adding BCH for blob_nvtboot_recovery_cpu_t194_aligned.bin
[   4.2589 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_cpu_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   4.2591 ] Assuming zero filled SBK key
[   4.2609 ] Warning: pub_key.key is not found
[   4.2615 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_cpu_t194_aligned_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_t194_aligned_sigheader.bin.hash zerosbk
[   4.2658 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_t194_aligned.bin
[   4.2676 ] tegrahost_v2 --chip 0x19 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvtboot_recovery_t194_aligned.bin zerosbk
[   4.2684 ] adding BCH for blob_nvtboot_recovery_t194_aligned.bin
[   4.2730 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   4.2732 ] Assuming zero filled SBK key
[   4.2748 ] Warning: pub_key.key is not found
[   4.2756 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_t194_aligned_sigheader.bin.encrypt blob_nvtboot_recovery_t194_aligned_sigheader.bin.hash zerosbk
[   4.2798 ] tegrahost_v2 --chip 0x19 --align blob_preboot_c10_prod_cr_aligned.bin
[   4.2824 ] tegrahost_v2 --chip 0x19 0 --magicid MTSP --appendsigheader blob_preboot_c10_prod_cr_aligned.bin zerosbk
[   4.2833 ] Header already present for blob_preboot_c10_prod_cr_aligned.bin
[   4.2853 ] tegrasign_v3.py --key None --list blob_preboot_c10_prod_cr_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   4.2854 ] Assuming zero filled SBK key
[   4.2869 ] Warning: pub_key.key is not found
[   4.2888 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_preboot_c10_prod_cr_aligned_sigheader.bin.encrypt blob_preboot_c10_prod_cr_aligned_sigheader.bin.hash zerosbk
[   4.2920 ] tegrahost_v2 --chip 0x19 --align blob_mce_c10_prod_cr_aligned.bin
[   4.2935 ] tegrahost_v2 --chip 0x19 0 --magicid MTSM --appendsigheader blob_mce_c10_prod_cr_aligned.bin zerosbk
[   4.2942 ] Header already present for blob_mce_c10_prod_cr_aligned.bin
[   4.2983 ] tegrasign_v3.py --key None --list blob_mce_c10_prod_cr_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   4.2985 ] Assuming zero filled SBK key
[   4.3004 ] Warning: pub_key.key is not found
[   4.3021 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mce_c10_prod_cr_aligned_sigheader.bin.encrypt blob_mce_c10_prod_cr_aligned_sigheader.bin.hash zerosbk
[   4.3082 ] tegrahost_v2 --chip 0x19 --align blob_mts_c10_prod_cr_aligned.bin
[   4.3112 ] tegrahost_v2 --chip 0x19 0 --magicid MTSB --appendsigheader blob_mts_c10_prod_cr_aligned.bin zerosbk
[   4.3121 ] adding BCH for blob_mts_c10_prod_cr_aligned.bin
[   4.3648 ] tegrasign_v3.py --key None --list blob_mts_c10_prod_cr_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   4.3650 ] Assuming zero filled SBK key
[   4.3733 ] Warning: pub_key.key is not found
[   4.3752 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mts_c10_prod_cr_aligned_sigheader.bin.encrypt blob_mts_c10_prod_cr_aligned_sigheader.bin.hash zerosbk
[   4.4122 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-p2888-0001-p2822-0000_aligned.dtb
[   4.4157 ] tegrahost_v2 --chip 0x19 0 --magicid CDTB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-p2888-0001-p2822-0000_aligned.dtb zerosbk
[   4.4165 ] adding BCH for blob_tegra194-p2888-0001-p2822-0000_aligned.dtb
[   4.4258 ] tegrasign_v3.py --key None --list blob_tegra194-p2888-0001-p2822-0000_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   4.4261 ] Assuming zero filled SBK key
[   4.4282 ] Warning: pub_key.key is not found
[   4.4298 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-p2888-0001-p2822-0000_aligned_sigheader.dtb.encrypt blob_tegra194-p2888-0001-p2822-0000_aligned_sigheader.dtb.hash zerosbk
[   4.4375 ] tegrahost_v2 --chip 0x19 --align blob_tos-optee_t194_aligned.img
[   4.4417 ] tegrahost_v2 --chip 0x19 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tos-optee_t194_aligned.img zerosbk
[   4.4427 ] adding BCH for blob_tos-optee_t194_aligned.img
[   4.4595 ] tegrasign_v3.py --key None --list blob_tos-optee_t194_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key
[   4.4597 ] Assuming zero filled SBK key
[   4.4627 ] Warning: pub_key.key is not found
[   4.4647 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tos-optee_t194_aligned_sigheader.img.encrypt blob_tos-optee_t194_aligned_sigheader.img.hash zerosbk
[   4.4781 ] tegrahost_v2 --chip 0x19 --align blob_bpmp-2_t194_aligned.bin
[   4.4812 ] tegrahost_v2 --chip 0x19 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader blob_bpmp-2_t194_aligned.bin zerosbk
[   4.4827 ] adding BCH for blob_bpmp-2_t194_aligned.bin
[   4.5021 ] tegrasign_v3.py --key None --list blob_bpmp-2_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   4.5024 ] Assuming zero filled SBK key
[   4.5054 ] Warning: pub_key.key is not found
[   4.5072 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_bpmp-2_t194_aligned_sigheader.bin.encrypt blob_bpmp-2_t194_aligned_sigheader.bin.hash zerosbk
[   4.5197 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-a02-bpmp-p2888-a04_aligned.dtb
[   4.5219 ] tegrahost_v2 --chip 0x19 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-a02-bpmp-p2888-a04_aligned.dtb zerosbk
[   4.5228 ] adding BCH for blob_tegra194-a02-bpmp-p2888-a04_aligned.dtb
[   4.5413 ] tegrasign_v3.py --key None --list blob_tegra194-a02-bpmp-p2888-a04_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   4.5415 ] Assuming zero filled SBK key
[   4.5551 ] Warning: pub_key.key is not found
[   4.5559 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-a02-bpmp-p2888-a04_aligned_sigheader.dtb.encrypt blob_tegra194-a02-bpmp-p2888-a04_aligned_sigheader.dtb.hash zerosbk
[   4.5682 ] tegrahost_v2 --chip 0x19 --align blob_eks_t194_aligned.img
[   4.5699 ] tegrahost_v2 --chip 0x19 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_eks_t194_aligned.img zerosbk
[   4.5708 ] adding BCH for blob_eks_t194_aligned.img
[   4.5741 ] tegrasign_v3.py --key None --list blob_eks_t194_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key
[   4.5743 ] Assuming zero filled SBK key
[   4.5764 ] Warning: pub_key.key is not found
[   4.5769 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_eks_t194_aligned_sigheader.img.encrypt blob_eks_t194_aligned_sigheader.img.hash zerosbk
[   4.8399 ] Disable RCE in rcm kernel-dtb.
