Which Fan Part number is used in the Jetson Orin AGX 64GB SoM ?
Unfortunately, the provided context does not explicitly mention the fan part number used in the Jetson Orin AGX 64GB SoM. However, I can provide some information that might be helpful.
According to the context, the Jetson Orin NX Series and Jetson Orin Nano Series Product Design Guide mentions that the Orin module provides PWM and Tachometer functionality for controlling a fan as part of the thermal solution. The guide also provides information on the PWM and Tachometer pins and functions, but it does not specify the fan part number.
However, the context does mention an “AGX Orin fan datasheet” in the list of documents, which might contain information about the fan part number used in the Jetson Orin AGX 64GB SoM. Unfortunately, the contents of this datasheet are not provided in the context.
In contrast, the context does provide information about the Jetson Orin NX and Jetson Orin Nano modules, including their pin descriptions and thermal design guides. However, this information is not directly applicable to the Jetson Orin AGX 64GB SoM.
Therefore, based on the provided context, I cannot determine the fan part number used in the Jetson Orin AGX 64GB SoM. If you need this information, I recommend checking the AGX Orin fan datasheet or other relevant documentation that might be available.
Jetson AGX Orin module does not have a FAN. FAN is on the carrier board. You can check / read part number from the carrier board / dev kit.
