POWER INPUT RANGE OF AGX ORIN DEVICE KIT 64GB
Hi, what’s the power input range of the device kit? We provide the power to AGX using our board. What’s the lowest input voltage which can make AGX power off if the input voltage not steady enough.
The power input range for the Jetson Orin NX Series and Jetson Orin Nano Series modules is nominally 5.0V to 20V, as stated in the Jetson Orin NX Series and Jetson Orin Nano Series Product Design Guide (Chapter 6. Power). However, for the Jetson AGX Orin Series, the power input range is not explicitly mentioned in the provided context.
But, we can infer that the power input range for the Jetson AGX Orin Series might be similar to the Jetson Orin NX Series and Jetson Orin Nano Series, as the power management features of these devices are very similar, and most of the document applies equally to both.
Regarding the lowest input voltage that can make the AGX power off if the input voltage is not steady enough, it is not explicitly mentioned in the provided context. However, we can consider the minimum voltage required for the MAXN_SUPER at 40W for Jetson Orin NX, which is 8.0V to the VDD_IN.
It is also important to note that the Jetson Orin module is not hot-pluggable, and before installing or removing the module, the main power supply (to VDD_IN pins) must be disconnected and adequate time allowed for the various power rails to fully discharge.
In summary, while the exact power input range for the Jetson AGX Orin Series is not provided, it is likely to be similar to the Jetson Orin NX Series and Jetson Orin Nano Series. The minimum voltage required for stable operation is not explicitly mentioned, but it is recommended to ensure a stable power supply within the nominal range of 5.0V to 20V to avoid any potential issues.