[   4.8867 ] tegrahost_v2 --chip 0x19 --align blob_spe_t194_aligned.bin
[   4.8902 ] tegrahost_v2 --chip 0x19 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_spe_t194_aligned.bin zerosbk
[   4.8911 ] adding BCH for blob_spe_t194_aligned.bin
[   4.8959 ] tegrasign_v3.py --key None --list blob_spe_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   4.8961 ] Assuming zero filled SBK key
[   4.8976 ] Warning: pub_key.key is not found
[   4.8998 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_spe_t194_aligned_sigheader.bin.encrypt blob_spe_t194_aligned_sigheader.bin.hash zerosbk
[   4.9040 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[   4.9051 ] number of images in blob are 13
[   4.9052 ] blobsize is 7909545
[   4.9052 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 232976
[   4.9194 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 206016
[   4.9195 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 24016
[   4.9197 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 145184
[   4.9198 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3430416
[   4.9215 ] Added binary blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt of size 397984
[   4.9222 ] Added binary blob_tos-optee_t194_sigheader.img.encrypt of size 977664
[   4.9227 ] Added binary blob_bpmp-2_t194_sigheader.bin.encrypt of size 1007392
[   4.9232 ] Added binary blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt of size 993408
[   4.9237 ] Added binary blob_eks_t194_sigheader.img.encrypt of size 5136
[   4.9239 ] Added binary blob_boot.img of size 21
[   4.9240 ] Added binary blob_tegra194-p2888-0001-p2822-0000.dtb of size 393884
[   4.9242 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 95232
[   4.9303 ] Sending bootloader and pre-requisite binaries
[   4.9315 ] tegrarcm_v2 --download blob blob.bin
[   4.9330 ] Applet version 01.00.0000
[   5.1939 ] Sending blob
[   5.1942 ] [................................................] 100%
[   6.9901 ] tegrarcm_v2 --boot recovery
[   6.9916 ] Applet version 01.00.0000
[   8.2825 ] tegrarcm_v2 --isapplet
[   9.3680 ] tegrarcm_v2 --ismb2
[   9.6321 ] tegradevflash_v2 --iscpubl
[   9.6334 ] Bootloader version 01.00.0000
[   9.7873 ] Bootloader version 01.00.0000
[   9.8396 ] tegraparser_v2 --read_fusetype PublicKeyHash read_fuse.bin
[   9.8409 ] WARNING: default chip 0x19 for parsing fuse info
[   9.8409 ]
[   9.8422 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   9.8432 ] Bootloader version 01.00.0000
[   9.9987 ] Saved read fuses in file __fuse_read_scatter.bin
[  10.0383 ] Fuse read successful
[  10.0608 ] tegraparser_v2 --read_fusetype SecureBootKey read_fuse.bin
[  10.0623 ] WARNING: default chip 0x19 for parsing fuse info
[  10.0624 ]
[  10.0637 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  10.0649 ] Bootloader version 01.00.0000
[  10.2170 ] Saved read fuses in file __fuse_read_scatter.bin
[  10.2592 ] Fuse read successful
[  10.2850 ] tegraparser_v2 --read_fusetype Kek0 read_fuse.bin
[  10.2866 ] WARNING: default chip 0x19 for parsing fuse info
[  10.2867 ]
[  10.2879 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  10.2889 ] Bootloader version 01.00.0000
[  10.4404 ] Saved read fuses in file __fuse_read_scatter.bin
[  10.4822 ] Fuse read successful
[  10.5033 ] tegraparser_v2 --read_fusetype Kek1 read_fuse.bin
[  10.5042 ] WARNING: default chip 0x19 for parsing fuse info
[  10.5066 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  10.5074 ] Bootloader version 01.00.0000
[  10.6619 ] Saved read fuses in file __fuse_read_scatter.bin
[  10.7029 ] Fuse read successful
[  10.7248 ] tegraparser_v2 --read_fusetype Kek2 read_fuse.bin
[  10.7264 ] WARNING: default chip 0x19 for parsing fuse info
[  10.7264 ]
[  10.7283 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  10.7301 ] Bootloader version 01.00.0000
[  10.8835 ] Saved read fuses in file __fuse_read_scatter.bin
[  10.9228 ] Fuse read successful
[  10.9478 ] tegraparser_v2 --read_fusetype Kek256 read_fuse.bin
[  10.9491 ] WARNING: default chip 0x19 for parsing fuse info
[  10.9522 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  10.9533 ] Bootloader version 01.00.0000
[  11.1181 ] Saved read fuses in file __fuse_read_scatter.bin
[  11.1572 ] Fuse read successful
[  11.1872 ] tegraparser_v2 --read_fusetype BootSecurityInfo read_fuse.bin
[  11.1893 ] WARNING: default chip 0x19 for parsing fuse info
[  11.1893 ]
[  11.1908 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  11.1919 ] Bootloader version 01.00.0000
[  11.3474 ] Saved read fuses in file __fuse_read_scatter.bin
[  11.3919 ] Fuse read successful
[  11.4152 ] tegraparser_v2 --read_fusetype JtagDisable read_fuse.bin
[  11.4167 ] WARNING: default chip 0x19 for parsing fuse info
[  11.4167 ]
[  11.4179 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  11.4191 ] Bootloader version 01.00.0000
[  11.5674 ] Saved read fuses in file __fuse_read_scatter.bin
[  11.6093 ] Fuse read successful
[  11.6331 ] tegraparser_v2 --read_fusetype SecurityMode read_fuse.bin
[  11.6342 ] WARNING: default chip 0x19 for parsing fuse info
[  11.6362 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  11.6372 ] Bootloader version 01.00.0000
[  11.7871 ] Saved read fuses in file __fuse_read_scatter.bin
[  11.8272 ] Fuse read successful
[  11.8509 ] tegraparser_v2 --read_fusetype SwReserved read_fuse.bin
[  11.8535 ] WARNING: default chip 0x19 for parsing fuse info
[  11.8535 ]
[  11.8563 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  11.8571 ] Bootloader version 01.00.0000
[  12.0131 ] Saved read fuses in file __fuse_read_scatter.bin
[  12.0554 ] Fuse read successful
[  12.0770 ] tegraparser_v2 --read_fusetype DebugAuthentication read_fuse.bin
[  12.0784 ] WARNING: default chip 0x19 for parsing fuse info
[  12.0784 ]
[  12.0800 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  12.0816 ] Bootloader version 01.00.0000
[  12.2326 ] Saved read fuses in file __fuse_read_scatter.bin
[  12.2872 ] Fuse read successful
[  12.3090 ] tegraparser_v2 --read_fusetype OdmId read_fuse.bin
[  12.3098 ] WARNING: default chip 0x19 for parsing fuse info
[  12.3125 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  12.3144 ] Bootloader version 01.00.0000
[  12.4647 ] Saved read fuses in file __fuse_read_scatter.bin
[  12.5059 ] Fuse read successful
[  12.5276 ] tegraparser_v2 --read_fusetype OdmLock read_fuse.bin
[  12.5300 ] WARNING: default chip 0x19 for parsing fuse info
[  12.5300 ]
[  12.5331 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  12.5343 ] Bootloader version 01.00.0000
[  12.6869 ] Saved read fuses in file __fuse_read_scatter.bin
[  12.7269 ] Fuse read successful
[  12.7501 ] tegraparser_v2 --read_fusetype ReservedOdm0 read_fuse.bin
[  12.7512 ] WARNING: default chip 0x19 for parsing fuse info
[  12.7537 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  12.7546 ] Bootloader version 01.00.0000
[  12.9050 ] Saved read fuses in file __fuse_read_scatter.bin
[  12.9456 ] Fuse read successful
[  12.9687 ] tegraparser_v2 --read_fusetype ReservedOdm1 read_fuse.bin
[  12.9701 ] WARNING: default chip 0x19 for parsing fuse info
[  12.9701 ]
[  12.9714 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  12.9725 ] Bootloader version 01.00.0000
[  13.1252 ] Saved read fuses in file __fuse_read_scatter.bin
[  13.1685 ] Fuse read successful
[  13.1899 ] tegraparser_v2 --read_fusetype ReservedOdm2 read_fuse.bin
[  13.1912 ] WARNING: default chip 0x19 for parsing fuse info
[  13.1912 ]
[  13.1927 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  13.1941 ] Bootloader version 01.00.0000
[  13.3512 ] Saved read fuses in file __fuse_read_scatter.bin
[  13.3911 ] Fuse read successful
[  13.4189 ] tegraparser_v2 --read_fusetype ReservedOdm3 read_fuse.bin
[  13.4212 ] WARNING: default chip 0x19 for parsing fuse info
[  13.4253 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  13.4264 ] Bootloader version 01.00.0000
[  13.5823 ] Saved read fuses in file __fuse_read_scatter.bin
[  13.6221 ] Fuse read successful
[  13.6451 ] tegraparser_v2 --read_fusetype ReservedOdm4 read_fuse.bin
