Hi Team
I have used below commands to flash Orin NX 8GB. It is working fine with Orin NX. But once come to Orin Nano.
It is failing with below error. Entire logs is attached.
Please can you suggest us , What could be went wrong?
Error: Return value 3
Reading board information failed.
Error: failed to generate images
…Command used :
sudo ./apply_binaries.sh
sudo ./tools/l4t_flash_prerequisites.sh
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c
tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml” --showlogs
–network usb0 jetson-orin-nano-devkit internal
nano4GBfail_logs (26.3 KB)
