See here:
How can I make my flames to burn higher, all the way?
See here:
This is a case of running out of Flow blocks to allocate. Either increase the densityCellSize, or increase the maximum blocks. Increasing maximum blocks will increase VRAM usage. Max blocks is found in Render Settings->Common->Flow. The default maximum blocks is 4096 currently.
Thanks!!! This was the solution.