[  13.6466 ] WARNING: default chip 0x19 for parsing fuse info
[  13.6466 ]
[  13.6480 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  13.6489 ] Bootloader version 01.00.0000
[  13.7988 ] Saved read fuses in file __fuse_read_scatter.bin
[  13.8406 ] Fuse read successful
[  13.8627 ] tegraparser_v2 --read_fusetype ReservedOdm5 read_fuse.bin
[  13.8642 ] WARNING: default chip 0x19 for parsing fuse info
[  13.8642 ]
[  13.8666 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  13.8678 ] Bootloader version 01.00.0000
[  14.0215 ] Saved read fuses in file __fuse_read_scatter.bin
[  14.0632 ] Fuse read successful
[  14.0864 ] tegraparser_v2 --read_fusetype ReservedOdm6 read_fuse.bin
[  14.0897 ] WARNING: default chip 0x19 for parsing fuse info
[  14.0897 ]
[  14.0909 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  14.0918 ] Bootloader version 01.00.0000
[  14.2468 ] Saved read fuses in file __fuse_read_scatter.bin
[  14.2834 ] Fuse read successful
[  14.3058 ] tegraparser_v2 --read_fusetype ReservedOdm7 read_fuse.bin
[  14.3066 ] WARNING: default chip 0x19 for parsing fuse info
[  14.3091 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  14.3100 ] Bootloader version 01.00.0000
[  14.4637 ] Saved read fuses in file __fuse_read_scatter.bin
[  14.5049 ] Fuse read successful
[  14.5287 ] tegraparser_v2 --read_fusetype ReservedOdm8 read_fuse.bin
[  14.5317 ] WARNING: default chip 0x19 for parsing fuse info
[  14.5317 ]
[  14.5347 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  14.5357 ] Bootloader version 01.00.0000
[  14.6835 ] Saved read fuses in file __fuse_read_scatter.bin
[  14.7215 ] Fuse read successful
[  14.7434 ] tegraparser_v2 --read_fusetype ReservedOdm9 read_fuse.bin
[  14.7448 ] WARNING: default chip 0x19 for parsing fuse info
[  14.7448 ]
[  14.7459 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  14.7484 ] Bootloader version 01.00.0000
[  14.8977 ] Saved read fuses in file __fuse_read_scatter.bin
[  14.9374 ] Fuse read successful
[  14.9616 ] tegraparser_v2 --read_fusetype ReservedOdm10 read_fuse.bin
[  14.9634 ] WARNING: default chip 0x19 for parsing fuse info
[  14.9647 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  14.9656 ] Bootloader version 01.00.0000
[  15.1241 ] Saved read fuses in file __fuse_read_scatter.bin
[  15.1660 ] Fuse read successful
[  15.1874 ] tegraparser_v2 --read_fusetype ReservedOdm11 read_fuse.bin
[  15.1887 ] WARNING: default chip 0x19 for parsing fuse info
[  15.1887 ]
[  15.1900 ] tegradevflash_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[  15.1909 ] Bootloader version 01.00.0000
[  15.3496 ] Saved read fuses in file __fuse_read_scatter.bin
[  15.3922 ] Fuse read successful
[  15.4117 ] Rebooting to recovery mode
[  15.4139 ] tegrarcm_v2 --ismb2
[  15.6836 ] tegradevflash_v2 --reboot recovery
[  15.6846 ] Bootloader version 01.00.0000
Fuse reading is done. The fuse values have been saved in: /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/fuse_info.txt
PublicKeyHash: 0000000000000000000000000000000000000000000000000000000000000000
SecureBootKey: 00000000000000000000000000000000
Kek0: 00000000000000000000000000000000
Kek1: 00000000000000000000000000000000
Kek2: 00000000000000000000000000000000
Kek256: 0000000000000000000000000000000000000000000000000000000000000000
BootSecurityInfo: 00000000
JtagDisable: 00000000
SecurityMode: 00000000
SwReserved: 00000000
DebugAuthentication: 00000000
OdmId: 0000000000000000
OdmLock: 00000000
ReservedOdm0: 00000000
ReservedOdm1: 00000000
ReservedOdm2: 00000000
ReservedOdm3: 00000000
ReservedOdm4: 00000000
ReservedOdm5: 00000000
ReservedOdm6: 00000000
ReservedOdm7: 00000000
ReservedOdm8: 00000000
ReservedOdm9: 00000000
ReservedOdm10: 00000000
ReservedOdm11: 00000000
done.
*** Start fusing from fuse configuration ...
./tegraflash.py --sdram_config tegra194-mb1-bct-memcfg-p2888.cfg,tegra194-memcfg-sw-override.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini.cfg --pmc_config tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic_config tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --br_cmd_config tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod_config tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --device_config tegra19x-mb1-bct-device-sdmmc.cfg --gpioint_config tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --dev_params tegra194-br-bct-sdmmc.cfg --uphy_config tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg  --bins "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bootloader_dtb tegra194-p2888-0001-p2822-0000.dtb; tlk tos-optee_t194.img; bpmp_fw bpmp-2_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a04.dtb; eks eks_t194.img; kernel boot.img; kernel_dtb tegra194-p2888-0001-p2822-0000.dtb; spe_fw spe_t194.bin" --cfg flash.xml --odmdata 0x9190000 --chip 0x19 --applet mb1_t194_prod.bin --bl nvtboot_recovery_cpu_t194.bin  --cmd "burnfuses dummy fuse_qIz1QZ.xml"
version 1.0.0
[   0.0138 ] Burning fuses
[   0.0138 ] Generating RCM messages
[   0.0156 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[   0.0165 ] Header already present for mb1_t194_prod.bin
[   0.0218 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0220 ] Assuming zero filled SBK key
[   0.0243 ] tegrasign_v3.py --file mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[   0.0245 ] Assuming zero filled SBK key
[   0.0268 ] Warning: pub_key.key is not found
[   0.0282 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[   0.0337 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[   0.0372 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[   0.0381 ] FwIndex: 1, MinRatchetLevel: 0
[   0.0385 ] FwIndex: 2, MinRatchetLevel: 0
[   0.0385 ] FwIndex: 3, MinRatchetLevel: 0
[   0.0385 ] FwIndex: 4, MinRatchetLevel: 0
[   0.0385 ] FwIndex: 5, MinRatchetLevel: 0
[   0.0385 ] FwIndex: 6, MinRatchetLevel: 0
[   0.0385 ] FwIndex: 7, MinRatchetLevel: 0
[   0.0385 ] FwIndex: 11, MinRatchetLevel: 0
[   0.0385 ] FwIndex: 12, MinRatchetLevel: 0
[   0.0385 ] FwIndex: 13, MinRatchetLevel: 0
[   0.0385 ] FwIndex: 14, MinRatchetLevel: 0
[   0.0385 ] FwIndex: 15, MinRatchetLevel: 0
[   0.0385 ] FwIndex: 16, MinRatchetLevel: 0
[   0.0386 ] FwIndex: 17, MinRatchetLevel: 0
[   0.0386 ] FwIndex: 18, MinRatchetLevel: 0
[   0.0386 ] FwIndex: 19, MinRatchetLevel: 0
[   0.0386 ] FwIndex: 30, MinRatchetLevel: 0
[   0.0386 ] FwIndex: 31, MinRatchetLevel: 0
[   0.0386 ]
[   0.0407 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[   0.0417 ] RCM 0 is saved as rcm_0.rcm
[   0.0438 ] RCM 1 is saved as rcm_1.rcm
[   0.0439 ] RCM 2 is saved as rcm_2.rcm
[   0.0439 ] List of rcm files are saved in rcm_list.xml
[   0.0439 ]
[   0.0439 ] Signing RCM messages
[   0.0470 ] tegrasign_v3.py --key None --list rcm_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[   0.0472 ] Assuming zero filled SBK key
[   0.0514 ] Warning: pub_key.key is not found
[   0.0508 ] Copying signature to RCM mesages
[   0.0532 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.0546 ] Boot Rom communication
[   0.0572 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[   0.0579 ] BR_CID: 0x88021911643171840800000010ff8180
[   0.1609 ] RCM version 0X190001
[   0.2650 ] Boot Rom communication completed
[   2.3114 ] tegrarcm_v2 --isapplet
[   2.3137 ] Applet version 01.00.0000
[   2.5763 ] Parsing fuse info as per xml file
[   2.5778 ] tegraparser_v2 --fuse_info fuse_qIz1QZ.xml blow_fuse_data.bin
[   2.5794 ] WARNING: default chip 0x19 for parsing fuse info
[   2.5795 ] MagicId=0x45535546 version=0x1
[   2.5796 ] node: name=PublicKeyHash size=32
[   2.5797 ]   value=0xe297bd68a275dc373dbec6f9cdbdabca9a690e3d32f3261bcb8aa6422a389adf
[   2.5797 ] node: name=Kek0 size=16
[   2.5798 ]   value=0x112233445566778899AABBCCDDEEFF00
[   2.5799 ] node: name=Kek1 size=16
[   2.5799 ]   value=0x123456789ABCDEF0FEDCBA9876543210
[   2.5800 ] node: name=SecureBootKey size=16
[   2.5800 ]   value=0x123456789ABCDEF0FEDCBA9876543210
[   2.5800 ]
[   2.5835 ] tegrarcm_v2 --oem burnfuses dummy
[   2.5852 ] Applet version 01.00.0000
[   2.8422 ] 0000000074741201: E> NV3P_SERVER: Fuse burn is not supported.
