Fedora: deprecated ML repo, but no new cuDNN in Fedora 39 repo
Hi all.
I note from this post that the Nvidia machine learning repository is now deprecated in favour of distributing, for example, libcudnn in the main CUDA RPM repository.
However, I also note that libcudnn et al are NOT available in the fedora 39 repository, whereas I note, for example, that they are available in the Ubuntu 22.04 repository.
Are there plans to eventually bring the Fedora repositories back up-to-date, or is one now expected to use the RHEL repositories to keep up-to-date when using Fedora?
Many thanks.
Hi @jamesturner246 ,
I am checking on this with the team and shall get back to you.
thanks
Great. Thank you.
Any word on this?
I need cudnn for F39.
Bump.
need cudnn for fedora 39 too, still no solution?
An update would be fantastic. Is the expectation that we use the RHEL 9 repo from now onwards? Thanks.
Hi All,
I am afraid, We currently don’t support Fedora, so RHEL is the alternative you’ll have to use.
That’s a little disappointing, but thanks for clarifying.
Best,
James.
