The Jetson Orin Nano flashed system could not go into the configuration desktop
I’m using the Orin Nano 8G development kit to extend the 128G NVME SSD, and following the steps in the development guide, Use $sudo./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1-c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/generic/cfg/flash_t234_qspi.xml” --showlogs --network usb0 The jetson-orin-nano-devkit internal command is used to refresh the machine. The log of the process is as follows:
flash_1-1_0_20240329-114531.log (51.2 KB)
The following interface is displayed when Orin nano is powered on:
I used the serial port to get the boot log as follows:
orin_nano.log (74.8 KB)
Please help me check the reasons and how I should solve them? Thank you!
Thanks for posting. Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
Try this before flashing:
https://docs.nvidia.com/jetson/archives/r36.2/DeveloperGuide/SD/FlashingSupport.html#skipping-oem-config