[   2.8805 ]
[   2.8806 ] Fuse burning failed
[   2.8806 ]
[   2.8807 ] trying fusing with CPU binary
[   2.8884 ] tegrasign_v3.py --key None --getmode mode.txt
[   2.8891 ] Assuming zero filled SBK key
[   2.8893 ] Parsing partition layout
[   2.8905 ] tegraparser_v2 --pt flash.xml.tmp
[   2.8920 ] Creating list of images to be signed
[   2.8930 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[   2.8938 ] MB1: Nvheader already present is mb1_t194_prod_aligned.bin
[   2.8977 ] Header already present for mb1_t194_prod_aligned_sigheader.bin
[   2.8982 ] MB1: Nvheader already present is mb1_t194_prod_aligned.bin
[   2.8987 ] Header already present for mb1_t194_prod_aligned_sigheader.bin
[   2.8992 ] adding BCH for spe_t194_aligned.bin
[   2.8995 ] adding BCH for nvtboot_t194_aligned.bin
[   2.9015 ] Header already present for preboot_c10_prod_cr_aligned.bin
[   2.9054 ] adding BCH for spe_t194_aligned.bin
[   2.9071 ] adding BCH for nvtboot_t194_aligned.bin
[   2.9073 ] Header already present for preboot_c10_prod_cr_aligned.bin
[   2.9178 ] Header already present for mce_c10_prod_cr_aligned.bin
[   2.9185 ] adding BCH for mts_c10_prod_cr_aligned.bin
[   2.9253 ] adding BCH for nvdisp-init_aligned.bin
[   2.9792 ] adding BCH for tegra194-p2888-0001-p2822-0000_aligned.dtb
[   3.0203 ] adding BCH for tos-optee_t194_aligned.img
[   3.0274 ] adding BCH for eks_t194_aligned.img
[   3.0404 ] adding BCH for bpmp-2_t194_aligned.bin
[   3.0421 ] adding BCH for tegra194-a02-bpmp-p2888-a04_aligned.dtb
[   3.0581 ] adding BCH for camera-rtcpu-t194-rce_aligned.img
[   3.0713 ] adding BCH for adsp-fw_aligned.bin
[   3.0793 ] Header already present for warmboot_t194_prod_aligned.bin
[   3.0841 ] Header already present for mce_c10_prod_cr_aligned.bin
[   3.0849 ] adding BCH for mts_c10_prod_cr_aligned.bin
[   3.0966 ] adding BCH for nvdisp-init_aligned.bin
[   3.1571 ] adding BCH for tegra194-p2888-0001-p2822-0000_aligned.dtb
[   3.2033 ] adding BCH for tos-optee_t194_aligned.img
[   3.2116 ] adding BCH for eks_t194_aligned.img
[   3.2263 ] adding BCH for bpmp-2_t194_aligned.bin
[   3.2289 ] adding BCH for tegra194-a02-bpmp-p2888-a04_aligned.dtb
[   3.2465 ] adding BCH for camera-rtcpu-t194-rce_aligned.img
[   3.2626 ] adding BCH for adsp-fw_aligned.bin
[   3.2720 ] Header already present for warmboot_t194_prod_aligned.bin
[   3.2783 ] Filling MB1 storage info
[   3.2784 ] Parsing dev params for multi chains
[   3.2785 ] Generating br-bct
[   3.2811 ] Performing cfg overlay
[   3.2811 ] ['tegra194-mb1-bct-memcfg-p2888.cfg', 'tegra194-memcfg-sw-override.cfg']
[   3.2813 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p2888.cfg -s tegra194-memcfg-sw-override.cfg -o /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6012/tmpfuvro8d41.cfg
[   3.3159 ] Updating dev and MSS params in BR BCT
[   3.3159 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6012/tmpfuvro8d41.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   3.3710 ] Updating bl info
[   3.3741 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[   3.3765 ] Generating signatures
[   3.3798 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key
[   3.3800 ] Assuming zero filled SBK key
[   3.4788 ] Warning: pub_key.key is not found
[   3.4782 ] Parsing dev params for multi chains
[   3.4782 ] Generating br-bct
[   3.4807 ] Performing cfg overlay
[   3.4807 ] ['/home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6012/tmpfuvro8d41.cfg']
[   3.4807 ] Updating dev and MSS params in BR BCT
[   3.4808 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6012/tmpfuvro8d41.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   3.5378 ] Updating bl info
[   3.5407 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   3.5437 ] Updating smd info
[   3.5460 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[   3.5471 ] Updating Odmdata
[   3.5495 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0x9190000
[   3.5505 ] Signing BCT
[   3.5506 ] Get Signed section of bct
[   3.5533 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[   3.5579 ] tegrasign_v3.py --key None --list bct_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[   3.5581 ] Assuming zero filled SBK key
[   3.5609 ] Warning: pub_key.key is not found
[   3.5603 ] Updating BCT with signature
[   3.5630 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[   3.5642 ] Generating coldboot mb1-bct
[   3.5667 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6012/tmpfuvro8d41.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[   3.5675 ] MB1-BCT version: 0x1
[   3.5679 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[   3.5682 ] Added Platform Config 0 data with size :- 3168
[   3.5691 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[   3.5692 ] Added Platform Config 1 data with size :- 19640
[   3.5768 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[   3.5771 ] Added Platform Config 2 data with size :- 24
[   3.5773 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[   3.5775 ] File read failed
[   3.5777 ] File read failed
[   3.5777 ] Added Platform Config 4 data with size :- 348
[   3.5777 ]
[   3.5777 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[   3.5777 ] Added Platform Config 3 data with size :- 92
[   3.5777 ]
[   3.5777 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[   3.5777 ] Added Platform Config 5 data with size :- 68
[   3.5777 ]
[   3.5777 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[   3.5777 ] Added Platform Config 7 data with size :- 392
[   3.5777 ]
[   3.5777 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[   3.5777 ] Added Platform Config 8 data with size :- 12
[   3.5777 ]
[   3.5777 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[   3.5777 ] Added Platform Config 9 data with size :- 32
[   3.5777 ]
[   3.5778 ] Updating mb1-bct with firmware information
[   3.5805 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   3.5820 ] Updating mb1-bct with storage information
[   3.5834 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[   3.5848 ] Updating mb1-bct with ratchet information
[   3.5874 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[   3.5890 ] FwIndex: 1, MinRatchetLevel: 0
[   3.5893 ] FwIndex: 2, MinRatchetLevel: 0
[   3.5895 ] FwIndex: 3, MinRatchetLevel: 0
[   3.5895 ] FwIndex: 4, MinRatchetLevel: 0
[   3.5895 ] FwIndex: 5, MinRatchetLevel: 0
[   3.5895 ] FwIndex: 6, MinRatchetLevel: 0
[   3.5895 ] FwIndex: 7, MinRatchetLevel: 0
[   3.5895 ] FwIndex: 11, MinRatchetLevel: 0
[   3.5895 ] FwIndex: 12, MinRatchetLevel: 0
[   3.5895 ] FwIndex: 13, MinRatchetLevel: 0
[   3.5895 ] FwIndex: 14, MinRatchetLevel: 0
[   3.5895 ] FwIndex: 15, MinRatchetLevel: 0
[   3.5896 ] FwIndex: 16, MinRatchetLevel: 0
[   3.5896 ] FwIndex: 17, MinRatchetLevel: 0
[   3.5896 ] FwIndex: 18, MinRatchetLevel: 0
[   3.5896 ] FwIndex: 19, MinRatchetLevel: 0
[   3.5896 ] FwIndex: 30, MinRatchetLevel: 0
[   3.5896 ] FwIndex: 31, MinRatchetLevel: 0
[   3.5896 ]
[   3.5920 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1_aligned.bct
[   3.5949 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   3.5956 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   3.5996 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   3.5998 ] Assuming zero filled SBK key
[   3.6012 ] Warning: pub_key.key is not found
[   3.6031 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   3.6054 ] Generating recovery mb1-bct
[   3.6067 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6012/tmpfuvro8d41.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[   3.6077 ] MB1-BCT version: 0x1
[   3.6087 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[   3.6117 ] Added Platform Config 0 data with size :- 3168
[   3.6135 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[   3.6136 ] Added Platform Config 1 data with size :- 19640
[   3.6185 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[   3.6187 ] Added Platform Config 2 data with size :- 24
[   3.6191 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[   3.6193 ] File read failed
[   3.6194 ] File read failed
[   3.6194 ] Added Platform Config 4 data with size :- 348
[   3.6196 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[   3.6198 ] Added Platform Config 3 data with size :- 92
[   3.6198 ]
[   3.6198 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[   3.6198 ] Added Platform Config 5 data with size :- 68
[   3.6198 ]
[   3.6198 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[   3.6198 ] Added Platform Config 7 data with size :- 392
