Flash jetson-orin-nx with jetpack 6
We have been trying to install “Jetpack 6” on our Jetson Orin NX 8GB, but we have had several problems using the sdkmanager.
The first test that was done was on an Ubuntu 22.04 installing the sdkmanager and jumps an error at 75% related to the RPC indicating that it is already in use. Attached are the logs.
SDKM_logs_JetPack_6.1_Linux_for_Jetson_Orin_NX_8GB_2024-11-13_10-27-24_rpc_issue.zip (262.8 KB)
To avoid the above error, the rdp-bind service has been disabled, if it is running before starting the flash process. In this case, the flash process stays at 99% and is not able to boot, we think it may be because of the initramfs, “Device failed to boot to the initrd flash kernel. Please retrieve the serial log during flashing to debug further”. I attach the logs.
SDKM_logs_JetPack_6.1_Linux_for_Jetson_Orin_NX_8GB_2024-11-13_11-20-24_initramfs.zip (445.8 KB)
Hi david.pacios,
Are you using the devkit or custom board for Orin NX?
10:49:47.071 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: Waiting for target to boot-up...
10:49:48.073 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: Timeout
10:49:48.073 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: Device failed to boot to the initrd flash kernel. Please retrive the serial log during flashing to debug further.
From the log you shared, please check the serial console log at this moment.
11:41:17.236 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: Waiting for target to boot-up...
11:41:18.238 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: Timeout
11:41:18.238 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: Device failed to boot to the initrd flash kernel. Please retrive the serial log during flashing to debug further.
11:41:18.240 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NX_TARGETS: Cleaning up...
The same for the second log.
Please help to provide the full serial console log to check the boot failed issue.
The Jetson was purchased through Advantech. The model is: Mic-713_Orin NX 8GB_2 ,with the following product number: MIC-713_OX3A1. This model does not have serial console log or I have not been able to connect to it.
SDK manager may not work with your custom carrier board.
Please request the custom BSP package from your vendor and also check the method to capture serial console log.
