I am trying a deploy a custom caffemodel in Jeston Xavier . The model is trained with pascal_voc, ZF.
The repo which i used is as follow https://github.com/rbgirshick/py-faster-rcnn
However, it seems like I cannot deploy this model via Deepstream.
The following is my prototxt, ( this is train.prototxt)
layer {
type: 'Python'
top: 'data'
top: 'im_info'
top: 'gt_boxes'
python_param {
module: 'roi_data_layer.layer'
layer: 'RoIDataLayer'
param_str: "'num_classes': 3" ############
#========= conv1-conv5 ============
layer {
type: "Convolution"
bottom: "data"
top: "conv1"
param { lr_mult: 1.0 }
param { lr_mult: 2.0 }
convolution_param {
num_output: 96
kernel_size: 7
pad: 3
stride: 2
layer {
type: "ReLU"
bottom: "conv1"
top: "conv1"
layer {
type: "LRN"
bottom: "conv1"
top: "norm1"
lrn_param {
local_size: 3
alpha: 0.00005
beta: 0.75
norm_region: WITHIN_CHANNEL
engine: CAFFE
layer {
type: "Pooling"
bottom: "norm1"
top: "pool1"
pooling_param {
kernel_size: 3
stride: 2
pad: 1
pool: MAX
layer {
type: "Convolution"
bottom: "pool1"
top: "conv2"
convolution_param {
num_output: 256
kernel_size: 5
pad: 2
stride: 2
layer {
type: "ReLU"
bottom: "conv2"
top: "conv2"
layer {
type: "LRN"
bottom: "conv2"
top: "norm2"
lrn_param {
local_size: 3
alpha: 0.00005
beta: 0.75
engine: CAFFE
layer {
type: "Pooling"
bottom: "norm2"
top: "pool2"
pooling_param {
kernel_size: 3
stride: 2
pad: 1
pool: MAX
layer {
type: "Convolution"
bottom: "pool2"
top: "conv3"
convolution_param {
num_output: 384
kernel_size: 3
pad: 1
stride: 1
layer {
type: "ReLU"
bottom: "conv3"
top: "conv3"
layer {
type: "Convolution"
bottom: "conv3"
top: "conv4"
convolution_param {
num_output: 384
kernel_size: 3
pad: 1
stride: 1
layer {
type: "ReLU"
bottom: "conv4"
top: "conv4"
layer {
type: "Convolution"
bottom: "conv4"
top: "conv5"
convolution_param {
num_output: 256
kernel_size: 3
pad: 1
stride: 1
layer {
type: "ReLU"
bottom: "conv5"
top: "conv5"
#========= RPN ============
layer {
type: "Convolution"
bottom: "conv5"
top: "rpn/output"
convolution_param {
num_output: 256
kernel_size: 3 pad: 1 stride: 1
weight_filler { type: "gaussian" std: 0.01 }
bias_filler { type: "constant" value: 0 }
layer {
type: "ReLU"
bottom: "rpn/output"
top: "rpn/output"
#layer {
# name: "rpn_conv/3x3"
# type: "Convolution"
# bottom: "conv5"
# top: "rpn_conv/3x3"
# param { lr_mult: 1.0 }
# param { lr_mult: 2.0 }
# convolution_param {
# num_output: 192
# kernel_size: 3 pad: 1 stride: 1
# weight_filler { type: "gaussian" std: 0.01 }
# bias_filler { type: "constant" value: 0 }
#layer {
# name: "rpn_conv/5x5"
# bottom: "conv5"
# top: "rpn_conv/5x5"
# num_output: 64
# kernel_size: 5 pad: 2 stride: 1
# weight_filler { type: "gaussian" std: 0.0036 }
#layer {
# name: "rpn/output"
# type: "Concat"
# bottom: "rpn_conv/3x3"
# bottom: "rpn_conv/5x5"
# top: "rpn/output"
#layer {
# name: "rpn_relu/output"
# type: "ReLU"
# bottom: "rpn/output"
# top: "rpn/output"
layer {
type: "Convolution"
top: "rpn_cls_score"
convolution_param {
num_output: 18 # 2(bg/fg) * 9(anchors)
kernel_size: 1 pad: 0 stride: 1
layer {
type: "Convolution"
top: "rpn_bbox_pred"
