Failure to boot with stock kernel when build from source
I am having trouble with our Jetson Orin NX 16GB booting after installing the kernel when built from source.
Here are the steps I am taking to build and install the kernel and flash the board:
Steps to build kernel and flash Jetson Orin NX 16GB
#Setup L4T Folder and exports
cd /home/${USER}/JetsonFlashing
sudo tar --same-owner -xvf Jetson_Linux_R36.2.0_aarch64.tbz2
sudo tar --same-owner -xvf Tegra_Linux_Sample-Root-Filesystem_R36.2.0_aarch64.tbz2 --directory Linux_for_Tegra/rootfs/
export TOOLCHAIN_PATH=/home/${USER}/Documents/JetsonFlashing/aarch64--glibc--stable-2022.08-1
export L4T_DIR=/home/${USER}/JetsonFlashing/Linux_for_Tegra
sudo ./apply_binaries.sh
cd ${L4T_DIR}/source
#Without this block in the middle, the board will flash and boot fine (after patching usb-gadget driver on r36.2 release)
#Build Kernel, modules, graphics driver, and dtbs
./source_sync.sh -k -t rel-36_eng_2024-02-05
./generic_rt_build.sh "enable"
export CROSS_COMPILE=${TOOLCHAIN_PATH}/bin/aarch64-buildroot-linux-gnu-
make -C kernel
export INSTALL_MOD_PATH=${L4T_DIR}/rootfs/
sudo -E make install -C kernel
sudo cp -f kernel/kernel-jammy-src/arch/arm64/boot/Image ${L4T_DIR}/kernel/Image
export IGNORE_PREEMPT_RT_PRESENCE=1
export KERNEL_HEADERS=$PWD/kernel/kernel-jammy-src
make modules
sudo -E make modules_install
make dtbs
sudo cp -f nvidia-oot/device-tree/platform/generic-dts/dtbs/* ${L4T_DIR}/kernel/dtb/
sudo FAB=000 BOARDID=3767 BOARDSKU=0000 BOARDREV= FUSELEVEL=1 CHIPREV=  ./build_l4t_bup.sh --single-image-bup A_xusb-fw p3768-0000-p3767-0000-a0 mmcblk0p1
sudo ./l4t_generate_soc_bup.sh -b p3768-0000-p3767-0000-a0 t23x
sudo systemctl stop udisks2.service
sudo service nfs-kernel-server start
sudo ADDITIONAL_DTB_OVERLAY_OPT="BootOrderNvme.dtbo" ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/generic/cfg/flash_t234_qspi.xml” --showlogs --network usb0 p3768-0000-p3767-0000-a0-nvme external
sudo service nfs-kernel-server stop
sudo systemctl start udisks2.service
I have attached the boot log from serial console as well as the flash log.
flash_3-6_0_20240210-171406.log (51.5 KB)
bootlog.txt (196.1 KB)
I’m not sure what we’re doing wrong. Our intent is to build the RT kernel, however, it fails to boot with or without patching RT
This line is a typo:
It is supposed to read:
sudo ./l4t_generate_soc_bup.sh -b jetson-orin-nano-devkit t23x
Sorry for the late response.
Sorry that I missed this.
Please follow this post to update the initrd for RT kernel, or the driver for NVMe will fail to load because the version of the driver does not match with the kernel image:
I followed this and unpacked initrd, replaced the drivers in nvme and usb. Then repacked, copied to rootfs/boot and then flashed with initrd flash. I am receiving the same error. Do I need to replace the entire NVME and USB folders in initrd? I only replaced the .ko files that were present in the initrd when I unpacked it.
Please let me know if there is something else I should do
You need to make sure the folder is named 5.15.122-rt-tegra.
It won’t work a folder named 5.15.122-tegra even if the files are updated.
If you don’t know what I’m talking about, or you just cannot get it done, please wait for JetPack 6 GA, which comes with an official solution to this issue.
Hi Dave,
Yes, I changed the folder name to include rt and made sure the strings matched in the rootfs/var/modules/… folder. I followed your instructions step by step word for word but still no success.
Thank you,
Rob
Actually you can simply direct copy & paste the entire /lib/modules/5.15.122-rt-tegra from rootfs into initrd, and delete the old one named 5.15.122-tegra.
It is supposed to work this way.
