Orin Nano flashing failed
Hi,Nvidia
I have tried more than a dozen times and have been reporting the following error
19:38:51.777 - Error: Flash failure.
19:38:51.780 - Error: Either the device cannot mount the NFS server on the host or a flash command has failed. Check your network setting (VPN, firewall,...) to make sure the device can mount NFS server. Debug log saved to /tmp/tmp.nkhP1BYqmn. You can access the target's terminal through "sshpass -p root ssh root@fc00:1:1:0::2"
19:38:51.782 - Debug: The last 5 lines of the debug log are:
00:00:46.903 - Debug: Writing A_kernel partition with boot.img
00:00:46.909 - Debug: Get size of partition through connection.
00:00:46.957 - Debug: 58173440 bytes from /mnt/external/boot.img to /dev/nvme0n1: 1KB block=56810 remainder=0
00:00:46.961 - Debug: dd if=/mnt/external/boot.img of=/dev/nvme0n1 bs=1K skip=0  seek=20 count=56810
Cleaning up...
lihao@lihao:~/hello/Nano/orin_bsp_36_4_4/Linux_for_Tegra$ sudo ufw status
Status: inactive
lihao@lihao:~/hello/Nano/orin_bsp_36_4_4/Linux_for_Tegra$ cat 1_flash_image.sh
#!/usr/bin/env bash
set -e
CUR_DIR="$(cd "$(dirname "${BASH_SOURCE[0]}")" && pwd -P)"
cd ${CUR_DIR}
sudo ./tools/kernel_flash/l4t_initrd_flash.sh \
    --external-device nvme0n1p1 \
    -c tools/kernel_flash/flash_l4t_t234_nvme.xml \
    -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" \
    --showlogs --network usb0 upai-pro02-box-a00 internal
Hi @IvanLL,
I hope you are doing well!
I have a few questions to help troubleshoot the flashing issue:
  1. Are you using a custom carrier board for the Jetson?
  2. Are you running the flash on a virtual machine or a native Ubuntu host? Which Ubuntu version are you using?
  3. Can you confirm that the NFS server is enabled on your host? You can check with:
sudo systemctl status nfs-server
I found this forum which may help you solve the issue: Flash Error (Flash Jetson Linux - flash: [ 0.0106 ] ERROR: failed to read rcm_state) - #6 by nanxue2022
Additionally, sometimes flashing can fail due to a faulty USB cable. If possible, try using a different high-quality USB data cable.
It also would be helpful if you could share:
  • The full host-side logs from the flashing process.
  • The serial console logs from the Jetson device.
Best regards,
Nico
Hi @nico.morua
1.I’m using my own motherboard instead of the official one, but I can sometimes flash it successfully on a Lenovo host, so the motherboard should be fine.
2.I’m not using a virtual machine — I’m running it on a native Ubuntu 20.04 host.
3.
lihao@lihao:~/hello/Nano/orin_os_36_4_4/Linux_for_Tegra/source$ sudo systemctl status nfs-server
● nfs-server.service - NFS server and services
     Loaded: loaded (/lib/systemd/system/nfs-server.service; enabled; vendor preset: enabled)
    Drop-In: /run/systemd/generator/nfs-server.service.d
             └─order-with-mounts.conf
     Active: active (exited) since Wed 2025-10-29 09:24:45 CST; 2h 8min ago
    Process: 1224 ExecStartPre=/usr/sbin/exportfs -r (code=exited, status=0/SUCCESS)
    Process: 1232 ExecStart=/usr/sbin/rpc.nfsd $RPCNFSDARGS (code=exited, status=0/SUCCESS)
   Main PID: 1232 (code=exited, status=0/SUCCESS)
Oct 29 09:24:44 lihao systemd[1]: Starting NFS server and services...
Oct 29 09:24:45 lihao systemd[1]: Finished NFS server and services.
I’ve already replaced it with a high-speed USB data cable, but the issue still occurs.
I’ll post the complete log once I finish my other tasks and also try the thread you mentioned.
Thanks a lot for your help and suggestions!
Hi @IvanLL,
Any updates on this issue?
Were you able to extract the logs for me to review?
Feel free to reach out for any further support.
Best regards,
Nico
Hi @nico.morua
Sorry for replying to you so late. I’ve resolved the issue.
First, it must have a cooling fan added;
second, it needs to be connected via the serial port.
The second factor has the most direct impact — without the serial port connected, it will keep failing. This is likely related to the power supply design on the backplane I created.
Hi @IvanLL,
Glad to hear you resolved the issue!
If you need any further support, don’t hesitate to reach out - We’ll be happy to help!
Best regards,
Nico
@nico.morua Hi bro, I encountered some problems while using SPI as a slave. Could you give me some help?