[   3.6198 ]
[   3.6198 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[   3.6198 ] Added Platform Config 8 data with size :- 12
[   3.6198 ]
[   3.6198 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[   3.6198 ] Added Platform Config 9 data with size :- 32
[   3.6198 ]
[   3.6198 ] Updating mb1-bct with firmware information
[   3.6226 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[   3.6241 ] Updating mb1-bct with storage information
[   3.6265 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[   3.6277 ] Updating mb1-bct with ratchet information
[   3.6300 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[   3.6307 ] FwIndex: 1, MinRatchetLevel: 0
[   3.6311 ] FwIndex: 2, MinRatchetLevel: 0
[   3.6312 ] FwIndex: 3, MinRatchetLevel: 0
[   3.6313 ] FwIndex: 4, MinRatchetLevel: 0
[   3.6314 ] FwIndex: 5, MinRatchetLevel: 0
[   3.6314 ] FwIndex: 6, MinRatchetLevel: 0
[   3.6314 ] FwIndex: 7, MinRatchetLevel: 0
[   3.6314 ] FwIndex: 11, MinRatchetLevel: 0
[   3.6314 ] FwIndex: 12, MinRatchetLevel: 0
[   3.6314 ] FwIndex: 13, MinRatchetLevel: 0
[   3.6314 ] FwIndex: 14, MinRatchetLevel: 0
[   3.6314 ] FwIndex: 15, MinRatchetLevel: 0
[   3.6314 ] FwIndex: 16, MinRatchetLevel: 0
[   3.6314 ] FwIndex: 17, MinRatchetLevel: 0
[   3.6314 ] FwIndex: 18, MinRatchetLevel: 0
[   3.6314 ] FwIndex: 19, MinRatchetLevel: 0
[   3.6314 ] FwIndex: 30, MinRatchetLevel: 0
[   3.6314 ] FwIndex: 31, MinRatchetLevel: 0
[   3.6314 ]
[   3.6337 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1_aligned.bct
[   3.6369 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   3.6382 ] adding BCH for mb1_bct_MB1_aligned.bct
[   3.6414 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   3.6418 ] Assuming zero filled SBK key
[   3.6438 ] Warning: pub_key.key is not found
[   3.6457 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   3.6473 ] Generating coldboot mem-bct
[   3.6497 ] tegrabct_v2 --chip 0x19 0 --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6012/tmpfuvro8d41.cfg --membct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6012/tmpfuvro8d41_1.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6012/tmpfuvro8d41_2.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6012/tmpfuvro8d41_3.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6012/tmpfuvro8d41_4.bct
[   3.6511 ] Packing sdram param for instance[0]
[   3.7080 ] Packing sdram param for instance[1]
[   3.7081 ] Packing sdram param for instance[2]
[   3.7083 ] Packing sdram param for instance[3]
[   3.7083 ] Packing sdram param for instance[4]
[   3.7083 ] Packing sdram param for instance[5]
[   3.7083 ] Packing sdram param for instance[6]
[   3.7083 ] Packing sdram param for instance[7]
[   3.7083 ] Packing sdram param for instance[8]
[   3.7083 ] Packing sdram param for instance[9]
[   3.7083 ] Packing sdram param for instance[10]
[   3.7083 ] Packing sdram param for instance[11]
[   3.7083 ] Packing sdram param for instance[12]
[   3.7083 ] Packing sdram param for instance[13]
[   3.7083 ] Packing sdram param for instance[14]
[   3.7083 ] Packing sdram param for instance[15]
[   3.7083 ]
[   3.7083 ] Getting sector size from pt
[   3.7108 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[   3.7125 ] BlockSize read from layout is 200
[   3.7141 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6012/tmpfuvro8d41_1.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6012/tmpfuvro8d41_2.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6012/tmpfuvro8d41_3.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6012/tmpfuvro8d41_4.bct
[   3.7153 ] adding BCH for /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6012/tmpfuvro8d41_1.bct
[   3.7196 ] tegrahost_v2 --chip 0x19 --align mem_coldboot_aligned.bct
[   3.7228 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[   3.7235 ] Header already present for mem_coldboot_aligned.bct
[   3.7271 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   3.7273 ] Assuming zero filled SBK key
[   3.7294 ] Warning: pub_key.key is not found
[   3.7312 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[   3.7327 ] Generating recovery mem-bct
[   3.7348 ] tegrabct_v2 --chip 0x19 0 --sdram /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6012/tmpfuvro8d41.cfg --membct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6012/tmpfuvro8d41_1.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6012/tmpfuvro8d41_2.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6012/tmpfuvro8d41_3.bct /home/work/nvidia/35.4.1/Linux_for_Tegra/bootloader/6012/tmpfuvro8d41_4.bct
[   3.7355 ] Packing sdram param for instance[0]
[   3.7930 ] Packing sdram param for instance[1]
[   3.7931 ] Packing sdram param for instance[2]
[   3.7932 ] Packing sdram param for instance[3]
[   3.7933 ] Packing sdram param for instance[4]
[   3.7934 ] Packing sdram param for instance[5]
[   3.7935 ] Packing sdram param for instance[6]
[   3.7936 ] Packing sdram param for instance[7]
[   3.7937 ] Packing sdram param for instance[8]
[   3.7938 ] Packing sdram param for instance[9]
[   3.7938 ] Packing sdram param for instance[10]
[   3.7939 ] Packing sdram param for instance[11]
[   3.7939 ] Packing sdram param for instance[12]
[   3.7939 ] Packing sdram param for instance[13]
[   3.7939 ] Packing sdram param for instance[14]
[   3.7939 ] Packing sdram param for instance[15]
[   3.7939 ]
[   3.7940 ] Using default ramcode: 0
[   3.7968 ] tegrahost_v2 --chip 0x19 --align mem_rcm_aligned.bct
[   3.8002 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[   3.8010 ] adding BCH for mem_rcm_aligned.bct
[   3.8054 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   3.8057 ] Assuming zero filled SBK key
[   3.8079 ] Warning: pub_key.key is not found
[   3.8098 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[   3.8113 ] Copying signatures
[   3.8133 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[   4.0280 ] Sending BCTs
[   4.0308 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[   4.0321 ] Applet version 01.00.0000
[   4.2879 ] Sending bct_bootrom
[   4.2881 ] [................................................] 100%
[   4.3179 ] Sending bct_mb1
[   4.3389 ] [................................................] 100%
[   4.3703 ] Sending bct_mem
[   4.4324 ] [................................................] 100%
[   4.5240 ] Generating blob
[   4.5263 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_cpu_t194_aligned.bin
[   4.5304 ] tegrahost_v2 --chip 0x19 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvtboot_recovery_cpu_t194_aligned.bin zerosbk
[   4.5315 ] adding BCH for blob_nvtboot_recovery_cpu_t194_aligned.bin
[   4.5363 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_cpu_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   4.5365 ] Assuming zero filled SBK key
[   4.5381 ] Warning: pub_key.key is not found
[   4.5384 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_cpu_t194_aligned_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_t194_aligned_sigheader.bin.hash zerosbk
[   4.5446 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_t194_aligned.bin
[   4.5481 ] tegrahost_v2 --chip 0x19 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvtboot_recovery_t194_aligned.bin zerosbk
[   4.5490 ] adding BCH for blob_nvtboot_recovery_t194_aligned.bin
[   4.5553 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   4.5556 ] Assuming zero filled SBK key
[   4.5573 ] Warning: pub_key.key is not found
[   4.5581 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_t194_aligned_sigheader.bin.encrypt blob_nvtboot_recovery_t194_aligned_sigheader.bin.hash zerosbk
[   4.5646 ] tegrahost_v2 --chip 0x19 --align blob_preboot_c10_prod_cr_aligned.bin
[   4.5676 ] tegrahost_v2 --chip 0x19 0 --magicid MTSP --appendsigheader blob_preboot_c10_prod_cr_aligned.bin zerosbk
[   4.5684 ] Header already present for blob_preboot_c10_prod_cr_aligned.bin
[   4.5717 ] tegrasign_v3.py --key None --list blob_preboot_c10_prod_cr_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   4.5719 ] Assuming zero filled SBK key
[   4.5734 ] Warning: pub_key.key is not found
[   4.5752 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_preboot_c10_prod_cr_aligned_sigheader.bin.encrypt blob_preboot_c10_prod_cr_aligned_sigheader.bin.hash zerosbk
[   4.5801 ] tegrahost_v2 --chip 0x19 --align blob_mce_c10_prod_cr_aligned.bin
[   4.5830 ] tegrahost_v2 --chip 0x19 0 --magicid MTSM --appendsigheader blob_mce_c10_prod_cr_aligned.bin zerosbk
