Error when flashing Orin NX using l4t_initrd_flash
I am working over the Orin NX module + Orin Nano carrier board. I flashed the Jetpack 6 succesfully using the sdkmanager. Now I am trying to flash my own kernel and dts using l4t_initrd_flash script, but it fails.
The command that I use is:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/generic/cfg/flash_t234_qspi.xml” --showlogs --network usb0 jetson-orin-nano-devkit internal > flash_logs.log
Below you can find the last logs showed before flash failure:
Waiting for target to boot-up…
Waiting for device to expose ssh …RTNETLINK answers: File exists
Waiting for device to expose ssh …Run command: flash on fc00:1:1:0::2
SSH ready
blockdev: cannot open /dev/mmcblk3boot0: No such file or directory
[ 0]: l4t_flash_from_kernel: Starting to create gpt for emmc
Active index file is /mnt/internal/flash.idx
Number of lines is 79
max_index=78
writing item=62, 6:0:primary_gpt, 512, 19968, gpt_primary_6_0.bin, 16896, fixed--0, 1b6086b41ef3bf9e54dc6a3b5756680e610fdbfa
Error: Could not stat device /dev/mmcblk3 - No such file or directory.
Flash failure
Cleaning up…
Using Jetpack 5.1.2 I did not have this problem, the module was flashed correctly.
Any idea of what the problem might be o which way to go?
Thanks in advance.
Did you also remember to install kernel modules after compiling the new kernel?
Anyway, please dump the serial console log during flashing as indicated in:
Yes, I build and deployed the kernel modules.
Attached you can find the serial port logs during flashing:
serial-port-logs.txt (118.1 KB)
[2024-01-22_14:17:29:301]modprobe: ERROR: could not insert ‘tegra_mce’: Exec format error
[2024-01-22_14:17:29:320]9968] spi_tegra210_quad: disagrees about version of symbol module_layout
I don’t believe you are doing it right.
Please also check this post:
It’s a clean kernel build. For this, I used following steps:
Prepare the workspace:
  • Download BSP using sdkmanager
  • Flash Orin NX first time using the sdkmanager in order to test that it works great.
  • sudo apt-get install git-core
  • Run ./source_sync.sh -k -t jetson_36.2 located in /home/user/nvidia/nvidia_sdk/Jetpack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/source
  • Move to source folder
  • Install gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu.tar.xz
  • Set environment settings (CROSS_COMPILE, PATH, ARCH, LOCALVERSION)
Make a clean kernel build:
  • make clean
  • make defconfig
  • make -j4 Image
  • make -j4 modules
  • sudo -E make INSTALL_MOD_PATH=~/nvidia/nvidia_sdk/Jetpack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/rootfs/ modules_install
  • cp kernel/kernel-jammy-src/arch/arm64/boot/Image …/kernel/
  • cp kernel/kernel-jammy-src/arch/arm64/boot/dts/* …/kernel/dtb/
Flash board:
  • Boot the NX to recovery mode.
  • Move to ~/nvidia/nvidia_sdk/Jetpack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra
  • Flash using: sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/generic/cfg/flash_t234_qspi.xml” --showlogs --network usb0 jetson-orin-nano-devkit internal
I will move my own compiled modules to initrd image as you suggest.
Thanks for your support!
We are moving to GCC 11.3 on JetPack 6.
https://developer.nvidia.com/downloads/embedded/l4t/r36_release_v2.0/toolchain/aarch64--glibc--stable-2022.08-1.tar.bz2
7.3 is quite old and it may cause some ABI compatibility issues on building newer kernel versions.
Thanks Dave!
I recompile again using GCC 11.3 and I updated the initrd as following:
Re-pack the initrd image:
  • sudo cp Linux_for_Tegra/rootfs/boot/initrd ~/jp6/initrdImg/
  • mkdir ~/jp6/initrdImg/unziped
  • cd ~/jp6/initrdImg/unziped
  • sudo gunzip -c /home/user/jp6/initrdImg/initrd | cpio -i
Copy modules from Linux_for_Tegra/rootfs/lib/modules:
  • cd unziped/lib/modules
  • cp -r /home/user/nvidia/nvidia_sdk/Jetpack_6.0_DP_Linux_DP_ORIN_NX_TARGETS/Linux_for_Tegra/rootfs/lib/modules/5.15.122-tegra .
  • find . | cpio -H newc -o | gzip -9 -n > …/initrd
Copy initrd back to folder:
  • cd …
  • sudo cp initrd /home/user/nvidia/nvidia_sdk/Jetpack_6.0_DP_Linux_DP_ORIN_NX_TARGETS/Linux_for_Tegra/rootfs/boot/initrd
Flash board:
  • Boot NX to recovery mode
  • cd /home/user/nvidia/nvidia_sdk/Jetpack_6.0_DP_Linux_DP_ORIN_NX_TARGETS/Linux_for_Tegra
  • sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/generic/cfg/flash_t234_qspi.xml” --showlogs --network usb0 jetson-orin-nano-devkit internal
But it fails again. Last dmesg logs are:
Waiting for target to boot-up...
Timeout
Cleaning up...
And serial port debug logs from Orin NX board:
serial-port-debug-02.txt (101.6 KB)
OK, so now you are not getting error loading those drivers/modules.
That’s good.
Do you have any USB 2.0 devices connected to the board while flashing? Anything like a mouse or a keyboard. There’s currently a bug in 36.2 that USB devices are not enumerated correctly, which affects the flashing cable.
No, I don’t have any device connected to the board, only the flashing cable.
Then please make sure there is one.
Also, are you sure it’s the complete serial console log?
I don’t think it will timeout after only 3 seconds into the kernel.
It doesn’t work either with a USB2.0 keyboard connected.
Yes, it is the complete serial console log. Attached you can find the last one using a keyboard connected to one USB port.
serial-port-03.txt (102.5 KB)
I will review everything anyway.
Thanks!!
You can also consider this if it keeps failing:
https://docs.nvidia.com/jetson/archives/r36.2/DeveloperGuide/SD/FlashingSupport.html#manually-setting-up-a-flash-drive-for-booting
Orin NX is based on NVMe storage and now I don’t have any adapter to connect it directly to the host. I will get one to test.
Anyway, I suppose that it will be solved in the next Jetpack version. Is the next version scheduled?
It’s scheduled to be released in March.
Thank you so much Dave!
