Failed to flash JetPack 6.0 DP
I’m having issues installing Jetpack 6.0DP on a custom carrier board based on the Jetson Orin Carrier board.
Attach the logs from sdkmanager. What could be the cause?
SDKM_logs_JetPack_6.0_DP_Linux_for_Jetson_Orin_NX_modules_2024-04-22_11-39-47.log.zip (294.1 KB)
Please dump the serial console log at the same time.
Also, can this module be flashed when put on a DevKit?
I applied the contents of the following link and succeeded, thank you.