[   4.5838 ] Header already present for blob_mce_c10_prod_cr_aligned.bin
[   4.5882 ] tegrasign_v3.py --key None --list blob_mce_c10_prod_cr_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   4.5884 ] Assuming zero filled SBK key
[   4.5900 ] Warning: pub_key.key is not found
[   4.5905 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mce_c10_prod_cr_aligned_sigheader.bin.encrypt blob_mce_c10_prod_cr_aligned_sigheader.bin.hash zerosbk
[   4.5993 ] tegrahost_v2 --chip 0x19 --align blob_mts_c10_prod_cr_aligned.bin
[   4.6012 ] tegrahost_v2 --chip 0x19 0 --magicid MTSB --appendsigheader blob_mts_c10_prod_cr_aligned.bin zerosbk
[   4.6019 ] adding BCH for blob_mts_c10_prod_cr_aligned.bin
[   4.6608 ] tegrasign_v3.py --key None --list blob_mts_c10_prod_cr_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   4.6611 ] Assuming zero filled SBK key
[   4.6691 ] Warning: pub_key.key is not found
[   4.6707 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mts_c10_prod_cr_aligned_sigheader.bin.encrypt blob_mts_c10_prod_cr_aligned_sigheader.bin.hash zerosbk
[   4.7091 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-p2888-0001-p2822-0000_aligned.dtb
[   4.7126 ] tegrahost_v2 --chip 0x19 0 --magicid CDTB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-p2888-0001-p2822-0000_aligned.dtb zerosbk
[   4.7136 ] adding BCH for blob_tegra194-p2888-0001-p2822-0000_aligned.dtb
[   4.7233 ] tegrasign_v3.py --key None --list blob_tegra194-p2888-0001-p2822-0000_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   4.7235 ] Assuming zero filled SBK key
[   4.7258 ] Warning: pub_key.key is not found
[   4.7265 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-p2888-0001-p2822-0000_aligned_sigheader.dtb.encrypt blob_tegra194-p2888-0001-p2822-0000_aligned_sigheader.dtb.hash zerosbk
[   4.7348 ] tegrahost_v2 --chip 0x19 --align blob_tos-optee_t194_aligned.img
[   4.7381 ] tegrahost_v2 --chip 0x19 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tos-optee_t194_aligned.img zerosbk
[   4.7389 ] adding BCH for blob_tos-optee_t194_aligned.img
[   4.7578 ] tegrasign_v3.py --key None --list blob_tos-optee_t194_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key
[   4.7580 ] Assuming zero filled SBK key
[   4.7614 ] Warning: pub_key.key is not found
[   4.7621 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tos-optee_t194_aligned_sigheader.img.encrypt blob_tos-optee_t194_aligned_sigheader.img.hash zerosbk
[   4.7751 ] tegrahost_v2 --chip 0x19 --align blob_bpmp-2_t194_aligned.bin
[   4.7795 ] tegrahost_v2 --chip 0x19 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader blob_bpmp-2_t194_aligned.bin zerosbk
[   4.7808 ] adding BCH for blob_bpmp-2_t194_aligned.bin
[   4.8004 ] tegrasign_v3.py --key None --list blob_bpmp-2_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   4.8006 ] Assuming zero filled SBK key
[   4.8037 ] Warning: pub_key.key is not found
[   4.8055 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_bpmp-2_t194_aligned_sigheader.bin.encrypt blob_bpmp-2_t194_aligned_sigheader.bin.hash zerosbk
[   4.8187 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-a02-bpmp-p2888-a04_aligned.dtb
[   4.8205 ] tegrahost_v2 --chip 0x19 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-a02-bpmp-p2888-a04_aligned.dtb zerosbk
[   4.8215 ] adding BCH for blob_tegra194-a02-bpmp-p2888-a04_aligned.dtb
[   4.8413 ] tegrasign_v3.py --key None --list blob_tegra194-a02-bpmp-p2888-a04_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   4.8416 ] Assuming zero filled SBK key
[   4.8450 ] Warning: pub_key.key is not found
[   4.8471 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-a02-bpmp-p2888-a04_aligned_sigheader.dtb.encrypt blob_tegra194-a02-bpmp-p2888-a04_aligned_sigheader.dtb.hash zerosbk
[   4.8611 ] tegrahost_v2 --chip 0x19 --align blob_eks_t194_aligned.img
[   4.8646 ] tegrahost_v2 --chip 0x19 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_eks_t194_aligned.img zerosbk
[   4.8655 ] adding BCH for blob_eks_t194_aligned.img
[   4.8677 ] tegrasign_v3.py --key None --list blob_eks_t194_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key
[   4.8679 ] Assuming zero filled SBK key
[   4.8693 ] Warning: pub_key.key is not found
[   4.8705 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_eks_t194_aligned_sigheader.img.encrypt blob_eks_t194_aligned_sigheader.img.hash zerosbk
[   5.1073 ] Disable RCE in rcm kernel-dtb.
[   5.1562 ] tegrahost_v2 --chip 0x19 --align blob_spe_t194_aligned.bin
[   5.1584 ] tegrahost_v2 --chip 0x19 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_spe_t194_aligned.bin zerosbk
[   5.1596 ] adding BCH for blob_spe_t194_aligned.bin
[   5.1629 ] tegrasign_v3.py --key None --list blob_spe_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   5.1631 ] Assuming zero filled SBK key
[   5.1648 ] Warning: pub_key.key is not found
[   5.1692 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_spe_t194_aligned_sigheader.bin.encrypt blob_spe_t194_aligned_sigheader.bin.hash zerosbk
[   5.1737 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[   5.1753 ] number of images in blob are 13
[   5.1756 ] blobsize is 7909545
[   5.1757 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 232976
[   5.1783 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 206016
[   5.1786 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 24016
[   5.1788 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 145184
[   5.1791 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3430416
[   5.1807 ] Added binary blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt of size 397984
[   5.1818 ] Added binary blob_tos-optee_t194_sigheader.img.encrypt of size 977664
[   5.1819 ] Added binary blob_bpmp-2_t194_sigheader.bin.encrypt of size 1007392
[   5.1826 ] Added binary blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt of size 993408
[   5.1828 ] Added binary blob_eks_t194_sigheader.img.encrypt of size 5136
[   5.1830 ] Added binary blob_boot.img of size 21
[   5.1831 ] Added binary blob_tegra194-p2888-0001-p2822-0000.dtb of size 393884
[   5.1833 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 95232
[   5.1876 ] Sending bootloader and pre-requisite binaries
[   5.1908 ] tegrarcm_v2 --download blob blob.bin
[   5.1923 ] Applet version 01.00.0000
[   5.4479 ] Sending blob
[   5.4480 ] [................................................] 100%
[   7.2350 ] tegrarcm_v2 --boot recovery
[   7.2364 ] Applet version 01.00.0000
[   8.5180 ] tegrarcm_v2 --isapplet
[   9.5754 ] tegrarcm_v2 --ismb2
[   9.8376 ] tegradevflash_v2 --iscpubl
[   9.8391 ] Bootloader version 01.00.0000
[   9.9934 ] Bootloader version 01.00.0000
[  10.0451 ] tegradevflash_v2 --oem burnfuses dummy
[  10.0487 ] Bootloader version 01.00.0000
[  10.1995 ] Fusing burning successful
[  10.2626 ] tegradevflash_v2 --reboot recovery
[  10.2647 ] Bootloader version 01.00.0000
[work:~/nvidia/35.4.1/Linux_for_Tegra]$
The xml file is as follows:
$ cat uefi_keys/rsa_3k.xml
<genericfuse MagicId="0x45535546" version="1.0.0">
    <fuse name="PublicKeyHash" size="32" value="0xe297bd68a275dc373dbec6f9cdbdabca9a690e3d32f3261bcb8aa6422a389adf"/>
    <fuse name="Kek0" size="16" value="0x112233445566778899AABBCCDDEEFF00"/>
    <fuse name="Kek1" size="16" value="0x123456789ABCDEF0FEDCBA9876543210"/>
    <fuse name="SecureBootKey" size="16" value="0x123456789ABCDEF0FEDCBA9876543210"/>
</genericfuse>
Please ask the burn fuse report
[ 2.8422 ] 0000000074741201: E> NV3P_SERVER: Fuse burn is not supported. What is the reason and how can I burn fuses properly?
hello Youke,
Xavier series does not support rsa-3k. The rsa-3k is only for Orin series and newer.
Hi Jerry,
I looked at the secure boot documentation for 35.4.1. Xavier supports RSA-3k. Please confirm again. The link and notes are as follows.
Jetson AGX Xavier series and Jetson Xavier NX series targets support both RSA-2K and RSA-3K key.
https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/SD/Security/SecureBoot.html#example-xavier-fuse-configuration-file-to-program-the-rsa-2k-key
Hi Jerry,
I just generated rsa 2k, retested and burned it into Xavier, and reported the same issue.
hi Jerry,
When I just burned the rsa 2k, I found the following log. Does the information read indicate that the rsa 3k was successfully burned before? I have previously performed rsa 3k key burning without the – test parameter, and also reported that Fuse burn is not supported. I thought the execution failed at that time.
