I tried to apply Jetson Linux version 36.2 to the Jetson Orin Nano development board, but I can’t flash it successfully with the command to enable the rootfs A/B configuration.
I am using the command exactly as it is in the document below, under the section ‘Flashing with rootfs A/B enabled:’.
https://docs.nvidia.com/jetson/archives/r36.2/DeveloperGuide/SD/FlashingSupport.html#using-initrd-flash-with-orin-nx-and-nano
After execution, a dialog with the following content is displayed on the monitor connected to the development board, against the background of Ubuntu’s GUI display. When I press the ‘OK’ button on it, the screen disappears.
‘The installer encountered an unrecoverable error. A desktop session will now be run so that you may investigate the problem or try installing again.‘
Furthermore, for the ‘Flashing for the default case:’ in the same document, I have confirmed that it can be flashed successfully.
Also, the Orin Nano on the development board is equipped with a 128GB SSD, and I believe the capacity is sufficient.
