Software Version
DRIVE OS 6.0.8.1
Target Operating System
Linux
Hardware Platform
SDK Manager Version
1.9.3.10904
Host Machine Version
Hi, I usually reboot Orin through debug interface by using two “poweroff” and “poweron” commands. This ways is quite easy mostly from remote.
Unfortunately, lately when I follow this procedure most of the time it doesn’t power on successfully.
This is the output when it power on successfully:
ERROR: MCU_PLTFPWRMGR: WDT reset (or aurixreset force) triggered...
MCU_FOH: E2E Initialized
MCU_FOH: Initialization done
INFO: MCU_PLTFPWRMGR: Powering up
INFO: MCU_PLTFPWRMGR: Voltage Monitoring is enabled.
INFO: MCU_PLTFPWRMGR: Send command 'voltageMonitor disable' on console to disable Voltage Monitoring.
INFO: MCU_PLTFPWRMGR: Monitoring for KL30 (G3CH4) started.
INFO: MCU_PLTFPWRMGR: KL30 (G3CH4) Voltage (17937mV) exceeded threshold (6700mV). Continuing...!
INFO: PLTFPWRMGR_IOHWABS: Monitoring for PREREG_5V (G2CH2) started.
INFO: PLTFPWRMGR_IOHWABS: PREREG_5V (G2CH2) Voltage (4944mV) exceeded threshold (4850mV). Continuing...
INFO: MCU_PLTFPWRMGR: Monitoring for PREREG_SENSE_16V (G3CH6) started.
INFO: MCU_PLTFPWRMGR: PREREG_SENSE_16V (G3CH6) Voltage (12151mV) exceeded threshold (6700mV). Continuing...!
INFO: MCU_PLTFPWRMGR: Request Power-up Ethernet Switch done !
INFO: MCU_PltfPwrMgr: Linkup status is not active
INFO: MCU_PltfPwrMgr: 88Q5072 OAK Link Active
INFO:Marvell switch: 0: NW_CFG_BASE
INFO:Marvell switch: Marvell Oak/Spruce configuration completed..
INFO: MCU_PltfPwrMgr: Switch Init
INFO: Marvell Phy: Phy init begin..
INFO: Marvell Phy: Phy init completed..
INFO: MCU_PltfPwrMgr: PHYs Init
INFO: MCU_PltfPwrMgr: StbM Init
INFO: MCU_PLTFPWRMGR: Request Eth initialization done !
Check for VRS10............................................................
Check for VRS11-1..........................................................
Check for VRS11-2...........................................................
INFO: NVMCU_ORINPWRCTRL: FUNC_NIRQ continuous monitoring Enabled!
INFO: SftyMon_IoHwAbs: toggle check of local and remote sensor successfull
INFO: NvMCU_OrinTMON: toggle check of local and remote sensor successfull
INFO: SftyMon_IoHwAbs: Board Temperature sensor initialized
INFO: NvMCU_OrinTMON: Orin Temperature sensor initialized
INFO: MCU_PLTFPWRMGR: Orin TMON enabled ....
INFO: MCU_PLTFPWRMGR: Board TMON enabled.
INFO: BtChn_Cfg: Tegra x1 Boot Chain is : A
INFO: BtChn_Cfg: Bootchain Pin 0xc set to 0
INFO: BtChn_Cfg: Bootchain Pin 0x150 set to 0
INFO: NVMCU_ORINPWRCTRL: Tegra reset released
MCU_FOH: MCU FOH : Initiate SOC Error Pin Monitoring & SPI communication
MCU_FOH: MCU FOH : Start Monitoring Initiated
INFO: MCU_PLTFPWRMGR: Power-up sequence is complete !
INFO: CmnIf: Wdg Enabled Success!
INFO: MCU_PLTFPWRMGR: DL Ready drive to HIGH!
Power on the system
INFO : MCU_ISTMGR: IST_DONE pin no monitor time of 2000 ms over.
MCU_FOH: Spi Transmit Started
MCU_FOH: SOC error pin is de-asserted
ERROR: MCU_ERRHANDLER: SOC error pin is de-asserted
MCU_FOH: Periodic Status [0] 0xab [1] 0xcd [250] 0x12 [251] 0x34
INFO: SftyMon_IoHwAbs: PG_VRS11 monitoring started...
INFO : MCU_ISTMGR: IST Manager initialized to send/receive commands
INFO : IST_TESTAPP: IST Result Ready to fetch
MCU_FOH: SOC error pin is asserted
ERROR: MCU_ERRHANDLER: SOC error pin is asserted
MCU_FOH: ErrReport: ErrorCode-0x28da ReporterId-0xe04c Error_Attribute-0x0 Timestamp-0x146cebf5
INFO: MCU_SWC_FanControl: max_rpm fan2 : 0
INFO: MCU_SWC_FanControl: maxrpm of fan2 has more than 50 percent deviation against rated maxrpm
This is the output when it fails:
Info: Executing cmd: poweroff, argc: 0, args:
NvShell>INFO: MCU_PLTFPWRMGR: Powering off
INFO: MCU_PLTFPWRMGR: VRS11 PG Monitoring disable.
INFO: NVMCU_ORINPWRCTRL: Wait for Safe Shutdown notification (20s max)
MCU_FOH: SPI : E2E_P05Check Status : 7 : 112
ERROR: MCU_ERRHANDLER: McuFoh : ReporterID - 0x810E ErrorCode - 0x3
MCU_FOH: SPI : E2E_P05Check Status : 7 : 0
INFO: MCU_PltfPwrMgr: Ethernet peripherals de-initialized
INFO: MCU_PLTFPWRMGR: DL Ready drive to LOW !
INFO: MCU_PLTFPWRMGR: Orin TMON disable.
INFO: MCU_PLTFPWRMGR: Board TMON disable.
INFO: PLTFPWRMGR_IOHWABS: Power down sequence is complete !
Command Executed
poweron
Info: Executing cmd: poweron, argc: 0, args:
NvShell>INFO: MCU_PLTFPWRMGR: Powering up
INFO: MCU_PLTFPWRMGR: KL30 (G3CH4) Voltage (17925mV) exceeded threshold (6700mV). Continuing...!
INFO: MCU_PLTFPWRMGR: PREREG_SENSE_16V (G3CH6) Voltage (12146mV) exceeded threshold (6700mV). Continuing...!
Power on the system
Command Executed
ERROR: SftyMon_IoHwAbs: VRS11 PGOOD Failure notification...!
ERROR: MCU_ERRHANDLER: SftyMon : ReporterID - 0x8110 ErrorCode - 0x1A
ERROR: MCU_ERRHANDLER: PGOOD failure notification...error detected by VRS11
Do you have any idea of how to solve this? Other ways to reboot Orin are appreciated too. Thank you.