convolution_param {
num_output: 36 # 4 * 9(anchors)
layer {
bottom: "rpn_cls_score"
top: "rpn_cls_score_reshape"
type: "Reshape"
reshape_param { shape { dim: 0 dim: 2 dim: -1 dim: 0 } }
layer {
type: 'Python'
bottom: 'rpn_cls_score'
bottom: 'gt_boxes'
bottom: 'im_info'
bottom: 'data'
top: 'rpn_labels'
top: 'rpn_bbox_targets'
top: 'rpn_bbox_inside_weights'
top: 'rpn_bbox_outside_weights'
python_param {
module: 'rpn.anchor_target_layer'
layer: 'AnchorTargetLayer'
param_str: "'feat_stride': 16"
layer {
type: "SoftmaxWithLoss"
bottom: "rpn_cls_score_reshape"
bottom: "rpn_labels"
propagate_down: 1
propagate_down: 0
top: "rpn_cls_loss"
loss_weight: 1
loss_param {
ignore_label: -1
normalize: true
layer {
type: "SmoothL1Loss"
bottom: "rpn_bbox_pred"
bottom: "rpn_bbox_targets"
bottom: 'rpn_bbox_inside_weights'
bottom: 'rpn_bbox_outside_weights'
top: "rpn_loss_bbox"
loss_weight: 1
smooth_l1_loss_param { sigma: 3.0 }
#========= RoI Proposal ============
layer {
type: "Softmax"
top: "rpn_cls_prob"
layer {
type: 'Reshape'
bottom: 'rpn_cls_prob'
top: 'rpn_cls_prob_reshape'
reshape_param { shape { dim: 0 dim: 18 dim: -1 dim: 0 } }
layer {
type: 'Python'
bottom: 'rpn_cls_prob_reshape'
bottom: 'rpn_bbox_pred'
bottom: 'im_info'
top: 'rpn_rois'
# top: 'rpn_scores'
python_param {
module: 'rpn.proposal_layer'
layer: 'ProposalLayer'
#layer {
# name: 'debug-data'
# type: 'Python'
# bottom: 'data'
# bottom: 'rpn_rois'
# bottom: 'rpn_scores'
# python_param {
# module: 'rpn.debug_layer'
# layer: 'RPNDebugLayer'
layer {
type: 'Python'
bottom: 'rpn_rois'
bottom: 'gt_boxes'
top: 'rois'
top: 'labels'
top: 'bbox_targets'
top: 'bbox_inside_weights'
top: 'bbox_outside_weights'
python_param {
module: 'rpn.proposal_target_layer'
layer: 'ProposalTargetLayer'
#========= RCNN ============
layer {
type: "ROIPooling"
bottom: "conv5"
bottom: "rois"
top: "roi_pool_conv5"
roi_pooling_param {
pooled_w: 6
pooled_h: 6
spatial_scale: 0.0625 # 1/16
layer {
type: "InnerProduct"
bottom: "roi_pool_conv5"
top: "fc6"
inner_product_param {
num_output: 4096
layer {
type: "ReLU"
bottom: "fc6"
top: "fc6"
layer {
type: "Dropout"
bottom: "fc6"
top: "fc6"
dropout_param {
dropout_ratio: 0.5
scale_train: false
layer {
bottom: "fc6"
top: "fc7"
num_output: 4096
layer {
type: "ReLU"
bottom: "fc7"
top: "fc7"
layer {
type: "Dropout"
bottom: "fc7"
top: "fc7"
dropout_param {
dropout_ratio: 0.5
scale_train: false
layer {
bottom: "fc7"
top: "cls_score"
num_output: 3 ###########
weight_filler {
type: "gaussian"
std: 0.01
bias_filler {
type: "constant"
value: 0
layer {
bottom: "fc7"
top: "bbox_pred"
num_output: 12 ####num_class * 4
weight_filler {
type: "gaussian"
std: 0.001
bias_filler {
type: "constant"
value: 0
layer {
bottom: "cls_score"
bottom: "labels"
propagate_down: 1
propagate_down: 0
top: "cls_loss"
loss_weight: 1
loss_param {
ignore_label: -1
normalize: true
layer {
bottom: "bbox_pred"
bottom: "bbox_targets"
bottom: 'bbox_inside_weights'
bottom: 'bbox_outside_weights'
top: "bbox_loss"
loss_weight: 1
Do I need to edit this prototxt? If so, is there any guide to edit it.
Thanks in advance.