Have I successfully burned the RSA 3K key?How can I determine if I have successfully burned it?
hello Youke,
let me revise my previous comments. Xavier series do supports both RSA-2K and RSA-3K.
you may check the fuse value on the target directly, i.e. # cat /sys/devices/platform/tegra-fuse/public_key
hi Jerry,
I used the command you provided but couldn’t find the fuse data. I think I failed to write the fuse. May I ask the reason for the error in the log I sent earlier and why did I fail to write it?
thanks
hello Youke,
we need to dig into this… E> NV3P_SERVER: Fuse burn is not supported.
could you please setup serial console to gather the complete logs for fuse burning AGX Xavier.
Hi Jerry,
The serial console logs are as follows, please refer to
[0081.304] W> RATCHET: MB1 binary ratchet value 4 is larger than ratchet level 2 from HW fuses.
[0081.312] I> MB1 (prd-version: 2.6.0.0-t194-41334769-cab45716)
[0081.318] I> Boot-mode: Platform RCM
[0081.321] I> Platform: Silicon
[0081.324] I> Chip revision : A02P
[0081.327] I> Bootrom patch version : 15 (correctly patched)
[0081.332] I> ATE fuse revision : 0x200
[0081.336] I> Ram repair fuse : 0x0
[0081.339] I> Ram Code : 0x2
[0081.341] I> rst_source: 0x0, rst_level: 0x0
[0081.346] I> USB configuration success
[0084.153] I> mb2 image downloaded
[0084.451] I> Recovery boot mode 0
[0084.465] I> UPHY full init done
[0084.472] I> MB1 done
[0084.477] I> Welcome to MB2(TBoot-BPMP) Applet (version: default.t194-mobile-d394e178)
[0084.485] I> DMA Heap @ [0x40020000 - 0x40065800]
[0084.489] I> Default Heap @ [0xd486400 - 0xd48a400]
[0084.494] W> Profiler not initialized
[0085.144] I> sdmmc DDR50 mode
[0085.149] E> SPI_FLASH: Invalid value device id: 7.
[0085.153] I> QSPI Flash is not present.
[0085.160] E> CLK_RST: instance 6 not found in module 44.
[0085.165] E> MPhy CAR configuration failed error = 1747992077
[0085.170] E> UFS initialization failed
[0085.174] I> UFS is not present
[0085.181] I> Found 20 partitions in SDMMC_BOOT (instance 3)
[0085.190] I> Found 44 partitions in SDMMC_USER (instance 3)
[0085.195] W> Profiler not initialized
[0085.199] I> Entering 3p server
[0085.202] I> USB configuration success
[0086.570] I> Populate chip info
[0086.932] I> Populate eeprom info
[0086.949] I> Populate eeprom info for module cvm
[0086.954]  > DEVICE_PROD: device prod is not initialized.
[0087.601] I> Rebooting : reboot-recovery
[0087.614] I> Reset to recovery mode
[0002.642] W> RATCHET: MB1 binary ratchet value 4 is larger than ratchet level 2 from HW fuses.
[0002.650] I> MB1 (prd-version: 2.6.0.0-t194-41334769-cab45716)
[0002.656] I> Boot-mode: RCM
[0002.658] I> Platform: Silicon
[0002.661] I> Chip revision : A02P
[0002.664] I> Bootrom patch version : 15 (correctly patched)
[0002.669] I> ATE fuse revision : 0x200
[0002.673] I> Ram repair fuse : 0x0
[0002.676] I> Ram Code : 0x2
[0002.679] I> rst_source: 0xb, rst_level: 0x1
[0002.684] I> USB configuration success
[0006.694] I> bct_bootrom image downloaded
[0006.750] W> PROD_CONFIG: device prod data is empty in MB1 BCT.
[0006.757] I> Temperature = 28000
[0006.760] W> Skipping boost for clk: BPMP_CPU_NIC
[0006.764] W> Skipping boost for clk: BPMP_APB
[0006.768] W> Skipping boost for clk: AXI_CBB
[0006.772] W> Skipping boost for clk: AON_CPU_NIC
[0006.776] W> Skipping boost for clk: CAN1
[0006.780] W> Skipping boost for clk: CAN2
[0006.784] I> Boot-device: SDMMC (instance: 3)
[0006.789] I> bct_mb1 image downloaded
[0006.851] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0006.859] W>  Thermal config not found in BCT
[0006.867] W>  MEMIO rail config not found in BCT
[0006.883] I> bct_mem image downloaded
[0009.689] I> blob image downloaded
[0009.988] I> Recovery boot mode 0
[0010.039] W>  Platform config not found in BCT
[0010.087] I> MB1 done
▒▒▒▒main enter
SPE VERSION #: R01.00.18 Created: Jan 29 2021 @ 14:18:27
HW Function test
Start Scheduler.
in late init
  [0010.097] I> Welcome to MB2(TBoot-BPMP) Recovery (version: default.t194-mobile-1bd7b950)
[0010.098] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0010.098] I> Default Heap @ [0xd486400 - 0xd48a400]
[0010.100] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0010.106] W> device prod register failed
[0010.121] I> Relocating BR-BCT
[0010.122]  > DEVICE_PROD: device prod is not initialized.
[0010.147] E> I2C: slave not found in slaves.
[0010.148] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0010.149] E> I2C_DEV: Failed to send register address 0x00000000.
[0010.150] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0010.151] E> eeprom: Failed to read I2C slave device
[0010.154] I> Failed to read CVB eeprom data @ AE
[0010.159] I> Retrying CVB eeprom read @ AC ...
[0010.195] I> Relocating OP-TEE dtb from: 0x6bfffc10 to 0x70050000, size: 1008
[0010.196] I> [0] START: 0x80000000, SIZE: 0x47af0000
[0010.197] I> [1] START: 0xca000000, SIZE: 0x800000
[0010.197] I> dram_block larger than 80000000
[0010.197] I> [2] START: 0x100000000, SIZE: 0x780000000
[0010.202] I> Setting NS memory ranges to OP-TEE dtb finished.
[0010.206] I> decompressor handler not found
[0010.461] I> EKB detected (length: 0x410) @ VA:0x526fa200
[0010.462] I> Setting EKB blob info to OPTEE dtb finished.
