Haoyu
August 3, 2017, 2:46pm
1
I tried the provided faster rcnn VGG16 example and it’s working well.
My own ZF caffemodel and definition file works in caffe. But failed when using them in TensorRT.
The definition file is modified according to the provided vgg16 prototxt file. All the parameters at beginning of example code are same except the input_H, input_W, pooled_H, pooled_W and I fixed them to my own.
So
Could you provide your ZF definition prototxt file? I see there is a ZF caffemodel in the provided downloaded model package.
Did anyone success modifying your own faster rcnn definition prototxt file in TensorRT2?
Thank you.
Have you changed ZF network?I have the same problem
Meet the same problem. VGG16 works fine.
ZF crash in
Thread 1 “my_fasterRCNN_d” received signal SIGSEGV, Segmentation fault.
0x00007fffebd995f7 in CaffeWeightFactory::getBlobProtoData(ditcaffe::BlobProto const&, ditcaffe::Type, std::vector<void*, std::allocator<void*> >&) ()
from /usr/local/nvidia/tensorrt/targets/x86_64-linux-gnu/lib/libnvparsers.so.4.0.2
Here is the prototxt file I used:
input: "data"
input_shape {
dim: 2
dim: 3
dim: 375
dim: 500
input: "im_info"
input_shape {
dim: 2
dim: 1
dim: 1
dim: 3
#========= conv1-conv5 ============
layer {
type: "Convolution"
bottom: "data"
top: "conv1"
convolution_param {
num_output: 96
kernel_size: 7
pad: 3
stride: 2
layer {
type: "ReLU"
bottom: "conv1"
top: "conv1"
layer {
type: "LRN"
bottom: "conv1"
top: "norm1"
lrn_param {
local_size: 3
alpha: 0.00005
beta: 0.75
norm_region: WITHIN_CHANNEL
engine: CAFFE
layer {
type: "Pooling"
bottom: "norm1"
top: "pool1"
pooling_param {
kernel_size: 3
stride: 2
pad: 1
pool: MAX
layer {
type: "Convolution"
bottom: "pool1"
top: "conv2"
convolution_param {
num_output: 256
kernel_size: 5
pad: 2
stride: 2
layer {
type: "ReLU"
bottom: "conv2"
top: "conv2"
layer {
type: "LRN"
bottom: "conv2"
top: "norm2"
lrn_param {
local_size: 3
alpha: 0.00005
beta: 0.75
engine: CAFFE
layer {
type: "Pooling"
bottom: "norm2"
top: "pool2"
pooling_param {
kernel_size: 3
stride: 2
pad: 1
pool: MAX
layer {
type: "Convolution"
bottom: "pool2"
top: "conv3"
convolution_param {
num_output: 384
kernel_size: 3
pad: 1
stride: 1
layer {
type: "ReLU"
bottom: "conv3"
top: "conv3"
layer {
type: "Convolution"
bottom: "conv3"
top: "conv4"
convolution_param {
num_output: 384
kernel_size: 3
pad: 1
stride: 1
layer {
type: "ReLU"
bottom: "conv4"
top: "conv4"
layer {
type: "Convolution"
bottom: "conv4"
top: "conv5"
convolution_param {
num_output: 256
kernel_size: 3
pad: 1
stride: 1
layer {
type: "ReLU"
bottom: "conv5"
top: "conv5"
#========= RPN ============
layer {
type: "Convolution"
bottom: "conv5"
top: "rpn/output"
convolution_param {
num_output: 256
kernel_size: 3 pad: 1 stride: 1
layer {
type: "ReLU"
bottom: "rpn/output"
top: "rpn/output"
layer {
type: "Convolution"
top: "rpn_cls_score"
convolution_param {
num_output: 18 # 2(bg/fg) * 9(anchors)
kernel_size: 1 pad: 0 stride: 1
layer {
type: "Convolution"
top: "rpn_bbox_pred"
convolution_param {
num_output: 36 # 4 * 9(anchors)
layer {
bottom: "rpn_cls_score"
top: "rpn_cls_score_reshape"
type: "IPlugin"
#========= RoI Proposal ============
layer {
type: "Softmax"
bottom: "rpn_cls_score_reshape"
top: "rpn_cls_prob"
layer {
type: 'IPlugin'
bottom: 'rpn_cls_prob'
top: 'rpn_cls_prob_reshape'
layer {
type: 'IPlugin'
bottom: 'rpn_cls_prob_reshape'
bottom: 'rpn_bbox_pred'
bottom: 'conv5'
bottom: 'im_info'
top: 'rois'
top: 'roi_pool_conv5'
layer {
type: "InnerProduct"
bottom: "roi_pool_conv5"
top: "fc6"
inner_product_param {
num_output: 4096
layer {
type: "ReLU"
bottom: "fc6"
top: "fc6"
layer {
bottom: "fc6"
top: "fc7"
num_output: 4096
layer {
type: "ReLU"
bottom: "fc7"
top: "fc7"
layer {
bottom: "fc7"
top: "cls_score"
num_output: 21
layer {
bottom: "fc7"
top: "bbox_pred"
num_output: 84
layer {
type: "Softmax"
bottom: "cls_score"
top: "cls_prob"
Have anyone got the results?
Did the Faster-rcnn worked in tensorRT, jetson-tx2 with 30 FPS?
