Orin Nano 4GB Production Module on dev kit Flash issues
I have a brand new 4GB orin nano module which I am trying to get operating on the Orin Nano Dev kit It gets stuck on waiting to boot during flashing, I have attached the output from the flashing terminal and the serial log.
uart_ouptut4GBDev_kit.log (82.1 KB)
4GBOutput.log (285.8 KB)
Please refer to Jetson Orin Nano Developer kit bootup issue to see if able to help.
Hi Kayccc,
I successfully got it to flash using the sdkmanager (I couldnt get it to setup the sdk properly over the USB connection but at least I got it flashed).
Why didn’t the quickstart flash instructions work? I am working on a carrier board so figuring out how to use it without relying on the SDK manager is important.
$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 \
  -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" \
  --showlogs --network usb0 jetson-orin-nano-devkit internal
the above was copy and pasted from the quick start guide and resulted in a failed flash.
Teva
Please apply this for a try:
Jetson AGX Orin FAQ