▒▒NOTICE:  BL31: v2.6(release):346877e39
NOTICE:  BL31: Built : 12:32:40, Aug  1 2023
I/TC: Physical secure memory base 0xcb040000 size 0xf00000
  bpmp: init
bpmp: tag is 128431eec76692047e1ac1ebc0392266
sku_dt_init: not sku 0x00
clk_early initialized
mail_early initialized
fuse initialized
hwwdt initialized
t194_ec_get_ec_list: found 45 ecs
ec initialized
vmon_setup_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
mc initialized
reset initialized
nvhs initialized
uphy_early initialized
emc_early initialized
392 clocks registered
clk initialized
io_dpd initialized
thermal initialized
thermal_mrq initialized
i2c initialized
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
vrmon initialized
regulator initialized
▒▒I/TC:
▒▒avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
suspend initialized
pg_late initialized
pg_mrq_init initialized
strap initialized
nvl initialized
emc initialized
emc_mrq initialized
clk_dt initialized
tj_init initialized
/uphy is not enabled status = disabled
uphy_dt initialized
uphy_mrq initialized
uphy initialized
ec_swd_poll_start: 281 reg polling start w period 47 ms
ec_late initialized
hwwdt_late initialized
reset_mrq initialized
ec_mrq initialized
fmon_mrq initialized
clk_mrq initialized
avfs_mrq initialized
mail_mrq initialized
i2c_mrq initialized
tag_mrq initialized
console_mrq initialized
mrq initialized
clk_sync_fmon_post initialized
▒▒I/TC: Non-secure external DT found
▒▒clk_dt_late initialized
noc_late initialized
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
avfs_clk_mach_post initialized
avfs_clk_platform_post initialized
cvc_late initialized
regulator_post initialized
rm initialized
console_late initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
profile initialized
fuse_late initialized
extras_post initialized
bpmp: init complete
entering main console loop
] ▒▒I/TC: OP-TEE version: 3.21 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Aug  1 19:39:56 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Primary CPU switching to normal world boot
  [0011.302] I> Welcome to TBoot-CPU Recovery
[0011.302] I> Heap: [0xa0f00000 ... 0xa9f00000
[0011.302] I> gpio framework initialized
[0011.323] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0011.333] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0011.333] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0011.343] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0011.353] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0011.354] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0011.354] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0011.364] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0011.375] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0011.375] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0011.384] I> fixed regulator driver initialized
[0011.559] I> CPU: Nvidia Carmel
[0011.560] I> CPU: MIDR: 0x4e0f0040, MPIDR: 0x80000000
[0011.560] I> Platform: Silicon
[0011.560] I> chip revision : A02P
[0011.561] I> Boot_device: SDMMC_BOOT instance: 3
[0011.561] I> sdmmc-3 params source = boot args
[0012.003] I> sdmmc-3 params source = boot args
[0012.003] I> sdmmc bdev is already initialized
[0012.030] I> Found 20 partitions in SDMMC_BOOT (instance 3)
[0012.043] I> Found 44 partitions in SDMMC_USER (instance 3)
[0012.043] I> Recovery boot_type: 0
[0012.044] I> Entering 3p server
[0012.044] I> USB configuration success
[0012.754] I> Reading fuses
[0012.773] I> Read fuse successfully
[0012.972] I> Reading fuses
[0012.991] I> Read fuse successfully
[0013.195] I> Reading fuses
[0013.214] I> Read fuse successfully
[0013.410] I> Reading fuses
[0013.429] I> Read fuse successfully
[0013.632] I> Reading fuses
[0013.652] I> Read fuse successfully
[0013.853] I> Reading fuses
[0013.871] I> Read fuse successfully
[0014.072] I> Reading fuses
[0014.092] I> Read fuse successfully
[0014.291] I> Reading fuses
[0014.310] I> Read fuse successfully
[0014.503] I> Reading fuses
[0014.522] I> Read fuse successfully
[0014.725] I> Reading fuses
[0014.744] I> Read fuse successfully
[0014.953] I> Reading fuses
[0014.972] I> Read fuse successfully
[0015.170] I> Reading fuses
[0015.189] I> Read fuse successfully
[0015.384] I> Reading fuses
[0015.403] I> Read fuse successfully
[0015.595] I> Reading fuses
[0015.615] I> Read fuse successfully
[0015.811] I> Reading fuses
[0015.829] I> Read fuse successfully
[0016.024] I> Reading fuses
[0016.044] I> Read fuse successfully
[0016.240] I> Reading fuses
[0016.260] I> Read fuse successfully
[0016.460] I> Reading fuses
[0016.479] I> Read fuse successfully
[0016.680] I> Reading fuses
[0016.697] I> Read fuse successfully
[0016.899] I> Reading fuses
[0016.917] I> Read fuse successfully
[0017.106] I> Reading fuses
[0017.125] I> Read fuse successfully
[0017.322] I> Reading fuses
[0017.341] I> Read fuse successfully
[0017.545] I> Reading fuses
[0017.564] I> Read fuse successfully
[0017.761] I> Reading fuses
[0017.781] I> Read fuse successfully
[0017.977] I> Reading fuses
[0017.996] I> Read fuse successfully
[0018.454] I> Rebooting : reboot-recovery
[0018.464] I> Reset to recovery mode
▒▒▒▒Shutdown state requested 1
Rebooting system ...
[0002.690] W> RATCHET: MB1 binary ratchet value 4 is larger than ratchet level 2 from HW fuses.
[0002.698] I> MB1 (prd-version: 2.6.0.0-t194-41334769-cab45716)
[0002.703] I> Boot-mode: RCM
[0002.706] I> Platform: Silicon
[0002.709] I> Chip revision : A02P
[0002.712] I> Bootrom patch version : 15 (correctly patched)
[0002.717] I> ATE fuse revision : 0x200
[0002.720] I> Ram repair fuse : 0x0
[0002.723] I> Ram Code : 0x2
[0002.726] I> rst_source: 0xb, rst_level: 0x1
[0002.731] I> USB configuration success
[0005.240] I> Handling oem command 6
[0005.244] E> NV3P_SERVER: Fuse burn is not supported.
[0006.711] I> bct_bootrom image downloaded
[0006.768] W> PROD_CONFIG: device prod data is empty in MB1 BCT.
[0006.773] I> Temperature = 31500
[0006.776] W> Skipping boost for clk: BPMP_CPU_NIC
[0006.781] W> Skipping boost for clk: BPMP_APB
[0006.785] W> Skipping boost for clk: AXI_CBB
[0006.789] W> Skipping boost for clk: AON_CPU_NIC
[0006.793] W> Skipping boost for clk: CAN1
[0006.797] W> Skipping boost for clk: CAN2
[0006.801] I> Boot-device: SDMMC (instance: 3)
[0006.805] I> bct_mb1 image downloaded
[0006.864] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0006.872] W>  Thermal config not found in BCT
[0006.880] W>  MEMIO rail config not found in BCT
[0006.897] I> bct_mem image downloaded
[0009.606] I> blob image downloaded
[0009.895] I> Recovery boot mode 0
[0009.947] W>  Platform config not found in BCT
[0009.995] I> MB1 done
▒▒▒▒main enter
HW Function test
Start Scheduler.
in late init
  [0010.005] I> Welcome to MB2(TBoot-BPMP) Recovery (version: default.t194-mobile-1bd7b950)
[0010.005] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0010.006] I> Default Heap @ [0xd486400 - 0xd48a400]
[0010.008] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0010.013] W> device prod register failed
[0010.028] I> Relocating BR-BCT
[0010.030]  > DEVICE_PROD: device prod is not initialized.
[0010.056] E> I2C: slave not found in slaves.
[0010.057] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0010.058] E> I2C_DEV: Failed to send register address 0x00000000.
[0010.059] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0010.060] E> eeprom: Failed to read I2C slave device
[0010.063] I> Failed to read CVB eeprom data @ AE
[0010.067] I> Retrying CVB eeprom read @ AC ...
[0010.103] I> Relocating OP-TEE dtb from: 0x6bfffc10 to 0x70050000, size: 1008
[0010.104] I> [0] START: 0x80000000, SIZE: 0x47af0000
[0010.105] I> [1] START: 0xca000000, SIZE: 0x800000
[0010.105] I> dram_block larger than 80000000
[0010.106] I> [2] START: 0x100000000, SIZE: 0x780000000
[0010.110] I> Setting NS memory ranges to OP-TEE dtb finished.
[0010.114] I> decompressor handler not found
[0010.364] I> EKB detected (length: 0x410) @ VA:0x526fa200
[0010.366] I> Setting EKB blob info to OPTEE dtb finished.
  bpmp: init
fuse initialized
hwwdt initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
mc initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
vrmon initialized
▒▒I/TC:
aotag initialized
dvs initialized
pm initialized
suspend initialized
pg_late initialized
strap initialized
nvl initialized
emc initialized
emc_mrq initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy initialized
ec_late initialized
ec_mrq initialized
clk_mrq initialized
i2c_mrq initialized
tag_mrq initialized
mrq initialized
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
rm initialized
mc_reg initialized
pg_post initialized
profile initialized
bpmp: init complete
  [0011.207] I> Welcome to TBoot-CPU Recovery
[0011.208] I> Heap: [0xa0f00000 ... 0xa9f00000
[0011.208] I> gpio framework initialized
[0011.225] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0011.233] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0011.234] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0011.242] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0011.251] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0011.252] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0011.252] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0011.261] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0011.269] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0011.270] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0011.279] I> fixed regulator driver initialized
[0011.429] I> CPU: Nvidia Carmel
[0011.430] I> CPU: MIDR: 0x4e0f0040, MPIDR: 0x80000000
[0011.430] I> Platform: Silicon
[0011.430] I> chip revision : A02P
[0011.430] I> Boot_device: SDMMC_BOOT instance: 3
[0011.431] I> sdmmc-3 params source = boot args
[0011.875] I> sdmmc-3 params source = boot args
[0011.875] I> sdmmc bdev is already initialized
[0011.902] I> Found 20 partitions in SDMMC_BOOT (instance 3)
[0011.915] I> Found 44 partitions in SDMMC_USER (instance 3)
[0011.915] I> Recovery boot_type: 0
[0011.915] I> Entering 3p server
[0011.915] I> USB configuration success
[0012.607] I> Generic fusing path
[0012.616] I> Dummy test successful
[0012.810] I> Rebooting : reboot-recovery
[0012.820] I> Reset to recovery mode
hello Youke,
it looks odmfuse keeps going on to MB2, and the fuse burning is a success.
for example,
this message, E> NV3P_SERVER: Fuse burn is not supported has reported in the
middle of the UART logs
due to Xavier doesn’t support fuse by using FSKP. that’s an expected failure when trying to burn the fuses via MB1.
so…
is the odmfuse.sh has stop running and returning you an error?
BTW,
here’s an explanation for those two messages.
as you can see, it’s calling tegrasign_v3.py, for example, tegrasign_v3.py --key None .. --pubkeyhash pub_key.key
because it’s command with a None key, --key none and, pub_key.key were passed in as zero by default.
hence,
you may ignore these two messages.
