I get fail when I use orin nx 16G module and orin nano dev-kit carrier board to flash DP6.0.
I patch echo on > /sys/bus/usb/devices/usb2/power/control to
Linux_for_Tegra/tools/kernel_flash/initrd_flash/nv_enable_remote.sh by referencing
But still can’t flash succefully.
I test with all my USB ports, and also use an usb2.0 hub, but still get failed.
The flashing process ended successfully, but the MB2 bootloader failed to start up after reboot, which is weird.
Try this to re-flash the QSPI bootloader and see if it helps:
I have reflash Orin NX 16G and 8G with Jetpack 5.1.3 by SDK manager to verify these two modules.
Both modules can be flashed, and login succefully.
Then I also flash 8G with JetPack DP6.0 by SDK manager, it can be flashed, and login succefully.
But I still get fail when I use 16G module for JetPack DP6.0.
I’m having trouble installing Jetpack 6.0 DP on a custom carrier board based on the Jetson Orin Carrier board. I’m also using the orin nx 16GB module.
I can get up to Jetpack 5.1.2 with no problem. What should I be looking at?
My colleague uses his environment to do the test, but still gets fail.
He has tested
1.Use sdk manager to flash DP6.0 which is with “echo on > /sys/bus/usb/devices/usb2/power/control” patch.
2.Use “sudo ./flash.sh --no-systemimg -c bootloader/generic/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit internal” to flash 16G module.
3.Use “sudo ./tools/kernel_flash/l4t_initrd_flash.sh -p “–no-systemimg -c bootloader/generic/cfg/flash_t234_qspi.xml” --network usb0 jetson-orin-nano-devkit internal” to flash 16G module
Test environment
1.Host : ASUS TUF Z370-PRO GAMING monther board/Ubuntu 20.04.1 LTS x86_64
2.SDK manager : 2.0.0.11405 x86_64
Can you also try JetPack 5.1.2?
Maybe your case is related to a PCN of Orin NX that is not included in either JetPack 6 DP and JetPack 5.1.2, but only in 5.1.3.
