Power consumption for Jetson AGX Orin 64Gb non-industrial
What is the sleep mode power consumption for Jetson AGX orin 64 GB, non-industrial.
The provided context does not explicitly mention the sleep mode power consumption for the Jetson AGX Orin 64GB non-industrial module. However, it does provide information on the power management features and thermal management of the Jetson AGX Orin series.
According to the context, the Jetson AGX Orin series has various power-saving features, including kernel space power-saving features, clock and voltage management, CPU power management, and memory power management. Additionally, the context mentions that the Jetson AGX Orin series has different modes, including Deep Sleep (LP0) and Suspend (LP1), which can help reduce power consumption.
While the context does not provide specific information on the sleep mode power consumption for the Jetson AGX Orin 64GB non-industrial module, it does mention that the Jetson AGX Orin series has a low power state in Deep Sleep (LP0) and Suspend (LP1). However, the exact power consumption values are not provided.
In comparison, the context does provide information on the SATA (Optional) section, which mentions that the Jetson AGX Orin series should verify that any implemented SATA interfaces transition to the lowest power state in Deep Sleep (LP0) and Suspend (LP1). However, this information is specific to the SATA interface and not directly related to the sleep mode power consumption of the Jetson AGX Orin 64GB non-industrial module.
To provide a comprehensive answer, it would be necessary to refer to the technical specifications table mentioned in the context, which is not provided. Therefore, the exact sleep mode power consumption for the Jetson AGX Orin 64GB non-industrial module cannot be determined based on the provided context.
In summary, while the context provides information on the power management features and thermal management of the Jetson AGX Orin series, it does not explicitly mention the sleep mode power consumption for the Jetson AGX Orin 64GB non-industrial module. To determine the exact power consumption values, it would be necessary to refer to the technical specifications table or other external resources.
There is no official number documented for sleep mode power consumption. However, it has been measured by someone to be ~1W here:
