Based on the provided context, I’ll help you troubleshoot the issue and provide the correct commands to prepare a flashable image and flash it to your Jetson Orin Nano board.
Preparing the system image:
The command you used to prepare the system image is almost correct. However, you need to specify the --external-device option to indicate that you’re using an NVMe drive. Here’s the corrected command:
sudo BOARDID=3767 FAB=300 BOARDSKU=0003 BOARDREV=P1 tools/kernel_flash/l4t_initrd_flash.sh --no-flash --external-device nvme0n1p1 jetson-orin-nano-devkit internal
This command will prepare the system image for flashing to the NVMe drive.
Flashing the image:
To flash the prepared image, you can use the following command:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --external-device nvme0n1p1 jetson-orin-nano-devkit internal
This command will flash the prepared image to the NVMe drive.
Verifying the pre-image creation:
To verify if the pre-image is created, you can check the output of the --no-flash command. If the command completes successfully, it will create a boot.img file in the bootloader directory. You can also check the bootloader directory for the presence of the boot.img file.
Additionally, you can use the ls command to check if the boot.img file is present in the bootloader directory:
ls bootloader/boot.img
If the file is present, it indicates that the pre-image creation was successful.
Troubleshooting tips:
- Make sure that the NVMe drive is properly connected to the Jetson Orin Nano board.
- Verify that the
nvme0n1p1 device is present in the system by running the lsblk command.
- Check the output of the
--no-flash command for any errors or warnings.
- If you’re still facing issues, try using the
--showlogs option with the --flash-only command to get more detailed logs.
I hope this helps you resolve the issue and successfully flash the BSP to your Jetson Orin Nano board.
